Leveler Hydraulic Line - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Leveler Hydraulic Line (/showthread.php?tid=5353) |
Leveler Hydraulic Line - Scott Forman - 07-14-2007 06:22 The line that runs to my left front jack has a leak. I am having trouble determining where the end of this line is, not the jack end, the other end. I am trying to figure out if this is something I am likely to be able to change out myself. Does anyone know how these lines run or have a diagram? Scott Forman 86 PT38 Memphis Leveler Hydraulic Line - Ralph L. Fullenwider - 07-14-2007 06:31 Scott: Those lines run directly from the jack to the control valves. They should be routed along the frame then into the drives side front compartment area. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 06:22 PM 7/14/2007 +0000, you wrote: >The line that runs to my left front jack has a leak. I am having >trouble determining where the end of this line is, not the jack end, >the other end. I am trying to figure out if this is something I am >likely to be able to change out myself. Does anyone know how these >lines run or have a diagram? > >Scott Forman >86 PT38 >Memphis > > Leveler Hydraulic Line - Scott Forman - 07-14-2007 08:31 My control valves are located behind the step well as I have the electronic system. I was curious as to whether each line was continuous from vavle to jack or if there were are T's or other couplings in there. Scott --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Scott: > > Those lines run directly from the jack to the control valves. They should > be routed along the frame then into the drives side front compartment area. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 06:22 PM 7/14/2007 +0000, you wrote: > >The line that runs to my left front jack has a leak. I am having > >trouble determining where the end of this line is, not the jack end, > >the other end. I am trying to figure out if this is something I am > >likely to be able to change out myself. Does anyone know how these > >lines run or have a diagram? > > > >Scott Forman > >86 PT38 > >Memphis > > > > > Leveler Hydraulic Line - Ralph L. Fullenwider - 07-14-2007 08:43 Scott: All BB Coaches I have worked on have been continuous lines from jacks to the control valves. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 08:31 PM 7/14/2007 +0000, you wrote: >My control valves are located behind the step well as I have the >electronic system. I was curious as to whether each line was >continuous from vavle to jack or if there were are T's or other >couplings in there. > >Scott > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Scott: > > > > Those lines run directly from the jack to the control valves. They >should > > be routed along the frame then into the drives side front >compartment area. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Duncan, Oklahoma > > > > At 06:22 PM 7/14/2007 +0000, you wrote: > > >The line that runs to my left front jack has a leak. I am having > > >trouble determining where the end of this line is, not the jack >end, > > >the other end. I am trying to figure out if this is something I am > > >likely to be able to change out myself. Does anyone know how these > > >lines run or have a diagram? > > > > > >Scott Forman > > >86 PT38 > > >Memphis > > > > > > > > > Leveler Hydraulic Line - bloomas - 07-14-2007 09:29 ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 14, 2007 3:43 PM Subject: Re: [WanderlodgeForum] Re: Leveler Hydraulic Line That true Ralph except where people like me have used inline splices. Bob Loomas 1985 PT 36 Scott: All BB Coaches I have worked on have been continuous lines from jacks to the control valves. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 08:31 PM 7/14/2007 +0000, you wrote: >My control valves are located behind the step well as I have the >electronic system. I was curious as to whether each line was >continuous from vavle to jack or if there were are T's or other >couplings in there. > >Scott > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Scott: > > > > Those lines run directly from the jack to the control valves. They >should > > be routed along the frame then into the drives side front >compartment area. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Duncan, Oklahoma > > > > At 06:22 PM 7/14/2007 +0000, you wrote: > > >The line that runs to my left front jack has a leak. I am having > > >trouble determining where the end of this line is, not the jack >end, > > >the other end. I am trying to figure out if this is something I am > > >likely to be able to change out myself. Does anyone know how these > > >lines run or have a diagram? > > > > > >Scott Forman > > >86 PT38 > > >Memphis > > > > > > > > > [Non-text portions of this message have been removed] Leveler Hydraulic Line - Scott Forman - 07-15-2007 08:30 Bob...these splices...how do they work and where do they come from? Scott --- In WanderlodgeForum@yahoogroups.com, "bloomas" wrote: > > > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, July 14, 2007 3:43 PM > Subject: Re: [WanderlodgeForum] Re: Leveler Hydraulic Line > That true Ralph except where people like me have used inline splices. > Bob Loomas 1985 PT 36 > > > Scott: > > All BB Coaches I have worked on have been continuous lines from jacks to > the control valves. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 08:31 PM 7/14/2007 +0000, you wrote: > >My control valves are located behind the step well as I have the > >electronic system. I was curious as to whether each line was > >continuous from vavle to jack or if there were are T's or other > >couplings in there. > > > >Scott > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > Scott: > > > > > > Those lines run directly from the jack to the control valves. They > >should > > > be routed along the frame then into the drives side front > >compartment area. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 > > > Duncan, Oklahoma > > > > > > At 06:22 PM 7/14/2007 +0000, you wrote: > > > >The line that runs to my left front jack has a leak. I am having > > > >trouble determining where the end of this line is, not the jack > >end, > > > >the other end. I am trying to figure out if this is something I am > > > >likely to be able to change out myself. Does anyone know how these > > > >lines run or have a diagram? > > > > > > > >Scott Forman > > > >86 PT38 > > > >Memphis > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > Leveler Hydraulic Line - robertnloomas - 07-15-2007 11:33 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: Scott i get the fittings from aeroquip. Blue bird use aeroequip for the Hydraulic Line. Bob Loomas 1985 PT 36 http://www.aeroquip.com > > Bob...these splices...how do they work and where do they come from? > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "bloomas" > wrote: > > > > > > ----- Original Message ----- > > From: Ralph L. Fullenwider > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, July 14, 2007 3:43 PM > > Subject: Re: [WanderlodgeForum] Re: Leveler Hydraulic Line > > That true Ralph except where people like me have used inline > splices. > > Bob Loomas 1985 PT 36 > > > > > > Scott: > > > > All BB Coaches I have worked on have been continuous lines from > jacks to > > the control valves. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Duncan, Oklahoma > > > > At 08:31 PM 7/14/2007 +0000, you wrote: > > >My control valves are located behind the step well as I have the > > >electronic system. I was curious as to whether each line was > > >continuous from vavle to jack or if there were are T's or other > > >couplings in there. > > > > > >Scott > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > Scott: > > > > > > > > Those lines run directly from the jack to the control valves. > They > > >should > > > > be routed along the frame then into the drives side front > > >compartment area. > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > 84FC35 > > > > Duncan, Oklahoma > > > > > > > > At 06:22 PM 7/14/2007 +0000, you wrote: > > > > >The line that runs to my left front jack has a leak. I am > having > > > > >trouble determining where the end of this line is, not the > jack > > >end, > > > > >the other end. I am trying to figure out if this is > something I am > > > > >likely to be able to change out myself. Does anyone know how > these > > > > >lines run or have a diagram? > > > > > > > > > >Scott Forman > > > > >86 PT38 > > > > >Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
