Vipwheels - New replacement Steering Wheel - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Vipwheels - New replacement Steering Wheel (/showthread.php?tid=534) |
Vipwheels - New replacement Steering Wheel - judy2gene - 05-07-2005 08:10 Good Afternoon , Emailed Vipwheels about a replacement wheel and costs. Charlene requested the diameter, spline count, and part number. I can get the diameter and spline count if I can get the wheel off, my question is how ? The wheel is loose both (right & left), plus telescoping (up & down). Is that ok/normal to have about 2 to 4 inches of play in its motion ? Part # ? Thanks, Gene Judy & Gene Sharp 93' WL40' Ohio Vipwheels - New replacement Steering Wheel - drdigger@...> - 05-07-2005 08:43 On my 83 FC the horn button pops off with a little nudge from a flat headed screwdriver (It's a switch, not a contact ring like a car, and has a wire attached). Look down into the hole and there is about a 1 1/8" nut. remove the nut and the wheel should come off with the proper wheel puller. Keep us posted, I also need to replace my steering wheel with a smaller unit. Something about that Law Of Physics that states My belly and the steering wheel cannot occupy the same space at the same time. Good Luck Glenn Shehorn 83 FC 35 KCMO ----- Original Message ----- From: judy2gene To: WanderlodgeForum@yahoogroups.com Sent: Saturday, May 07, 2005 3:10 PM Subject: [WanderlodgeForum] Vipwheels - New replacement Steering Wheel Good Afternoon , Emailed Vipwheels about a replacement wheel and costs. Charlene requested the diameter, spline count, and part number. I can get the diameter and spline count if I can get the wheel off, my question is how ? The wheel is loose both (right & left), plus telescoping (up & down). Is that ok/normal to have about 2 to 4 inches of play in its motion ? Part # ? Thanks, Gene Judy & Gene Sharp 93' WL40' Ohio ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Vipwheels - New replacement Steering Wheel - Stephen Birtles - 05-07-2005 09:03 You will probably find you want a BB1 center on your steeing wheel Stephen Cape0001 77fc35 http://www.capeinnovation.com --- In WanderlodgeForum@yahoogroups.com, "judy2gene" wrote: > Good Afternoon , > Emailed Vipwheels about a replacement wheel and costs. > Charlene requested the diameter, spline count, and part > number. I can get the diameter and spline count if I > can get the wheel off, my question is how ? The wheel is > loose both (right & left), plus telescoping (up & down). > Is that ok/normal to have about 2 to 4 inches of play > in its motion ? Part # ? > Thanks, > Gene > > Judy & Gene Sharp > 93' WL40' Ohio Vipwheels - New replacement Steering Wheel - judy2gene - 05-08-2005 06:43 Hello Again, Forgot to say THANKS Jeff Miller for the steering wheel supplier - vipwheels. Thanks also for the solutions. Gene Judy & Gene 93' WL40' Ohio --- In WanderlodgeForum@yahoogroups.com, "judy2gene" wrote: > Good Afternoon , > Emailed Vipwheels about a replacement wheel and costs. > Charlene requested the diameter, spline count, and part > number. I can get the diameter and spline count if I > can get the wheel off, my question is how ? The wheel is > loose both (right & left), plus telescoping (up & down). > Is that ok/normal to have about 2 to 4 inches of play > in its motion ? Part # ? > Thanks, > Gene > > Judy & Gene Sharp > 93' WL40' Ohio |
