Low Air Alarm - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Low Air Alarm (/showthread.php?tid=533) |
Low Air Alarm - glenn_shehorn - 05-07-2005 07:28 After finding my air leak and replacing air regulator(?), after a few minutes I am up to 120-125 PSI on front and rear guages. Front one is slower. Now a few months later I am getting a low air alarm and dash light. Can anyone tell me where the sensor is or any other pertinent info on the issue. Glenn Shehorn 83FCRb Kansas City Mo (Tornado Alley) Low Air Alarm - Gary Miller - 05-07-2005 08:00 Hi Glenn, The 66psi sensor is located in the area aft of the curbside air tank. If you can locate the schraeder valve fitting, follow the plumbing to a cross shaped junction. One of the pipes from this junction should lead you right to the sender, one pipe comes from the pump, and one goes to a 'T' then to each front tank. Part #'s, BB 1145853, vendor B-W #104246. Orange wire for the buzzer and light, not associated with the direct pressure reading of each gauge. Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn" > After finding my air leak and replacing air regulator(?), after a few > minutes I am up to 120-125 PSI on front and rear guages. Front one is > slower. Now a few months later I am getting a low air alarm and dash > light. Can anyone tell me where the sensor is or any other pertinent > info on the issue. > > Glenn Shehorn > 83FCRb > Kansas City Mo (Tornado Alley) Low Air Alarm - randydupree - 05-07-2005 10:52 the low air alarm sending unit is located just to the front of the entry door,slide under the coach,look up,you will see an air tank ,on the top of this tank is the sendor,on one end,screwed into a tee or some other fitting.randydupree93wb ----- Original Message ----- From: glenn_shehorn To: WanderlodgeForum@yahoogroups.com Sent: Saturday, May 07, 2005 3:28 PM Subject: [WanderlodgeForum] Low Air Alarm After finding my air leak and replacing air regulator(?), after a few minutes I am up to 120-125 PSI on front and rear guages. Front one is slower. Now a few months later I am getting a low air alarm and dash light. Can anyone tell me where the sensor is or any other pertinent info on the issue. Glenn Shehorn 83FCRb Kansas City Mo (Tornado Alley) ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
