Corian tabletop - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Corian tabletop (/showthread.php?tid=5364) |
Corian tabletop - williamcharrison - 07-16-2007 04:34 My corian tabletop mysteriously developed 2 sharp edged cracks while I was parked with the levelers down. I realize that it should be replaced by a professional but I wonder if anything I did contributed to the cracking. Also, what should I expect to pay for the job? Chuck Harrison Akron, Ohio 90SP36 Corian tabletop - David Brady - 07-16-2007 04:44 I've been warned about putting very hot items on corian; i.e., pots and pans - always use a trivet of some sort. Is it possible that heat caused the cracks? David Brady '02 LXi, Smokey NC williamcharrison wrote: > > My corian tabletop mysteriously developed 2 sharp edged cracks while > I was parked with the levelers down. I realize that it should be > replaced by a professional but I wonder if anything I did contributed > to the cracking. Also, what should I expect to pay for the job? > > Chuck Harrison > Akron, Ohio > 90SP36 > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.6/902 - Release Date: 7/15/2007 2:21 PM > [Non-text portions of this message have been removed] Corian tabletop - g_man1146 - 07-16-2007 04:56 Chuck, Corian can, in many cases, be repaired invisibly. During the early 90's BB used some 1/4" Corian glued to plywood. While the two materials expand and contract about the same with changes in temperature, the best bet is to use 1/2" Corian over support strips. If your table top can be unscrewed from underneath, I would take it to a kitchen design/installation dealer that specializes in Corian. They can probably repair it to good as new condition. Cost of repair will be much less than a new one which will also vary greatly depending on how the edge was/is styled and built. Rich D. '99LXi43' CT ('90PT40' ![]() --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > I've been warned about putting very hot items on corian; i.e., > pots and pans - always use a trivet of some sort. Is it possible > that heat caused the cracks? > > David Brady > '02 LXi, Smokey > NC > > williamcharrison wrote: > > > > My corian tabletop mysteriously developed 2 sharp edged cracks while > > I was parked with the levelers down. I realize that it should be > > replaced by a professional but I wonder if anything I did contributed > > to the cracking. Also, what should I expect to pay for the job? > > > > Chuck Harrison > > Akron, Ohio > > 90SP36 > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.6/902 - Release Date: 7/15/2007 2:21 PM > > > > > > [Non-text portions of this message have been removed] > Corian tabletop - williamcharrison - 07-30-2007 03:34 Anyone have any experience with cracking of the corian on the dining room table? Mine has cracked in two places and I was told by the local table and counter shop that it can't be repaired because part of it has lifted (with razor sharp edges). Chuck harrison Akron, Ohio 90SP36 Corian tabletop - Ed Gardels - 07-30-2007 05:41 --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" >Chuck-- on my 89, I havent had it crack. It is very heavy.My sp36 dining table was not convertable to a bed, so I did a conversion my self.I was worried about it cracking when laid down between seats so I use a step stool under it just in case. Now I have my sofa and table for sleepers. Does yours convert to a bed? > Anyone have any experience with cracking of the corian on the dining > room table? Mine has cracked in two places and I was told by the local > table and counter shop that it can't be repaired because part of it has > lifted (with razor sharp edges). > > Chuck harrison > Akron, Ohio > 90SP36 > Corian tabletop - williamcharrison - 07-31-2007 01:14 Hi Ed, No, it does not convert to a bed. -- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > >Chuck-- on my 89, I havent had it crack. It is very heavy.My sp36 > dining table was not convertable to a bed, so I did a conversion my > self.I was worried about it cracking when laid down between seats so I > use a step stool under it just in case. Now I have my sofa and table > for sleepers. Does yours convert to a bed? > > Anyone have any experience with cracking of the corian on the dining > > room table? Mine has cracked in two places and I was told by the > local > > table and counter shop that it can't be repaired because part of it > has > > lifted (with razor sharp edges). > > > > Chuck harrison > > Akron, Ohio > > 90SP36 > > > Corian tabletop - RTJ49@... - 08-05-2007 04:30 Hi Chuck, What color is the top. Let me know. I may have the color you need in my shop. We are certified Corian fabricators and installers. Raymond Jordan Foretravel Maryland ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] Corian tabletop - Leroy Eckert - 08-05-2007 08:08 Been gone to California for a week or so. I did not see a response to you question. Corian will not crack unless it is unstable and moving around. The only repair is a new one and figure out why the original broke. Leroy Eckert 1990 WB-40"Smoke N Mirrors Niceville, FL Love that Texas Hill Country around the Comfort area. ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 30, 2007 10:34 AM Subject: [WanderlodgeForum] Corian tabletop Anyone have any experience with cracking of the corian on the dining room table? Mine has cracked in two places and I was told by the local table and counter shop that it can't be repaired because part of it has lifted (with razor sharp edges). Chuck harrison Akron, Ohio 90SP36 [Non-text portions of this message have been removed] Corian tabletop - williamcharrison - 08-06-2007 01:56 It is an off-white, if I had to guess I would say bone. --- In WanderlodgeForum@yahoogroups.com, RTJ49@... wrote: > > Hi Chuck, > What color is the top. Let me know. I may have the color you need in my > shop. We are certified Corian fabricators and installers. > > Raymond Jordan > Foretravel > Maryland > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > Corian tabletop - williamcharrison - 08-25-2007 09:25 I never got a reply from you. I am a terrible judge of color but I know it is off white. Chuck harrison Akron, Ohio 90WLSP36 --- In WanderlodgeForum@yahoogroups.com, RTJ49@... wrote: > > Hi Chuck, > What color is the top. Let me know. I may have the color you need in my > shop. We are certified Corian fabricators and installers. > > Raymond Jordan > Foretravel > Maryland > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > |
