air conditioner - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: air conditioner (/showthread.php?tid=552) |
air conditioner - Dan Saari - 05-08-2005 15:25 Can anyone tell me ...........If my chassie air needs to be re-charged and it says ester oil on the compressor.......Is it compatable for 134 refrigerant???? .....DAN SAARI 1992 WLWB 40ft. Depere, Wi air conditioner - Tom Warner - 05-08-2005 15:35 Ester oil can be used for either R12 or R134a but it normally is used in R134a charged systems. If you have the large red and blue knobs on the compressor fill ports you have R134a in it. you need to put a set of gauges on the compressor and check the pressures to tell if you need to add R134a. If the electric clutch is cycling off and on you still have some refrigerant in it. I converted mine over last fall just before leaving for warmer weather. Tom 1982 FC35 At 03:25 AM 5/9/2005 +0000, you wrote: >Can anyone tell me ...........If my chassie air needs to be re-charged >and it says ester oil on the compressor.......Is it compatable for 134 >refrigerant???? .....DAN SAARI > >1992 WLWB 40ft. >Depere, Wi |
