Air Compressor Maintenance - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Compressor Maintenance (/showthread.php?tid=5311) |
Air Compressor Maintenance - Alan - 07-07-2007 02:31 Is there scheduled maintenance that should occur with the air compressor on my 87FC35? This has probably been addressed somewhere in here, but I looked and couldn't find it. I'm not sure how the compressor is lubricated, and therefore wonder if there is some lubricant that needs to be changed. Also is there a filter? I check for water in the tanks occasionally, but there is never any in them. Thanks, Alan Johnson 87FC35 Air Compressor Maintenance - pattypape - 07-07-2007 02:54 Alan, The intake air filter / strainer needs replaced or cleaned. Do not be surprised if the foam filter in missing, they break down and disintegrate. I replaced with a small paper disposible mini air filter, available at truck parts stores or NAPA. It is very difficult to service from the doghouse, , That is the reason for the disposable replacement , it can be replaced from the doghouse. Try the link for information, It is in the files section. You will need to cut and paste, see pages 3 & 4. http://f1.grp.yahoofs.com/v1/YJyPRq- Q6t8jD6zu0tyFOvudywMIwBxht3uTlTjabPcqLlGfNp49QX56ZDUkZrHwrkYlQdlH-g- saExrQAQ5q8YxA-TCKaSb/AirCompressor.pdf Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Is there scheduled maintenance that should occur with the air > compressor on my 87FC35? > > This has probably been addressed somewhere in here, but I looked and > couldn't find it. I'm not sure how the compressor is lubricated, and > therefore wonder if there is some lubricant that needs to be changed. > Also is there a filter? > > I check for water in the tanks occasionally, but there is never any in > them. > > Thanks, > Alan Johnson > 87FC35 > Air Compressor Maintenance - putneyflash@...> - 07-07-2007 14:39 The compressor is lubeb by engine oil > > From: "Alan" > Date: 2007/07/07 Sat AM 10:31:12 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Air Compressor Maintenance > > Is there scheduled maintenance that should occur with the air > compressor on my 87FC35? > > This has probably been addressed somewhere in here, but I looked and > couldn't find it. I'm not sure how the compressor is lubricated, and > therefore wonder if there is some lubricant that needs to be changed. > Also is there a filter? > > I check for water in the tanks occasionally, but there is never any in > them. > > Thanks, > Alan Johnson > 87FC35 > > > Air Compressor Maintenance - M Thomas Eastham - 07-08-2007 03:32 There's a gasket between the air compressor and the engine. It went out on my FC a few months ago and we dumped 8 quarts of engine oil in less than 20 miles. The fix was cheap - new gasket - but a little hard to get to. Always watch your oil pressure gauge.... :-) 83' FC35 SB 84' FC33 SB parting Houston, TX Thomas Eastham 713-851-9693 thomase@... [Non-text portions of this message have been removed] |
