Things that go bump in the night... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Things that go bump in the night... (/showthread.php?tid=5153) |
Things that go bump in the night... - Ryan Wright - 06-18-2007 06:06 Several nights now, I have heard a loud thump in my coach in the middle of the night. The first couple of nights it was loud enough and startled me out of my sleep such that I flipped the security lights on and went out hunting bad guys with a tactical light and a 9mm (bus is parked on my private property behind a fence with a locked gate, so anyone lurking in the shadows by my coach is fair game). Fortunately I haven't found anyone and the noise happened again last night, so I'm fairly sure at this point it's something on the bus itself. Basically, it's a "boom" type of echoing noise. It's loud, at least when you're sleeping in the back. Sounds like someone smacking a big, empty aluminum tank with a baseball bat. I can't help but wonder if it's coming from the plumbing system? Maybe a loud burp of a tank of some sort? Perhaps a side wall on the hot water heater flexing? I don't know, I'm just guessing here. Has anyone else experienced this? I'm not running A/C or heaters, so probably not related to those. No engine or generator running, either. Plugged into 50 amp shore power, running fridge, water pump, hot water heater, battery chargers and lights. That's about it. No incoming water connection (I prefer to use the on-board water and just fill it up every few weeks to minimize the damage in the event of a leak). Thanks for any advice. -Ryan '86 PT-40 8V92 Tri-Cities, WA Things that go bump in the night... - Leroy Eckert - 06-18-2007 06:57 Any bears nearby? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Monday, June 18, 2007 1:06 PM Subject: [WanderlodgeForum] Things that go bump in the night... Several nights now, I have heard a loud thump in my coach in the middle of the night. The first couple of nights it was loud enough and startled me out of my sleep such that I flipped the security lights on and went out hunting bad guys with a tactical light and a 9mm (bus is parked on my private property behind a fence with a locked gate, so anyone lurking in the shadows by my coach is fair game). Fortunately I haven't found anyone and the noise happened again last night, so I'm fairly sure at this point it's something on the bus itself. Basically, it's a "boom" type of echoing noise. It's loud, at least when you're sleeping in the back. Sounds like someone smacking a big, empty aluminum tank with a baseball bat. I can't help but wonder if it's coming from the plumbing system? Maybe a loud burp of a tank of some sort? Perhaps a side wall on the hot water heater flexing? I don't know, I'm just guessing here. Has anyone else experienced this? I'm not running A/C or heaters, so probably not related to those. No engine or generator running, either. Plugged into 50 amp shore power, running fridge, water pump, hot water heater, battery chargers and lights. That's about it. No incoming water connection (I prefer to use the on-board water and just fill it up every few weeks to minimize the damage in the event of a leak). Thanks for any advice. -Ryan '86 PT-40 8V92 Tri-Cities, WA [Non-text portions of this message have been removed] Things that go bump in the night... - Ryan Wright - 06-18-2007 07:13 Leroy, On 6/18/07, Leroy Eckert > > Any bears nearby? Nope. Bears don't live in the desert and I'm right smack in the middle of one. For that matter, no big game anywhere really to speak of. There are some elk outside the city and the occasional wild horses, but I've never seen 'em in the city or anywhere near my neighborhood. -Ryan '86 PT-40 8V92 Tri-Cities, WA Things that go bump in the night... - Wayne - 06-18-2007 07:18 I am not sure if it is correct or not but I had a similar sound on my 1984 - I concluded it was the parking brake releasing a bit and grabbing. Are you on any kind of front to back slope? Wayne Chappuis --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Several nights now, I have heard a loud thump in my coach in the > middle of the night. The first couple of nights it was loud enough and > startled me out of my sleep such that I flipped the security lights on > and went out hunting bad guys with a tactical light and a 9mm (bus is > parked on my private property behind a fence with a locked gate, so > anyone lurking in the shadows by my coach is fair game). Fortunately I > haven't found anyone and the noise happened again last night, so I'm > fairly sure at this