What is the best tempeture to run a 3208 engine? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: What is the best tempeture to run a 3208 engine? (/showthread.php?tid=5596) |
What is the best tempeture to run a 3208 engine? - Jon - 08-30-2007 17:16 Just completed reading about Andy's trouble up in Reno and was wondering at what temperature should these old 3208'S run at? And I have just drove down to California from Washington and the average temperature outside during the day coming down I-5 in Redding were over 100 degrees. Could this possibly have cause part of his problems with this heat situation? Also is there anything that you can use in your coolant to lubricate the water pump? Oh yes one more thing, would you think when you are in really hot weather it would be better to run your machine at night to wherever your going? Jon Rebel Bird What is the best tempeture to run a 3208 engine? - Don Bradner - 08-30-2007 17:29 There is no question that a rig will run cooler on a 75 degree night than a 100 degree day, and that doesn't even count the solar radiation effects. Unfortunately for us, and I'm sure some others here, my night vision is a fraction of what it once was, and so I avoid driving at night unless I absolutely have to. The alternative is to slow down. Under any condition, slower speeds while keeping the revs up will be cooler than pedal-to-the-metal. I am not the slow sort by inclination, but I have a wife who will let me know if I'm being crazy ![]() Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 8/31/2007 at 5:16 AM Jon wrote: >Just completed reading about Andy's trouble up in Reno and was >wondering at what temperature should these old 3208'S run at? > >And I have just drove down to California from Washington and the >average temperature outside during the day coming down I-5 in Redding >were over 100 degrees. Could this possibly have cause part of his >problems with this heat situation? > >Also is there anything that you can use in your coolant to lubricate >the water pump? > >Oh yes one more thing, would you think when you are in really hot >weather it would be better to run your machine at night to wherever >your going? > >Jon >Rebel Bird What is the best tempeture to run a 3208 engine? - davidkerryedwards - 08-31-2007 02:09 On my 82 Fc 3208 NA with an aftermarket turbo, the electric fan clutch kicks in at about 195 degrees and immediately starts dropping the temperature. (I haven't installed the manual switch overrride yet but I will). When climbing grades in temperatures above the mid-90's the clutch almost always kicks in and reduces the temperature. If the temperature of the engine kept climbing, instead of dropping, I'd slow down or pull over and let it cool down for a while. This has never happened to me. I also think it is quite premature to conclude that Andy's problems were caused by high coolant temperatures when climbing grades in hot weather. I don't think anyone knows why the head gasket failed. It's possible that the head gasket failed first, causing higher coolant temperatures. It seems extremely unlikely to me that running a 3208 at 200 degrees, which is the temperature that Andy reported, would by itself cause headgasket failure. Headgaskets do fail, and a google shows reports of people replacing headgaskets on 3208s. I think there's an odd combination of events associated with Andy's problems that should be considered. He reported repeated problems with belts coming off earlier this year, then he had a fan clutch bearing failure,then he had a water pump failure, replaced it, then had the head gasket failure. Alll those items are associated with the cooling system. There's something odd going on. I'd want to try to figure out if these problems are related and perhaps have a common cause. He also said his coolant lines to the rest of the coach were disconnected. Is it possible that blocking those lines can cause inadequate coolant circulation or high pressure leading to the other problems? Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Just completed reading about Andy's trouble up in Reno and was > wondering at what temperature should these old 3208'S run at? > > And I have just drove down to California from Washington and the > average temperature outside during the day coming down I-5 in Redding > were over 100 degrees. Could this possibly have cause part of his > problems with this heat situation? > > Also is there anything that you can use in your coolant to lubricate > the water pump? > > Oh yes one more thing, would you think when you are in really hot > weather it would be better to run your machine at night to wherever > your going? > > Jon > Rebel Bird > What is the best tempeture to run a 3208 engine? - Gregory OConnor - 08-31-2007 02:58 Engine water temps are a result of friction of operation and the ability to cool. Any one factor in the equation will change the operation temp. To keep the water cool does not mean that you have reduced the engine stress. if you over build the cooling ability you lose the temp stress gauge. Engine oil temp is closer to a gauge of friction stress. but engine oil is effected also by water temp. When I make a hill climb. I always down shift and find a range where I can maintain a higher rpm but have the ability to move the bus faster by dumping more fuel. This tells me I am running the bus with less stress that the maximum engineered . It is quite possible to overheat an engine on a long down hill run with engine backpressure and over the limit rpm. I find a down hill comfort zone there I can relax knowing if the little 12 volt wire that is keeping my tranny in drive fails I can still use my brakes independent of any jake, driveline, exhaust, or trans relarder. Down hill is a chance for the fleetwoods to catch up. Its shamefull that he can return tuesday to 'good news' that it is not a $20K repair but simply a $6,500.00 head gasket job. I had a government fund letter requesting over $100,000 for underpayment of club dues. After a review by a private mathmatician, he said, "I have good news, you only owe $17,800.00",,, no relief was experienced. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > On my 82 Fc 3208 NA with an aftermarket turbo, the electric fan clutch kicks in at about > 195 degrees and immediately starts dropping the temperature. (I haven't installed the > manual switch overrride yet but I will). When climbing grades in temperatures above the > mid-90's the clutch almost always kicks in and reduces the temperature. If the > temperature of the engine kept climbing, instead of dropping, I'd slow down or pull over > and let it cool down for a while. This has never happened to me. > I also think it is quite premature to conclude that Andy's problems were caused by high > coolant temperatures when climbing grades in hot weather. I don't think anyone knows > why the head gasket failed. It's possible that the head gasket failed first, causing higher > coolant temperatures. It seems extremely unlikely to me that running a 3208 at 200 > degrees, which is the temperature that Andy reported, would by itself cause headgasket > failure. Headgaskets do fail, and a google shows reports of people replacing headgaskets > on 3208s. > I think there's an odd combination of events associated with Andy's problems that should > be considered. He reported repeated problems with belts coming off earlier this year, > then he had a fan clutch bearing failure,then he had a water pump failure, replaced it, then > had the head gasket failure. Alll those items are associated with the cooling system. > There's something odd going on. I'd want to try to figure out if these problems are related > and perhaps have a common cause. He also said his coolant lines to the rest of the coach > were disconnected. Is it possible that blocking those lines can cause inadequate coolant > circulation or high pressure leading to the other problems? > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > Just completed reading about Andy's trouble up in Reno and was > > wondering at what temperature should these old 3208'S run at? > > > > And I have just drove down to California from Washington and the > > average temperature outside during the day coming down I-5 in Redding > > were over 100 degrees. Could this possibly have cause part of his > > problems with this heat situation? > > > > Also is there anything that you can use in your coolant to lubricate > > the water pump? > > > > Oh yes one more thing, would you think when you are in really hot > > weather it would be better to run your machine at night to wherever > > your going? > > > > Jon > > Rebel Bird > > > What is the best tempeture to run a 3208 engine? - Chuck Wheeler - 08-31-2007 03:18 One thing that can cause head gasket failure, and other problems, is bogging the engine. Bogging will not necessarily cause high coolant temperature readings. The 3208 has a short stroke and has to turn faster than most diesels used over the road. Except under very light throttle it should not be operated below 2000 rpm. The Allison should shift down about 2000 rpm under heavy throttle. If you are operating in the 2000-2200 rpm range and do not have throttle response it is probably a good idea to slow down and downshift. Also remember that the gauge is indicating the average temperature not the peaks. Somewhere I read an interesting article on 3208s when I was trying to understand how you could find them with various ratings from 175 to 400 hp. Basically the "life" curve was inverse to the hp curve. The low hp version had an expected life of 10,000-12,000 hours. The 400 version was 2500 to 3000 hours. The criteria was will a particular version outlast the warranty in the application. Example would be a pleasure boat that might see 100 to 300 hours a year would get a 300 hp version and a bobcat that would be operated 1600 to 1800 hours a year would get a 175 hp version. I will try to find the link to this. It was interesting reading. Just my thoughts, but if I were Andy I would consider replacing the engine if I liked the coach and was planning to keep it. It is a lot of money, but so is selling his current BB for a few thousand and then buying another that may present the same problems in the future. If he puts a good reman engine in it he then knows what he has. The price does sound a little high. The local cat dealer was estimating 14-15K if I had to replace mine. - Chuck Wheeler - FC 31SB Fort Worth TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Friday, August 31, 2007 9:10 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: What is the best tempeture to run a 3208 engine? On my 82 Fc 3208 NA with an aftermarket turbo, the electric fan clutch kicks in at about 195 degrees and immediately starts dropping the temperature. (I haven't installed the manual switch overrride yet but I will). When climbing grades in temperatures above the mid-90's the clutch almost always kicks in and reduces the temperature. If the temperature of the engine kept climbing, instead of dropping, I'd slow down or pull over and let it cool down for a while. This has never happened to me. I also think it is quite premature to conclude that Andy's problems were caused by high coolant temperatures when climbing grades in hot weather. I don't think anyone knows why the head gasket failed. It's possible that the head gasket failed first, causing higher coolant temperatures. It seems extremely unlikely to me that running a 3208 at 200 degrees, which is the temperature that Andy reported, would by itself cause headgasket failure. Headgaskets do fail, and a google shows reports of people replacing headgaskets on 3208 I think there's an odd combination of events associated with Andy's problems that should be considered. He reported repeated problems with belts coming off earlier this year, then he had a fan clutch bearing failure,then he had a water pump failure, replaced it, then had the head gasket failure. Alll those items are associated with the cooling system. There's something odd going on. I'd want to try to figure out if these problems are related and perhaps have a common cause. He also said his coolant lines to the rest of the coach were disconnected. Is it possible that blocking those lines can cause inadequate coolant circulation or high pressure leading to the other problems? Kerry 82 FC 