Air leak finally solved! - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air leak finally solved! (/showthread.php?tid=5296) |
Air leak finally solved! - Chuck Wheeler - 07-04-2007 16:19 Sunday before Kathy broke her wrist I was servicing the AD2. I had purchased a new cartridge and purge valve kit. The parts counter person recommended that I also replace the integral check valve that is on the output of the AD2. I had everything together and was making an air test when Kathy had her accident. I shut down and took her to emergency. That was Sunday. Today, Wednesday, I went out to the bird and when I opened the door the step actuated! I tried the steering and seat locks and they also worked. BIG improvement. Up until now about five hours was as long as the auxiliary air would stay up. The whole rebuild took about 2.5 hours although I got pretty dirty. I had rebuilt the AD2 before but never replace the check valve. Just for information. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX [Non-text portions of this message have been removed] Air leak finally solved! - davidkerryedwards - 07-05-2007 01:54 On a similar note. I just installed a Rostra electric cruise control. I removed and plugged the fitting where the vacuum generator was installed in the air system. Air now holds for at least 7 days whereas prior to this work, it would hold about 18 hrs. Vacuum generator must have been leaking. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Sunday before Kathy broke her wrist I was servicing the AD2. I had > purchased a new cartridge and purge valve kit. The parts counter person > recommended that I also replace the integral check valve that is on the > output of the AD2. I had everything together and was making an air test > when Kathy had her accident. I shut down and took her to emergency. That > was Sunday. Today, Wednesday, I went out to the bird and when I opened the > door the step actuated! I tried the steering and seat locks and they also > worked. BIG improvement. Up until now about five hours was as long as the > auxiliary air would stay up. The whole rebuild took about 2.5 hours > although I got pretty dirty. I had rebuilt the AD2 before but never replace > the check valve. > > > > Just for information. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > > > > [Non-text portions of this message have been removed] > |
