Bosch buzz - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Bosch buzz (/showthread.php?tid=5487) |
Bosch buzz - Alan - 08-08-2007 11:09 Can anyone tell me what would make a bosch relay buzz sometimes when it should be "turning off"? ...And it doesn't turn off. I've had a couple do that.. and new ones at that. Bosch buzz - pattypape - 08-08-2007 13:25 Alan, Occationally , A relay chatters, when shutting down the master DC disconnect. It is intermittent and I have not found a cure for this issue. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > Can anyone tell me what would make a bosch relay buzz sometimes when > it should be "turning off"? ...And it doesn't turn off. I've had a > couple do that.. and new ones at that. > Bosch buzz - Curt Sprenger - 08-08-2007 19:12 I replace a relay that chatters. My thought is the relay is getting weak from lots of use. Has worked so far...the new relay doesn't chatter. On 8/8/07, pattypape > > > Alan, > > Occationally , A relay chatters, when shutting down the master > DC disconnect. It is intermittent and I have not found a cure for > this issue. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > "Alan" > wrote: > > > > Can anyone tell me what would make a bosch relay buzz sometimes when > > it should be "turning off"? ...And it doesn't turn off. I've had a > > couple do that.. and new ones at that. > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] Bosch buzz - Wilhelmus Schreurs - 08-11-2007 16:18 Alan: There are a number of different kinds of relays - do you know if the relay you got has a capacitor across the coil. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Alan To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 8, 2007 4:09:35 PM Subject: [WanderlodgeForum] Bosch buzz Can anyone tell me what would make a bosch relay buzz sometimes when it should be "turning off"? ...And it doesn't turn off. I've had a couple do that.. and new ones at that. <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a { text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc { background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o {font-size:0;} .MsoNormal { margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> Get a sneak peak at messages with a handy reading pane with All new Yahoo! Mail: http://mrd.mail.yahoo.com/try_beta?.intl=ca [Non-text portions of this message have been removed] Bosch buzz - krminyl@... - 08-16-2007 13:33 Diodes (not a capacitor) are most often used across the coil to provide a path for current when the current path to the relay is interrupted (i.e. switched off, coil no longer energized). This allows the coil field to collapse without the voltage spike that would otherwise be generated. The diode protects switch or relay contacts and other circuits that may be sensitive to voltage spikes. Capacitors basically store electricity, diodes direct the current in just one direction (prevents "feedback"). FWIW.... Kevin McKeown Yorba Linda, CA 1986 38' PT (For sale) ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] Bosch buzz - Alan - 08-16-2007 14:13 Bill, I just got your message. I have the small black bosch/or bosch-like relays. i don't know if there is a capacitor across the coil or not. I could tear one apart and see if i needed to. What does the capacitor do? Thanks, Alan --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Alan: > There are a number of different kinds of relays - do you know if the relay you got has a capacitor across the coil. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > |
