Air pressure - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air pressure (/showthread.php?tid=5279) |
Air pressure - williamcharrison - 07-03-2007 05:17 I recently replaced the air governor on my 3208 engined BB because the old one let the pressure build to over 140psi as indicated on the dash gauge. The new one has an adjustment range of 105-120psi but the air pressure still builds to an indicated 145psi. is there something else that could cause this problem? (I checked to make sure that the exhaust port was free). Chuck Harrison Akron, Ohio 90 SP36 Air pressure - Wilhelmus Schreurs - 07-03-2007 05:35 William: Is your air pressure gauge accurate? Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 3, 2007 10:17:17 AM Subject: [WanderlodgeForum] Air pressure I recently replaced the air governor on my 3208 engined BB because the old one let the pressure build to over 140psi as indicated on the dash gauge. The new one has an adjustment range of 105-120psi but the air pressure still builds to an indicated 145psi. is there something else that could cause this problem? (I checked to make sure that the exhaust port was free). Chuck Harrison Akron, Ohio 90 SP36 Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com [Non-text portions of this message have been removed] Air pressure - Ray - 01-19-2011 06:59 Hey Guys, I have been a silent observer on here for over a year. I read every post that comes out and appreciat all the insight. It has been an immense help for me. Whoever started this ought to receive a peace prize or something comparable.Recently, there was a discussion about air pressure. It prompted me to run a little test by turning my auxiliary compressor on and airing up my system. I wanted to check and see if any obvious leaks had developed since I've been sitting for 4 months. My gauge on the dash is at about 70 for both the green and the red needle after a week. However, it created a small issue for me in that my front step came in while I was ruining the compressor. It didn't come all the way in, it just hangs in limbo. It won't stay in and won't stay out. I can easily push it in and out with my hand. I tried the step extend switch and it has no effect. It's a bit dangerous climbing in and out of this thing on a swinging step... Help if you can... Thanks Ray and Denise 92 Wanderlodge Redding CA For A While Air pressure - David - 01-19-2011 07:42 Ray, I would start the coach, air up the system and see if the step will extend and retract. My step will extend when the system air pressure starts to drop off. Use the step override switch to keep it extended while parked. David Hanvy 89WB in TX --- In WanderlodgeForum@yahoogroups.com, "Ray" > > Hey Guys, > I have been a silent observer on here for over a year. I read every post that comes out and appreciat all the insight. It has been an immense help for me. Whoever started this ought to receive a peace prize or something comparable.Recently, there was a discussion about air pressure. It prompted me to run a little test by turning my auxiliary compressor on and airing up my system. I wanted to check and see if any obvious leaks had developed since I've been sitting for 4 months. My gauge on the dash is at about 70 for both the green and the red needle after a week. However, it created a small issue for me in that my front step came in while I was ruining the compressor. It didn't come all the way in, it just hangs in limbo. It won't stay in and won't stay out. I can easily push it in and out with my hand. I tried the step extend switch and it has no effect. It's a bit dangerous climbing in and out of this thing on a swinging step... Help if you can... Thanks > > Ray and Denise > 92 Wanderlodge > Redding CA > For A While > Air pressure - ronmarabito2002 - 01-19-2011 08:33 Ray: First of all, you should get more than 70 psi. You either have a leak or your governor is not working correctly. Try kicking the step when the air is at its highest point. If it then either retracts or extends, that is a good indication that your leak was at the step. There are a couple of air pressure regulation valves that frequently go bad. One is in the rear next to your schraeder valve in the engine compartment assuming you have a pusher. If its leaking you will sure know it. The other is used to regulate the tag axle pressure and it is on the cross member above the rear axle. Hope that helps. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Ray" > > Hey Guys, > I have been a silent observer on here for over a year. I read every post that comes out and appreciat all the insight. It has been an immense help for me. Whoever started this ought to receive a peace prize or something comparable.Recently, there was a discussion about air pressure. It prompted me to run a little test by turning my auxiliary compressor on and airing up my system. I wanted to check and see if any obvious leaks had developed since I've been sitting for 4 months. My gauge on the dash is at about 70 for both the green and the red needle after a week. However, it created a small issue for me in that my front step came in while I was ruining the compressor. It didn't come all the way in, it just hangs in limbo. It won't stay in and won't stay out. I can easily push it in and out with my hand. I tried the step extend switch and it has no effect. It's a bit dangerous climbing in and out of this thing on a swinging step... Help if you can... Thanks > > Ray and Denise > 92 Wanderlodge > Redding CA > For A While > Air pressure - GARY MINKER - 01-19-2011 23:31