point it's something on the bus itself. > > Basically, it's a "boom" type of echoing noise. It's loud, at least > when you're sleeping in the back. Sounds like someone smacking a big, > empty aluminum tank with a baseball bat. I can't help but wonder if > it's coming from the plumbing system? Maybe a loud burp of a tank of > some sort? Perhaps a side wall on the hot water heater flexing? I > don't know, I'm just guessing here. > > Has anyone else experienced this? I'm not running A/C or heaters, so > probably not related to those. No engine or generator running, either. > Plugged into 50 amp shore power, running fridge, water pump, hot water > heater, battery chargers and lights. That's about it. No incoming > water connection (I prefer to use the on-board water and just fill it > up every few weeks to minimize the damage in the event of a leak). > > Thanks for any advice. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > Things that go bump in the night... - Leroy Eckert - 06-18-2007 07:40 That takes care of that idea. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, Fl ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 18, 2007 1:57 PM Subject: Re: [WanderlodgeForum] Things that go bump in the night... Any bears nearby? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Monday, June 18, 2007 1:06 PM Subject: [WanderlodgeForum] Things that go bump in the night... Several nights now, I have heard a loud thump in my coach in the middle of the night. The first couple of nights it was loud enough and startled me out of my sleep such that I flipped the security lights on and went out hunting bad guys with a tactical light and a 9mm (bus is parked on my private property behind a fence with a locked gate, so anyone lurking in the shadows by my coach is fair game). Fortunately I haven't found anyone and the noise happened again last night, so I'm fairly sure at this point it's something on the bus itself. Basically, it's a "boom" type of echoing noise. It's loud, at least when you're sleeping in the back. Sounds like someone smacking a big, empty aluminum tank with a baseball bat. I can't help but wonder if it's coming from the plumbing system? Maybe a loud burp of a tank of some sort? Perhaps a side wall on the hot water heater flexing? I don't know, I'm just guessing here. Has anyone else experienced this? I'm not running A/C or heaters, so probably not related to those. No engine or generator running, either. Plugged into 50 amp shore power, running fridge, water pump, hot water heater, battery chargers and lights. That's about it. No incoming water connection (I prefer to use the on-board water and just fill it up every few weeks to minimize the damage in the event of a leak). Thanks for any advice. -Ryan '86 PT-40 8V92 Tri-Cities, WA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Things that go bump in the night... - bubblerboy64 - 06-18-2007 07:57 1St guess: Its a body panel springing from the change in temperature day to night. 2nd guess: The bus is haunted :-) John Heckman Hopeful owner FC by 4/7 Shippensburg Pa > > I am not sure if it is correct or not but I had a similar sound on my > 1984 - I concluded it was the parking brake releasing a bit and > grabbing. Are you on any kind of front to back slope? > > Wayne Chappuis > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > Several nights now, I have heard a loud thump in my coach in the > > middle of the night. The first couple of nights it was loud enough > and > > startled me out of my sleep such that I flipped the security lights > on > > and went out hunting bad guys with a tactical light and a 9mm (bus > is > > parked on my private property behind a fence with a locked gate, so > > anyone lurking in the shadows by my coach is fair game). > Fortunately I > > haven't found anyone and the noise happened again last night, so I'm > > fairly sure at this point it's something on the bus itself. > > > > Basically, it's a "boom" type of echoing noise. It's loud, at least > > when you're sleeping in the back. Sounds like someone smacking a > big, > > empty aluminum tank with a baseball bat. I can't help but wonder if > > it's coming from the plumbing system? Maybe a loud burp of a tank of > > some sort? Perhaps a side wall on the hot water heater flexing? I > > don't know, I'm just guessing here. > > > > Has anyone else experienced this? I'm not running A/C or heaters, so > > probably not related to those. No engine or generator running, > either. > > Plugged into 50 amp shore power, running fridge, water pump, hot > water > > heater, battery chargers and lights. That's about it. No incoming > > water connection (I prefer to use the on-board water and just fill > it > > up every few weeks to minimize the damage in the event of a leak). > > > > Thanks for any advice. > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > Things that go bump in the night... - Ryan Wright - 06-18-2007 08:30 On 6/18/07, Wayne > > I am not sure if it is correct or not but I had a similar sound on my > 1984 - I concluded it was the parking brake releasing a bit and > grabbing. Are you on any kind of front to back slope? No front to back slope that I can tell - also, I'm up on leveling jacks. Curt Sprenger on the "wanderlodge" group mentioned a similar noise with his leveling jacks, so I'm going to try topping off the fluid & cycling them as he did. Might just solve it. Thanks for the ideas! -Ryan Things that go bump in the night... - pattypape - 06-18-2007 09:40 Air bag or jacks leaking down and causing a chassis, rear brake or suspention noise. Bill's Guess, 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Several nights now, I have heard a loud thump in my coach in the > middle of the night. The first couple of nights it was loud enough and > startled me out of my sleep such that I flipped the security lights on > and went out hunting bad guys with a tactical light and a 9mm (bus is > parked on my private property behind a fence with a locked gate, so > anyone lurking in the shadows by my coach is fair game). Fortunately I > haven't found anyone and the noise happened again last night, so I'm > fairly sure at this point it's something on the bus itself. > > Basically, it's a "boom" type of echoing noise. It's loud, at least > when you're sleeping in the back. Sounds like someone smacking a big, > empty aluminum tank with a baseball bat. I can't help but wonder if > it's coming from the plumbing system? Maybe a loud burp of a tank of > some sort? Perhaps a side wall on the hot water heater flexing? I > don't know, I'm just guessing here. > > Has anyone else experienced this? I'm not running A/C or heaters, so > probably not related to those. No engine or generator running, either. > Plugged into 50 amp shore power, running fridge, water pump, hot water > heater, battery chargers and lights. That's about it. No incoming > water connection (I prefer to use the on-board water and just fill it > up every few weeks to minimize the damage in the event of a leak). > > Thanks for any advice. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > Things that go bump in the night... - erniecarpet@... - 06-18-2007 10:21 In a message dated 6/18/2007 6:51:14 P.M. Mountain Standard Time, gcyeaw@... writes: Are you sure Ernie Ekberg isn't parked nearby tossing empty wine boxes in your direction? He's on the opposite side of the Continental Divide. ~ Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Things that go bump in the night... - Gardner Yeaw - 06-18-2007 13:48 Are you sure Ernie Ekberg isn't parked nearby tossing empty wine boxes in your direction? Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Several nights now, I have heard a loud thump in my coach in the > middle of the night. The first couple of nights it was loud enough and > startled me out of my sleep such that I flipped the security lights on > and went out hunting bad guys with a tactical light and a 9mm (bus is > parked on my private property behind a fence with a locked gate, so > anyone lurking in the shadows by my coach is fair game). Fortunately I > haven't found anyone and the noise happened again last night, so I'm > fairly sure at this point it's something on the bus itself. > > Basically, it's a "boom" type of echoing noise. It's loud, at least > when you're sleeping in the back. Sounds like someone smacking a big, > empty aluminum tank with a baseball bat. I can't help but wonder if > it's coming from the plumbing system? Maybe a loud burp of a tank of > some sort? Perhaps a side wall on the hot water heater flexing? I > don't know, I'm just guessing here. > > Has anyone else experienced this? I'm not running A/C or heaters, so > probably not related to those. No engine or generator running, either. > Plugged into 50 amp shore power, running fridge, water pump, hot water > heater, battery chargers and lights. That's about it. No incoming > water connection (I prefer to use the on-board water and just fill it > up every few weeks to minimize the damage in the event of a leak). > > Thanks for any advice. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
