FC 35 Generator - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FC 35 Generator (/showthread.php?tid=5261) |
FC 35 Generator - jmoorelewy - 06-30-2007 04:35 Does anyone know what generator I have in my 1982 FC 35. Its diesel and gold in colour. Is the engine a Perkins? Does anyone know where I can get a new waterpump? Many thanks for the help. Justin 1982 FC-35 "Perfect Weekend" FC 35 Generator - Ralph L. Fullenwider - 06-30-2007 05:56 Justin: You have a Perkins/Kohler in your Coach Perkins 4.108 Kohler 12.5 KW Probably a CCOPY-67 Model At 1800 rpm you will put out 60 HZ @ 240 VAC (120 VAC per leg) At no load it will burn aprox .4 GPH Diesel Fuel and at full load as much as aprox 1 GPH diesel. If you extend the gen set drawer, and have a mirror and flashlight handy, look at the rear of the valve cover of the engine. There you should find a slanted plate between the engine and generator. On that plate will be the specification tag with all the specs on it. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 04:35 PM 6/30/2007 +0000, you wrote: >Does anyone know what generator I have in my 1982 FC 35. Its diesel and >gold in colour. Is >the engine a Perkins? Does anyone know where I can get a new waterpump? >Many thanks for >the help. > >Justin 1982 FC-35 "Perfect Weekend" > > Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma FC 35 Generator - mbulriss - 06-30-2007 06:45 Jsutin, Also if you have not found it yet, in the "Links" section of the Wanderlodgeforum there is a link labeled Perkins Diesel Repair Manual. It links to an online shop maual for the Perkins. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Justin: > > You have a Perkins/Kohler in your Coach > Perkins 4.108 > Kohler 12.5 KW > > Probably a CCOPY-67 Model > > At 1800 rpm you will put out 60 HZ @ 240 VAC (120 VAC per leg) > > At no load it will burn aprox .4 GPH Diesel Fuel and at full load as much > as aprox 1 GPH diesel. > > If you extend the gen set drawer, and have a mirror and flashlight handy, > look at the rear of the valve cover of the engine. There you should find a > slanted plate between the engine and generator. On that plate will be the > specification tag with all the specs on it. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 04:35 PM 6/30/2007 +0000, you wrote: > >Does anyone know what generator I have in my 1982 FC 35. Its diesel and > >gold in colour. Is > >the engine a Perkins? Does anyone know where I can get a new waterpump? > >Many thanks for > >the help. > > > >Justin 1982 FC-35 "Perfect Weekend" > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > FC 35 Generator - jmoorelewy - 06-30-2007 07:02 Thanks for all your help, I think I have identified the generator as a 4.107 Perkins. I am still looking to see if I can find a water pump this weekend! --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Jsutin, > > Also if you have not found it yet, in the "Links" section of the > Wanderlodgeforum there is a link labeled Perkins Diesel Repair Manual. > It links to an online shop maual for the Perkins. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Justin: > > > > You have a Perkins/Kohler in your Coach > > Perkins 4.108 > > Kohler 12.5 KW > > > > Probably a CCOPY-67 Model > > > > At 1800 rpm you will put out 60 HZ @ 240 VAC (120 VAC per leg) > > > > At no load it will burn aprox .4 GPH Diesel Fuel and at full load as > much > > as aprox 1 GPH diesel. > > > > If you extend the gen set drawer, and have a mirror and flashlight > handy, > > look at the rear of the valve cover of the engine. There you should > find a > > slanted plate between the engine and generator. On that plate will > be the > > specification tag with all the specs on it. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Duncan, Oklahoma > > > > At 04:35 PM 6/30/2007 +0000, you wrote: > > >Does anyone know what generator I have in my 1982 FC 35. Its diesel > and > > >gold in colour. Is > > >the engine a Perkins? Does anyone know where I can get a new > waterpump? > > >Many thanks for > > >the help. > > > > > >Justin 1982 FC-35 "Perfect Weekend" > > > > > > > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Duncan, Oklahoma > > > FC 35 Generator - mbulriss - 06-30-2007 08:03 > 4.107 Perkins. I am still looking to see if I can find a water pump > this weekend! Good luck finding that on a weekend! Hard enough to find Perkins parts locally *anytime* unless you are in very large metropolitan area. Tractor stores might have one, since Perkins were used in many small tractors and bobcats. As I recall, you need all the codes you can find on the Perkins to get the right pump (or most other parts), not just the 4.107 model code. Since you have to replace the water pump, you should take the radiator in for cleaning and inspection at the same time. I went back with distilled water and low SCA coolant and got it all over with at once when I replaced my Perkins water pump on my 83PT. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "jmoorelewy" > > > Thanks for all your help, I think I have identified the generator as a > 4.107 Perkins. I am still looking to see if I can find a water pump > this weekend! > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Jsutin, > > > > Also if you have not found it yet, in the "Links" section of the > > Wanderlodgeforum there is a link labeled Perkins Diesel Repair Manual. > > It links to an online shop maual for the Perkins. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Justin: > > > > > > You have a Perkins/Kohler in your Coach > > > Perkins 4.108 > > > Kohler 12.5 KW > > > > > > Probably a CCOPY-67 Model > > > > > > At 1800 rpm you will put out 60 HZ @ 240 VAC (120 VAC per leg) > > > > > > At no load it will burn aprox .4 GPH Diesel Fuel and at full load as > > much > > > as aprox 1 GPH diesel. > > > > > > If you extend the gen set drawer, and have a mirror and flashlight > > handy, > > > look at the rear of the valve cover of the engine. There you should > > find a > > > slanted plate between the engine and generator. On that plate will > > be the > > > specification tag with all the specs on it. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 > > > Duncan, Oklahoma > > > > > > At 04:35 PM 6/30/2007 +0000, you wrote: > > > >Does anyone know what generator I have in my 1982 FC 35. Its diesel > > and > > > >gold in colour. Is > > > >the engine a Perkins? Does anyone know where I can get a new > > waterpump? > > > >Many thanks for > > > >the help. > > > > > > > >Justin 1982 FC-35 "Perfect Weekend" > > > > > > > > > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 > > > Duncan, Oklahoma > > > > > > FC 35 Generator - davidkerryedwards - 06-30-2007 08:59 Might want to try marine supply stores also, if there are any in your area. Lots of Perkins were put in sailboats. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > > 4.107 Perkins. I am still looking to see if I can find a water pump > > this weekend! > > Good luck finding that on a weekend! Hard enough to find Perkins > parts locally *anytime* unless you are in very large metropolitan > area. Tractor stores might have one, since Perkins were used in many > small tractors and bobcats. As I recall, you need all the codes you > can find on the Perkins to get the right pump (or most other parts), > not just the 4.107 model code. > > Since you have to replace the water pump, you should take the radiator > in for cleaning and inspection at the same time. I went back with > distilled water and low SCA coolant and got it all over with at once > when I replaced my Perkins water pump on my 83PT. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "jmoorelewy" > > > > > > Thanks for all your help, I think I have identified the generator as a > > 4.107 Perkins. I am still looking to see if I can find a water pump > > this weekend! > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > > > Jsutin, > > > > > > Also if you have not found it yet, in the "Links" section of the > > > Wanderlodgeforum there is a link labeled Perkins Diesel Repair Manual. > > > It links to an online shop maual for the Perkins. > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > Justin: > > > > > > > > You have a Perkins/Kohler in your Coach > > > > Perkins 4.108 > > > > Kohler 12.5 KW > > > > > > > > Probably a CCOPY-67 Model > > > > > > > > At 1800 rpm you will put out 60 HZ @ 240 VAC (120 VAC per leg) > > > > > > > > At no load it will burn aprox .4 GPH Diesel Fuel and at full load as > > > much > > > > as aprox 1 GPH diesel. > > > > > > > > If you extend the gen set drawer, and have a mirror and flashlight > > > handy, > > > > look at the rear of the valve cover of the engine. There you should > > > find a > > > > slanted plate between the engine and generator. On that plate will > > > be the > > > > specification tag with all the specs on it. > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > 84FC35 > > > > Duncan, Oklahoma > > > > > > > > At 04:35 PM 6/30/2007 +0000, you wrote: > > > > >Does anyone know what generator I have in my 1982 FC 35. Its diesel > > > and > > > > >gold in colour. Is > > > > >the engine a Perkins? Does anyone know where I can get a new > > > waterpump? > > > > >Many thanks for > > > > >the help. > > > > > > > > > >Justin 1982 FC-35 "Perfect Weekend" > > > > > > > > > > > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > 84FC35 > > > > Duncan, Oklahoma > > > > > > > > > > FC 35 Generator - jmoorelewy - 06-30-2007 14:06 Thanks to everyone for the help here is the update: I found a water pump at a marine supply store that was closed but the owner opened up for us! I then drove around like a mad person to find a place to get the pulley off the shaft and then the pulley pressed onto the new pump. Slight problem, the shaft is slightly bigger on the new pump so the pulley split when we were pressing it on. We tig welded the pulley and i have the whole thing put back together. I am having the rad flushed out so I will report back on Monday. Again thanks for everyones help, Justin 1982 FC-35 "Perfect Weekend" -- In WanderlodgeForum@yahoogroups.com, "jmoorelewy" > > Does anyone know what generator I have in my 1982 FC 35. Its diesel and gold in colour. Is > the engine a Perkins? Does anyone know where I can get a new waterpump? Many thanks for > the help. > > Justin 1982 FC-35 "Perfect Weekend" > |
