Round TV Turner - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Round TV Turner (/showthread.php?tid=5294) |
Round TV Turner - Al - 07-04-2007 13:26 Stephen, I finally got around to replaceing my dish I purchased from you at the RATS Rally. Do I also need to replace the electonics inside the bird or only the outside dish? I have tested the new dish with old electronics and appears to work fine. Will I loose some features by not replacing the inside electronics? Al Johnson '96 BMC B100 Mandeville, Louisiana Round TV Turner - Stephen Birtles - 07-04-2007 14:28 No you can use the same electronics. if you do not already have one you can run wire to the bedroom and wire in the additional remote you now have using the screw terminal reading left to right then bottom row left to right use five cable control cable or door bell cable or telephonecable 1.yellow 2.black 3 white 4 brown 5 red Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Al" > > Stephen, > I finally got around to replaceing my dish I purchased from you at > the RATS Rally. Do I also need to replace the electonics inside the > bird or only the outside dish? I have tested the new dish with old > electronics and appears to work fine. Will I loose some features by > not replacing the inside electronics? > > Al Johnson > '96 BMC B100 > Mandeville, Louisiana > |
