one legged genny - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: one legged genny (/showthread.php?tid=5534) |
one legged genny - david brady - 08-19-2007 13:10 Anyone ever experience loss of a 115V leg on their generator? My leg 2 works fine, but my leg 1 is intermittent. Sometimes when I start the genny both legs have power, other times only leg 2 has power. I assume the generator has a separate coil and field winding for each leg. I suppose there could be a problem with one of the field windings or with the regulator that feeds current to the field windings. Could this be an issue with the brushes? I guess a call to Powertech is in order. Thanks, David Brady '02 LXi, NC one legged genny - brad barton - 08-20-2007 10:30 Are there separate grounds for the different legs? I keep hearing a lot of the phantom 12V problems come from bad grounds fixed on or near the bottom of the coach near moisture, mud and road spray? Just an idea. So far I've had no problem w/ that part of my coach. Best of luck.Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: dmb993@...: Mon, 20 Aug 2007 01:10:41 +0000Subject: [WanderlodgeForum] one legged genny Anyone ever experience loss of a 115V leg on their generator? My leg 2 works fine, but my leg 1 is intermittent. Sometimes when I start the genny both legs have power, other times only leg 2 has power. I assume the generator has a separate coil and field winding for each leg. I suppose there could be a problem with one of the field windings or with the regulator that feeds current to the field windings. Could this be an issue with the brushes? I guess a call to Powertech is in order.Thanks,David Brady'02 LXi, NC _________________________________________________________________ Messenger Café â open for fun 24/7. Hot games, cool activities served daily. Visit now. http://cafemessenger.com?ocid=TXT_TAGLM_AugWLtagline [Non-text portions of this message have been removed] one legged genny - Pete Masterson - 08-21-2007 04:04 I'm not sure exactly how the genset is wired. But 110 volt wiring has a 'neutral' that returns to the generator and a 'ground' that goes to a ground source. In home wiring systems, the neutral and ground are tied together, but they are not supposed to be tied together in an RV (to avoid energizing the frame and body of the coach in the case of a short or other defect). While 12v ground problems are legendary (and I've experienced one myself), 110v grounding problems are much less common. A poor connection with 12v and the circuit will go dead. A poor connection with 110v often continues to work, but generates a lot of heat at the point of the fault -- which might eventually cause a breaker to trip. 12v doesn't have the 'oomph' to cross a poor connection, usually 110v does if the connection wires are in close proximity -- e.g. a connection where the connector has simply worked loose yet the wire remains touching. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 20, 2007, at 4:30 PM, brad barton wrote: > > Are there separate grounds for the different legs? I keep hearing > a lot of the phantom 12V problems come from bad grounds fixed on or > near the bottom of the coach near moisture, mud and road spray? > Just an idea. So far I've had no problem w/ that part of my > coach. Best of luck.Brad Barton 00LXiDFW bbartonwx@... > <snip> |