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "Jon" > > Just completed reading about Andy's trouble up in Reno and was > wondering at what temperature should these old 3208'S run at? > > And I have just drove down to California from Washington and the > average temperature outside during the day coming down I-5 in Redding > were over 100 degrees. Could this possibly have cause part of his > problems with this heat situation? > > Also is there anything that you can use in your coolant to lubricate > the water pump? > > Oh yes one more thing, would you think when you are in really hot > weather it would be better to run your machine at night to wherever > your going? > > Jon > Rebel Bird > [Non-text portions of this message have been removed] What is the best tempeture to run a 3208 engine? - whistles_n_bells - 08-31-2007 13:26 Just thought I'd throw this out to the group. When I was driving for a living in the 50's and 60's - and in more recent years (buses) - we would often-times turn on the engine-provided coach heat to get the water circulating in those many feet of plumbing thereby cooling the water. This of course is in the warmer months of the year when one is thinking air conditioning and not heat, of all things. Also, on the engine driven air conditioning, we would shut it down until the temp gage came down to the 190-200 degree range. It was always explained to the passengers (by way of the PA) why the coach was getting warmer. Obviously, this is taking into account that fans and radiator cooling functions are in good working order. The engines involved were DD 671, 8V71 and recently, Cummins M11. I would think that the setup on the PT Birds and other "pushers" would be similar - with regard to the coach heating layout. Again, just some recollections. P.S. Welcome home Ralph - glad your procedure is behind you. I always enjoy your posts. Joe (Pappy) Hagan St. George, UT Wannabe --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Just completed reading about Andy's trouble up in Reno and was > wondering at what temperature should these old 3208'S run at? > > And I have just drove down to California from Washington and the > average temperature outside during the day coming down I-5 in Redding > were over 100 degrees. Could this possibly have cause part of his > problems with this heat situation? > > Also is there anything that you can use in your coolant to lubricate > the water pump? > > Oh yes one more thing, would you think when you are in really hot > weather it would be better to run your machine at night to wherever > your going? > > Jon > Rebel Bird > What is the best tempeture to run a 3208 engine? - Jon - 09-01-2007 02:32 --- In WanderlodgeForum@yahoogroups.com, "whistles_n_bells" > > Just thought I'd throw this out to the group. When I was driving for a > living in the 50's and 60's - and in more recent years (buses) - we > would often-times turn on the engine-provided coach heat to get the > water circulating in those many feet of plumbing thereby cooling the > water. This of course is in the warmer months of the year when one is > thinking air conditioning and not heat, of all things. Also, on the > engine driven air conditioning, we would shut it down until the temp > gage came down to the 190-200 degree range. It was always explained to > the passengers (by way of the PA) why the coach was getting warmer. > Obviously, this is taking into account that fans and radiator cooling > functions are in good working order. Very interesting on the idea of using the coaches interior heaters for cooling the engine cooling water down. I will give that a try if and when my temperature gage is above the normal operating temperature for my coach. I don't think anybody mentioned yet but just what is the norm for these engines as far as heat ranges go? And one more question how do you compute engine hours to driving hours? I know this sounds dumb but my old brain just doesn't want to function for that easy answer. Jon Rebel Bird Bremerton Washington > > The engines involved were DD 671, 8V71 and recently, Cummins M11. I > would think that the setup on the PT Birds and other "pushers" would be > similar - with regard to the coach heating layout. > > Again, just some recollections. > > P.S. Welcome home Ralph - glad your procedure is behind you. I always > enjoy your posts. > > Joe (Pappy) Hagan > St. George, UT > Wannabe > > > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > Just completed reading about Andy's trouble up in Reno and was > > wondering at what temperature should these old 3208'S run at? > > > > And I have just drove down to California from Washington and the > > average temperature outside during the day coming down I-5 in Redding > > were over 100 degrees. Could this possibly have cause part of his > > problems with this heat situation? > > > > Also is there anything that you can use in your coolant to lubricate > > the water pump? > > > > Oh yes one more thing, would you think when you are in really hot > > weather it would be better to run your machine at night to wherever > > your going? > > > > Jon > > Rebel Bird > > > What is the best tempeture to run a 3208 engine? - davidkerryedwards - 09-01-2007 03:36 I've got 100k miles with about 3000 hrs. Pretty typical I think. Kerry 82 FC 35 Denver > > And one more question how do you compute engine hours to driving > hours? I know this sounds dumb but my old brain just doesn't want to > function for that easy answer. > > Jon > Rebel Bird > Bremerton Washington > What is the best tempeture to run a 3208 engine? - Curt Sprenger - 09-01-2007 04:07 Our coach has 93,000 miles and 2,030 engine hours; averaging about 46 miles per hour. The coach has been on the highway, not a lot of city driving or ideling time. On 9/1/07, davidkerryedwards > > I've got 100k miles with about 3000 hrs. Pretty typical I think. > > Kerry > 82 FC 35 > Denver > > > > And one more question how do you compute engine hours to driving > > hours? I know this sounds dumb but my old brain just doesn't want to > > function for that easy answer. > > > > Jon > > Rebel Bird > > Bremerton Washington > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
