'00 LXi Filters and Belts - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: '00 LXi Filters and Belts (/showthread.php?tid=5224) |
'00 LXi Filters and Belts - Allen & Conny - 08-07-2007 04:05 Does anyone have a complete list of fuel filters, oil filters, and spare belts for an LXi? Is there a favorite internet site/mail order supplier for these items? We are getting ready to start using this beast and I would like to carry spares. Thanks Everyone! -Allen and Conny '00 LXi, "Lone Wolf" Tampa Bay, FL '00 LXi Filters and Belts - g_man1146 - 08-07-2007 05:42 Allen, Here is my list. It appears to wrap around on the Yahoo post so if you want it in Excel, email me and I will attach a copy to the reply. That way you can modify it too. As others have said, use your dash switch to charge the house and chassis batteries while connected to shore power. The generator charges it's own battery. Several years ago I installed an Echo-Charger for the chassis batteries so I don't need to turn the switch on and off, all automatic and kind to your chassis batteries. Rich D. '99LXi43' CT 1999 Lxi Cross Reference Blue Bird Donaldson Baldwin FleetGuard NAPA Other Detroit Series 60 Oil Filter (2) 6082408 P552100 B495 LF3620 1971 Fuel Filter 3734175 P556916 BF5810 FF5206 3120 Racor 2020SM 3831310 P552020 PF590 3210 Coolant Filter P554422 B5140 WF2050 4074 Hydraulic Reservoir Filter (3) 4322442 Nelson 87976M Air Filter 189044 Farr 998-42-007 13.5X18 Serpentine Belt 4558540 Detroit 23521337 Air Conditioner Belt 1907674 Gates 9002-2070 Transmission Filter (2) 4541702 Allison 29526898 Generator Fuel Filter 3970860 P550127 BF940 FF5106 3390 Oil Filter 3970878 P550882 B2 LF3341 1068 Air Filter (Canister) 3838158 ECB05-5001 --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > Does anyone have a complete list of fuel filters, oil filters, and > spare belts for an LXi? Is there a favorite internet site/mail order > supplier for these items? We are getting ready to start using this > beast and I would like to carry spares. > > Thanks Everyone! > > -Allen and Conny > '00 LXi, "Lone Wolf" > Tampa Bay, FL > '00 LXi Filters and Belts - mbulriss - 08-07-2007 06:16 Rich, Greta information for future referrnce. I hope you don't mind, but I took the liberty of formatting your list and adding it to the Files in the 'Bluebird Filters' File. If you see any errors, let me know. Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote: > > Allen, > > Here is my list. It appears to wrap around on the Yahoo post so if you > want it in Excel, email me and I will attach a copy to the reply. That > way you can modify it too. > > As others have said, use your dash switch to charge the house and > chassis batteries while connected to shore power. The generator charges > it's own battery. Several years ago I installed an Echo-Charger for the > chassis batteries so I don't need to turn the switch on and off, all > automatic and kind to your chassis batteries. > > Rich D. '99LXi43' CT > > > 1999 Lxi Cross Reference Blue Bird Donaldson Baldwin > FleetGuard NAPA Other > > > > Detroit Series 60 > > Oil Filter (2) 6082408 P552100 B495 LF3620 1971 > > Fuel Filter 3734175 P556916 BF5810 FF5206 3120 > > Racor 2020SM 3831310 P552020 PF590 3210 > > Coolant Filter P554422 B5140 WF2050 4074 > > Hydraulic Reservoir Filter (3) 4322442 > Nelson 87976M > > Air Filter 189044 Farr 998-42-007 > 13.5X18 > > Serpentine Belt 4558540 Detroit 23521337 > > Air Conditioner Belt 1907674 Gates > 9002-2070 > > > Transmission > > Filter (2) 4541702 Allison 29526898 > > > Generator > > Fuel Filter 3970860 P550127 BF940 FF5106 3390 > > Oil Filter 3970878 P550882 B2 LF3341 1068 > > Air Filter (Canister) 3838158 ECB05-5001 > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > > > > Does anyone have a complete list of fuel filters, oil filters, and > > spare belts for an LXi? Is there a favorite internet site/mail order > > supplier for these items? We are getting ready to start using this > > beast and I would like to carry spares. > > > > Thanks Everyone! > > > > -Allen and Conny > > '00 LXi, "Lone Wolf" > > Tampa Bay, FL > > > '00 LXi Filters and Belts - Pete Masterson - 08-07-2007 06:43 This is what I have for the '95 with the DD