Hydraulic line to rear jack - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Hydraulic line to rear jack (/showthread.php?tid=5528) |
Hydraulic line to rear jack - John Mann - 08-17-2007 14:23 Well unfortunantely I broke the Hydraulic fitting on the end of the line that screws onto the top of the rear left HWH jack. How can that be fixed with a new fitting? hopefully the entire line up to the front doesn't have to be removed to have a new swival end put on. Thanks for some input! John Mann 1985 pt 40 Granbury Texas Hydraulic line to rear jack - bloomas - 08-17-2007 16:59 ----- Original Message ----- From: John Mann To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 17, 2007 9:23 PM Subject: [WanderlodgeForum] Hydraulic line to rear jack No you do not have to replace the hole line.take the old broken fitting to a aeroquip dealer.You may have to use a inline splice and add a little hose so it will be long enough.you can get the hose from aeroquip also. Bob Loomas 1985 PT 36 Well unfortunantely I broke the Hydraulic fitting on the end of the line that screws onto the top of the rear left HWH jack. How can that be fixed with a new fitting? hopefully the entire line up to the front doesn't have to be removed to have a new swival end put on. Thanks for some input! John Mann 1985 pt 40 Granbury Texas [Non-text portions of this message have been removed] Hydraulic line to rear jack - ejohna2000 - 08-18-2007 03:32 Take it to a shop that specializes in hoses. They have a portable machine and can put a new end on hose while it is still on the bird. Would not recommend a splice unless it is a high pressure repair. -- In WanderlodgeForum@yahoogroups.com, "John Mann" > > Well unfortunantely I broke the Hydraulic fitting on the end of the > line that screws onto the top of the rear left HWH jack. How can that > be fixed with a new fitting? hopefully the entire line up to the front > doesn't have to be removed to have a new swival end put on. Thanks > for some input! > > John Mann > 1985 pt 40 > Granbury Texas > Hydraulic line to rear jack - Bob Lawrence - 08-18-2007 12:52 When we got our bird 4 years ago, on the first trip, I read in our book that the 4 jacks had the capability to lift the bird...thought I would see if it was true....bird went up off ground on all tires, but since ground was not perfectly level, fell forward off the jacks...what a jolt!! Front jack folded back as they do, no problem. The back jacks have a small swivel built into the bolt holding them on, but right rear jack busted the hose. Went to my local truck shop (M&M), they pulled the hose off (only about 12 inches of it) and made a new one on the spot. Had them make me a spare just incase I go stupid again...cheap fix. Bob Lawrence 84 PT36 Tacoma, Wa. > Well unfortunantely I broke the Hydraulic fitting on the end of the > line that screws onto the top of the rear left HWH jack. How can that > be fixed with a new fitting? hopefully the entire line up to the front > doesn't have to be removed to have a new swival end put on. Thanks > for some input! > > John Mann > 1985 pt 40 > Granbury Texas > |
