Jabco water pressure regulator. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Jabco water pressure regulator. (/showthread.php?tid=5273) |
Jabco water pressure regulator. - williamcharrison - 07-02-2007 03:55 Anyone had experience changing the water pressure regulator, and where can you get a compatible unit? I believe the original was manufactured by Jabco. Chuck Harrison A kron, Ohio 90 SP36 Jabco water pressure regulator. - James Hutchings - 07-02-2007 04:10 Is that Jabco or Jabsco? From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of williamcharrison Sent: Monday, July 02, 2007 8:56 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Jabco water pressure regulator. Anyone had experience changing the water pressure regulator, and where can you get a compatible unit? I believe the original was manufactured by Jabco. Chuck Harrison A kron, Ohio 90 SP36 [Non-text portions of this message have been removed] Jabco water pressure regulator. - g_man1146 - 07-02-2007 04:29 Sureflo also makes a replacement that should fit. But, IMO, replace it with a Watts, home type regulator. See the 4 pictures of mine at this link: http://www.photosleeve.com/v/Gman/Regulator_Fix/IMG_0028.JPG.html Improved water flow and beter protection. Most RV water regulators are good for less than 1 gpm. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Anyone had experience changing the water pressure regulator, and > where can you get a compatible unit? I believe the original was > manufactured by Jabco. > > Chuck Harrison > A kron, Ohio > 90 SP36 > Jabco water pressure regulator. - Curt Sprenger - 07-02-2007 04:31 Chuck, I sent you pictures of what I did when our regulator stopped working. The pictures are also out on one of, or both forums. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. James Hutchings wrote: > Is that Jabco or Jabsco? > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com > > Sent: Monday, July 02, 2007 8:56 AM > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Jabco water pressure regulator. > > Anyone had experience changing the water pressure regulator, and > where can you get a compatible unit? I believe the original was > manufactured by Jabco. > > Chuck Harrison > A kron, Ohio > 90 SP36 > > [Non-text portions of this message have been removed] > > |