Series 60 engine and the Powertech 15kw generator. It may be a start for you. Napa auto parts is pretty good for getting filters. Wix (brand) are also widely available. If you have a different engine (Cummins in later models) then you'll need to check your blue box (owners manual) or read the numbers off the existing filters. PowerTech PTS MH-15 Generator (with Kubota Engine) (Powertech part no) NAPA # Wix # Fram # Oil filter 70000-32091 1191 51191 3569 Fuel Filter 70000-43081 3390 33390 N/A Air Filter 70000-11080 6296 46296 OEM: Donaldson DuraLite Air Cleaner ECC (type), C065002 (part #). Might also be NAPA #2792 (which is about 1/2" bigger around and 1/2" longer) Oil: Use 10w30 oil. Takes 2.4 gallons plus oil filter. Detroit Diesel Series 60 Engine Racor (Model 1000FG) Use element 2020TM -- 10 micron. DD# AC- Delco WIX Fuel Filter Primary 25014275 TP915D 22-25 micron 33118 Secondary 25014342 TP916D 6-8 micron 33120 Oil Filter 25414505 PF2100 51971 Requires 2 per change Oil: Use 15w40. (Do not use single weight oils). Capacity 26 quarts to low mark 32 quarts to full mark 40 quarts when oil filters are changed. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 7, 2007, at 9:05 AM, Allen & Conny wrote: > Does anyone have a complete list of fuel filters, oil filters, and > spare belts for an LXi? Is there a favorite internet site/mail order > supplier for these items? We are getting ready to start using this > beast and I would like to carry spares. > > Thanks Everyone! > > -Allen and Conny > '00 LXi, "Lone Wolf" > Tampa Bay, FL > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] '00 LXi Filters and Belts - g_man1146 - 08-07-2007 08:34 --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: Mike, I don't mind at all - glad to help. There is one line where the word wrap messed things up: That is for the "Racor (Model 2020SM)" The filter #'s are: Blue Bird 3831310 Donaldson P552020 Baldwin PF590 Fleetguard NONE NAPA 3710 Rich D. '99LXi43' CT > > Rich, > > Greta information for future referrnce. I hope you don't mind, but I > took the liberty of formatting your list and adding it to the Files in > the 'Bluebird Filters' File. If you see any errors, let me know. > > Thanks, > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > '00 LXi Filters and Belts - Allen & Conny - 08-08-2007 07:52 Thank you Pete! -Allen --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > This is what I have for the '95 with the DD Series 60 engine and the > Powertech 15kw generator. It may be a start for you. Napa auto parts > is pretty good for getting filters. Wix (brand) are also widely > available. If you have a different engine (Cummins in later models) > then you'll need to check your blue box (owners manual) or read the > numbers off the existing filters. > > > PowerTech PTS MH-15 Generator (with Kubota Engine) > > (Powertech part no) NAPA # Wix # Fram # > Oil filter 70000-32091 1191 51191 3569 > > Fuel Filter 70000-43081 3390 33390 N/A > > Air Filter 70000-11080 6296 46296 > OEM: Donaldson DuraLite Air Cleaner ECC (type), C065002 (part #). > Might also be NAPA #2792 (which is about 1/2" bigger around and 1/2" > longer) > > Oil: Use 10w30 oil. Takes 2.4 gallons plus oil filter. > > > Detroit Diesel Series 60 Engine > > Racor (Model 1000FG) Use element 2020TM -- 10 micron. > > DD# AC- > Delco WIX > Fuel Filter > Primary 25014275 TP915D 22-25 micron > 33118 > Secondary 25014342 TP916D 6-8 micron > 33120 > > Oil Filter 25414505 > PF2100 51971 > Requires 2 per change > > Oil: Use 15w40. (Do not use single weight oils). > Capacity 26 quarts to low mark > 32 quarts to full mark > 40 quarts when oil filters are changed. > > > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Aug 7, 2007, at 9:05 AM, Allen & Conny wrote: > > > Does anyone have a complete list of fuel filters, oil filters, and > > spare belts for an LXi? Is there a favorite internet site/mail order > > supplier for these items? We are getting ready to start using this > > beast and I would like to carry spares. > > > > Thanks Everyone! > > > > -Allen and Conny > > '00 LXi, "Lone Wolf" > > Tampa Bay, FL > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > [Non-text portions of this message have been