Fuel SOLENOID Power comes through coolant temp switch? 3208T - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fuel SOLENOID Power comes through coolant temp switch? 3208T (/showthread.php?tid=5588) |
Fuel SOLENOID Power comes through coolant temp switch? 3208T - xz3kg7 - 08-28-2007 16:04 I need to get my terminology right. I said sender in an earlier post instead of solenoid. I've had a couple of random electrical problems and I'm trying to figure something out. The hot wire for my 87FC35 (3208T) fuel solenoid goes through what looks like a coolant temperature sender/switch on my block. If I'm under the dog house, the coolant "sender/switch" looking thing is about 6" northeast of the fuel solenoid itself. (It is screwed into the engine and when I loosen it antifreeze comes out.) I'm suspecting that this sender/switch is bad. Does it make sense that this would be wired this way? I presume if the engine overheats it opens a contact and quits sending power to the fuel solenoid, therefore shutting down the engine before it can be damaged?? Anybody know? Thanks, Alan Johnson 87FC35 Fuel SOLENOID Power comes through coolant temp switch? 3208T - xz3kg7 - 08-29-2007 14:18 Well, I'll answer my own post... and record it here for posterity. I called Wanderlodge and Jessie told me that yes, on my coach the power to the fuel solenoid does go through a water temperature switch. If the coolant gets to 210 degrees, it shuts off power to the fuel solenoid to prevent engine damage. ...That's a pretty cool feature. Ya'll have a great day, Alan 87FC35 --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" Fuel SOLENOID Power comes through coolant temp switch? 3208T - Scott Forman - 08-29-2007 15:36 Hmmm...not so sure how excited I would be about my engine suddenly going dead on the freeway, give me a good gauge/warning light that at least gives me time to move the coach to safety before shutting down... Scott Formn 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" wrote: > > Well, I'll answer my own post... and record it here for posterity. I > called Wanderlodge and Jessie told me that yes, on my coach the power > to the fuel solenoid does go through a water temperature switch. If > the coolant gets to 210 degrees, it shuts off power to the fuel > solenoid to prevent engine damage. ...That's a pretty cool feature. > > Ya'll have a great day, > Alan > 87FC35 > > --- In WanderlodgeForum@yahoogroups.com, "xz3kg7" Fuel SOLENOID Power comes through coolant temp switch? 3208T - putneyflash@...> - 08-30-2007 13:47 I am not saying it couldn't be, but if it shuts down how do you steer the coach?. you also would lose air if you were applying the brakes?I have only seen the solenoid wired thru temp or oil pressure gages on statonary engines. > > From: "xz3kg7" > Date: 2007/08/29 Wed AM 12:04:13 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Fuel SOLENOID Power comes through coolant temp switch? 3208T > > I need to get my terminology right. I said sender in an earlier post > instead of solenoid. > > I've had a couple of random electrical problems and I'm trying to > figure something out. > > The hot wire for my 87FC35 (3208T) fuel solenoid goes through what > looks like a coolant temperature sender/switch on my block. If I'm > under the dog house, the coolant "sender/switch" looking thing is > about 6" northeast of the fuel solenoid itself. (It is screwed into > the engine and when I loosen it antifreeze comes out.) > > I'm suspecting that this sender/switch is bad. > > Does it make sense that this would be wired this way? I presume if > the engine overheats it opens a contact and quits sending power to the > fuel solenoid, therefore shutting down the engine before it can be > damaged?? Anybody know? > > Thanks, > Alan Johnson > 87FC35 > > > > |
