Air tanks 90SP36 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air tanks 90SP36 (/showthread.php?tid=5568) |
Air tanks 90SP36 - williamcharrison - 08-25-2007 09:20 Is there a rear air tank on the SP36 and if so, where is it? I found the 2 in front (with lots of water in them). Chuck Harrison Akron, Ohio 90WLSP36 Air tanks 90SP36 - dspithaler@... - 08-25-2007 10:37 Chuck There is two above the pass thru compartment in mine. I have an access plate in the ceiling of it. I don't know if they all have a plate that can be taken down to see the expello valves. I had to replace my valves. Don 89 SP 36' Butler, PA Is there a rear air tank on the SP36 and if so, where is it? I found the 2 in front (with lots of water in them). Chuck Harrison Akron, Ohio 90WLSP36 ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] Air tanks 90SP36 - williamcharrison - 08-27-2007 01:45 Hi Don, Are there 4 air tanks total? I found the 2 in front of and above the pass through. By the by, I will be at the 1980 campground near Mercer, Pa. this coming weekend. Chuck Harrison Akron, Ohio 90WLSP36 -- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > Chuck There is two above the pass thru compartment in mine. I have an > access plate in the ceiling of it. I don't know if they all have a plate that > can be taken down to see the expello valves. I had to replace my valves. > Don > 89 SP 36' > Butler, PA > > Is there a rear air tank on the SP36 and if so, where is it? > I found the 2 in front (with lots of water in them). > > Chuck Harrison > Akron, Ohio > 90WLSP36 > > > > > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > Air tanks 90SP36 - dspithaler@... - 08-27-2007 08:57 Chuck That's right 4 total. The two up front are the front & back air brakes & one of the ones over the pass thru is the wet tank. I think the other is for the accessory like the step the holding tanks among other things. I'm not sure where that park is. There was one south of Mercer that was a KOA & there was one east out of Mercer toward Grove City that was called the Plantation. That was 15 years ago they might have changed names. Don Hi Don, Are there 4 air tanks total? I found the 2 in front of and above the pass through. By the by, I will be at the 1980 campground near Mercer, Pa. this coming weekend. Chuck Harrison Akron, Ohio 90WLSP36 ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