removed] > '00 LXi Filters and Belts - Allen & Conny - 08-08-2007 07:54 Outstanding Rich! Thank you very much!! Can I get the Racor fuel filter wrench at Napa? -Allen --- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote: > > Allen, > > Here is my list. It appears to wrap around on the Yahoo post so if you > want it in Excel, email me and I will attach a copy to the reply. That > way you can modify it too. > > As others have said, use your dash switch to charge the house and > chassis batteries while connected to shore power. The generator charges > it's own battery. Several years ago I installed an Echo-Charger for the > chassis batteries so I don't need to turn the switch on and off, all > automatic and kind to your chassis batteries. > > Rich D. '99LXi43' CT > > > 1999 Lxi Cross Reference Blue Bird Donaldson Baldwin > FleetGuard NAPA Other > > > > Detroit Series 60 > > Oil Filter (2) 6082408 P552100 B495 LF3620 1971 > > Fuel Filter 3734175 P556916 BF5810 FF5206 3120 > > Racor 2020SM 3831310 P552020 PF590 3210 > > Coolant Filter P554422 B5140 WF2050 4074 > > Hydraulic Reservoir Filter (3) 4322442 > Nelson 87976M > > Air Filter 189044 Farr 998-42- 007 > 13.5X18 > > Serpentine Belt 4558540 Detroit 23521337 > > Air Conditioner Belt 1907674 Gates > 9002-2070 > > > Transmission > > Filter (2) 4541702 Allison 29526898 > > > Generator > > Fuel Filter 3970860 P550127 BF940 FF5106 3390 > > Oil Filter 3970878 P550882 B2 LF3341 1068 > > Air Filter (Canister) 3838158 ECB05-5001 > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > > > > Does anyone have a complete list of fuel filters, oil filters, and > > spare belts for an LXi? Is there a favorite internet site/mail order > > supplier for these items? We are getting ready to start using this > > beast and I would like to carry spares. > > > > Thanks Everyone! > > > > -Allen and Conny > > '00 LXi, "Lone Wolf" > > Tampa Bay, FL > > > '00 LXi Filters and Belts - mbulriss - 08-08-2007 08:34 FYI, We have uploaded Rich's Excel cross refernce chart for the LXi, along with David's addition on the genny filter to the Files section of the forum in the 'Bluebird Filters' File. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > Outstanding Rich! Thank you very much!! Can I get the Racor fuel > filter wrench at Napa? > > -Allen > > --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > wrote: > > > > Allen, > > > > Here is my list. It appears to wrap around on the Yahoo post so if > you > > want it in Excel, email me and I will attach a copy to the reply. > That > > way you can modify it too. > > > > As others have said, use your dash switch to charge the house and > > chassis batteries while connected to shore power. The generator > charges > > it's own battery. Several years ago I installed an Echo-Charger > for the > > chassis batteries so I don't need to turn the switch on and off, > all > > automatic and kind to your chassis batteries. > > > > Rich D. '99LXi43' CT > > > > > > 1999 Lxi Cross Reference Blue Bird Donaldson > Baldwin > > FleetGuard NAPA Other > > > > > > > > Detroit Series 60 > > > > Oil Filter (2) 6082408 P552100 B495 LF3620 1971 > > > > Fuel Filter 3734175 P556916 BF5810 FF5206 3120 > > > > Racor 2020SM 3831310 P552020 PF590 3210 > > > > Coolant Filter P554422 B5140 WF2050 4074 > > > > Hydraulic Reservoir Filter (3) 4322442 > > > Nelson 87976M > > > > Air Filter 189044 Farr 998-42- > 007 > > 13.5X18 > > > > Serpentine Belt 4558540 > Detroit 23521337 > > > > Air Conditioner Belt 1907674 > Gates > > 9002-2070 > > > > > > Transmission > > > > Filter (2) 4541702 Allison > 29526898 > > > > > > Generator > > > > Fuel Filter 3970860 P550127 BF940 FF5106 3390 > > > > Oil Filter 3970878 P550882 B2 LF3341 1068 > > > > Air Filter (Canister) 3838158 ECB05-5001 > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > > > > > > > Does anyone have a complete list of fuel filters, oil filters, > and > > > spare belts for an LXi? Is there a favorite internet site/mail > order > > > supplier for these items? We are getting ready to start using > this > > > beast and I would like to carry spares. > > > > > > Thanks Everyone! > > > > > > -Allen and Conny > > > '00 LXi, "Lone Wolf" > > > Tampa Bay, FL > > > > > > |
