inverter/charger - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: inverter/charger (/showthread.php?tid=5325) |
inverter/charger - skaggsmarvin - 07-10-2007 05:43 Sunelec_miami has a Prosine 3.0 refurb inverter/charger for sale on e- bay $1200. Would this be a good choice for a PT40? If so how much of a job to install? thanks, marvin 1984 PT40 inverter/charger - Jay Darst - 07-10-2007 13:44 Marvin that sounds like a fairly good deal on that Inverter. If you install it correctly, it will be a fair size job. I too, have an 85 PT40. I mounted the inverter in the Redi-Line compartment, on the top shelf. The 120V wiring is encased in conduit which passes thru the top of the inverter compartment, thru the floor to the area under the base trim in the bedroom at the foot of the bed (cross queen). The 120V wires continue forward to the factory distribution panel and to add'l circuit breaker panel where All loads that can be powered by the inverter are now located. Also, use 4/0 Marine grade cables for the 12V side of the installation. Use a Link2000R controller as you may soon upgrade the alternator to 320amp. Thus you will run 1 roof top a/c from the inverter/alternator setup. A bit of a job, but well worth it in my opinion... Jay Darst 85PT40 1996 Prevost Country Coach 45XL Springfield/Sullivan, IL --- In WanderlodgeForum@yahoogroups.com, "skaggsmarvin" > > Sunelec_miami has a Prosine 3.0 refurb inverter/charger for sale on e- > bay $1200. > > Would this be a good choice for a PT40? > > If so how much of a job to install? > thanks, marvin > 1984 PT40 > |
