How do you remove the upper dash panel? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How do you remove the upper dash panel? (/showthread.php?tid=5380) |
How do you remove the upper dash panel? - erniecarpet@... - 07-18-2007 21:12 John, the previous owner of my coach painted the old brown vinyl. Sure made a difference in the looks of my coach. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] How do you remove the upper dash panel? - erniecarpet@... - 07-18-2007 21:29 The paint used on my coach was BASF acrylic laquer. and on the side of the can it says Topcoat. It has lasted well and I have had the coach around 5 years. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] How do you remove the upper dash panel? - bubblerboy64 - 07-19-2007 01:00 I am not certain what you would correctly call the piece I want to remove. Its front panel at head level above the windshield, above the panel that contains the radio and heater controls. I looked around and the screws holding this piece in place are behind the elbow shaped ends of the side compartments. If I could get the ends of the side compartments off I believe the front panel would be easy. For the life of me I see no way to get those small elbow shaped panels loose. Gotta be a way. My goal is to cover the old black panels at the front of the bus with some light colored vinyl or leather. Wouldn't think this too difficult once removed. Appreciate the help. John Heckman Central Pa 1973 FC How do you remove the upper dash panel? - bubblerboy64 - 07-19-2007 01:18 Well, painting would be easier in that I would not have to necessarily remove anything to do so but what type of paint would be used? I would have assumed that being somewhat soft and flexible paint wouldn't stick. Jeh > > John, the previous owner of my coach painted the old brown vinyl. Sure made > a difference in the looks of my coach. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > How do you remove the upper dash panel? - Harold Prescott - 07-19-2007 01:51 --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > I am not certain what you would correctly call the piece I want to > remove. Its front panel at head level above the windshield, above > the panel that contains the radio and heater controls. I looked > around and the screws holding this piece in place are behind the > elbow shaped ends of the side compartments. If I could get the ends > of the side compartments off I believe the front panel would be > easy. For the life of me I see no way to get those small elbow > shaped panels loose. Gotta be a way. My goal is to cover the old > black panels at the front of the bus with some light colored vinyl or > leather. Wouldn't think this too difficult once removed. Appreciate > the help. > John Heckman > Central Pa > 1973 FC > John, If you are talking about removing the small triangle pieces at the front end of the side cabnets..... Then you must first start inside the front of these cabnets. There is a piece of 1/2" plywood in the front. This piece needs to come out before you can access the screws holding those upholstered triangle picees. Hope this helps, Harold Prescott '85 FC35 Northern California How do you remove the upper dash panel? - Doug Engel - 07-19-2007 02:00 John, If they are currently covered in vinyl, like Pokeys were, I'd use Mar-Hyde vinly paint, I think it is a Duplicolor product. It's a aerosol can product that's easy to apply, comes in lots of colors. Good Luck, Doug bubblerboy64 I am not certain what you would correctly call the piece I want to remove. Its front panel at head level above the windshield, above the panel that contains the radio and heater controls. I looked around and the screws holding this piece in place are behind the elbow shaped ends of the side compartments. If I could get the ends of the side compartments off I believe the front panel would be easy. For the life of me I see no way to get those small elbow shaped panels loose. Gotta be a way. My goal is to cover the old black panels at the front of the bus with some light colored vinyl or leather. Wouldn't think this too difficult once removed. Appreciate the help. John Heckman Central Pa 1973 FC Doug Engel, Gunnison, CO. Bird Usta Be, now 1990 Thomas Skoolie, "Hormone Derange" --------------------------------- Get the Yahoo! toolbar and be alerted to new email wherever you're surfing. [Non-text portions of this message have been removed] How do you remove the upper dash panel? - bubblerboy64 - 07-20-2007 04:25 Well, I painted it and you know that was the biggest improvement I've made to date for the interior. Took some time to tape off but it really turned out great. You know that vinyl material there is just no tape that will stick to it. I finally used duck tape and even that didn't work real well. I find that interesting. Maybe 70's vinyl and 2007 vinyl just don't work together. John Heckman Central Pa 1973 FC > > I am not certain what you would correctly call the piece I want to > remove. Its front panel at head level above the windshield, above > the panel that contains the radio and heater controls. I looked > around and the screws holding this piece in place are behind the > elbow shaped ends of the side compartments. If I could get the ends > of the side compartments off I believe the front panel would be > easy. For the life of me I see no way to get those small elbow > shaped panels loose. Gotta be a way. My goal is to cover the old > black panels at the front of the bus with some light colored vinyl or > leather. Wouldn't think this too difficult once removed. Appreciate > the help. > John Heckman > Central Pa > 1973 FC > How do you remove the upper dash panel? - bubblerboy64 - 07-20-2007 04:25 Well, I painted it and you know that was the biggest improvement I've made to date for the interior. Took some time to tape off but it really turned out great. You know that vinyl material there is just no tape that will stick to it. I finally used duck tape and even that didn't work real well. I find that interesting. Maybe 70's vinyl and 2007 vinyl just don't work together. John Heckman Central Pa 1973 FC > > I am not certain what you would correctly call the piece I want to > remove. Its front panel at head level above the windshield, above > the panel that contains the radio and heater controls. I looked > around and the screws holding this piece in place are behind the > elbow shaped ends of the side compartments. If I could get the ends > of the side compartments off I believe the front panel would be > easy. For the life of me I see no way to get those small elbow > shaped panels loose. Gotta be a way. My goal is to cover the old > black panels at the front of the bus with some light colored vinyl or > leather. Wouldn't think this too difficult once removed. Appreciate > the help. > John Heckman > Central Pa > 1973 FC > |
