Diagnosing Allison Code 32 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Diagnosing Allison Code 32 (/showthread.php?tid=5201) |
Diagnosing Allison Code 32 - Ryan Wright - 06-25-2007 18:09 Here's the story: When switching from drive to neutral, roughly every third time give or take the transmission will shudder a bit before going into neutral and the "check trans" light will come on. Pressing the "test trans" button causes the light to flash a code 32. This happened to me on the way home from buying the coach at Mr. Oliver's in Texas. An Allison licensed shop in Montana (Interstate) diagnosed it as the reverse solenoid getting pressure when it shouldn't. They tested the external wiring harness and found no shorts. Did not have parts on hand and I needed to get home so I drove the bus home as-is and brought it to a shop here. Cost me $400 for diagnosis. As of Friday, local shop has replaced the reverse solenoid, filter & flushed/refilled the trans fluid. Cost me $1000 including extraction and repair of two seized bolts on the trans pan. Problem still exists. ![]() I'm going to take it back to them, but does anyone have any idea whatsoever on this one before I sink several grand into more diagnostic labor? Seems to me it should be straight forward; I know when my car sets an engine code, it's just, "Replace part x." I'd imagine the built in diagnostics on my transmission would be just as smart, would they not? This one is getting frustrating and expensive fast. -Ryan '86 PT-40 8V92 Tri-Cities, WA Diagnosing Allison Code 32 - truitt44@...> - 06-26-2007 04:33 Ryan, I have no idea of your problem but also being the owner of an 86 8V92 PT40 with a 5 speed Allison I am very interested in what you find out. Please keep us posted and good luck. Howard Truitt Camilla, Ga. 86 PT40 > > From: "Ryan Wright" > Date: 2007/06/26 Tue AM 02:09:42 EDT > To: WanderlodgeForum@yahoogroups.com, wanderlodge@yahoogroups.com > Subject: [WanderlodgeForum] Diagnosing Allison Code 32 > > Here's the story: When switching from drive to neutral, roughly every > third time give or take the transmission will shudder a bit before > going into neutral and the "check trans" light will come on. Pressing > the "test trans" button causes the light to flash a code 32. > > This happened to me on the way home from buying the coach at Mr. > Oliver's in Texas. An Allison licensed shop in Montana (Interstate) > diagnosed it as the reverse solenoid getting pressure when it > shouldn't. They tested the external wiring harness and found no > shorts. Did not have parts on hand and I needed to get home so I drove > the bus home as-is and brought it to a shop here. Cost me $400 for > diagnosis. > > As of Friday, local shop has replaced the reverse solenoid, filter & > flushed/refilled the trans fluid. Cost me $1000 including extraction > and repair of two seized bolts on the trans pan. Problem still exists. > ![]() > > I'm going to take it back to them, but does anyone have any idea > whatsoever on this one before I sink several grand into more > diagnostic labor? Seems to me it should be straight forward; I know > when my car sets an engine code, it's just, "Replace part x." I'd > imagine the built in diagnostics on my transmission would be just as > smart, would they not? This one is getting frustrating and expensive > fast. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > |
