water heater water sensor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: water heater water sensor (/showthread.php?tid=5605) |
water heater water sensor - Jay Darst - 09-01-2007 14:56 While replumbing the new water heater, found a sensor that is 1/2"NPT that has a single, very small wire that runs over to a relay which powers the 120V to the water heater. Appears to be a safety device so that the heating element is not ruined when there is no water present. The sensor I removed is severly corroded. Can anyone point me in the direction of a replacement? Thanks Jay Darst 85PT40 Springfield/Sullivan, IL Shopping hard for my next Prevost to turn...and keeping my old Bird which I love dearly. water heater water sensor - Richard Hayden - 09-01-2007 17:39 Jay, If I'm not mistaken, these were a BB thingy and build by them in house. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Jay Darst To: WanderlodgeForum@yahoogroups.com Sent: Saturday, September 01, 2007 7:56 PM Subject: [WanderlodgeForum] water heater water sensor While replumbing the new water heater, found a sensor that is 1/2"NPT that has a single, very small wire that runs over to a relay which powers the 120V to the water heater. Appears to be a safety device so that the heating element is not ruined when there is no water present. The sensor I removed is severly corroded. Can anyone point me in the direction of a replacement? Thanks Jay Darst 85PT40 Springfield/Sullivan, IL Shopping hard for my next Prevost to turn...and keeping my old Bird which I love dearly. [Non-text portions of this message have been removed] water heater water sensor - Ryan Wright - 09-01-2007 20:12 Jay, Is it a float switch, or a contact water sensor, or what? If a float switch, these are easy to find. Check Grainger or McMaster-Carr, they have lots of 'em to choose from. If it's a water presence sensor as opposed to a level sensor, do a Google search for "liquid sensor" - there were several interesting results. ("water sensor" is not a great search term - you'll get a lot of consumer grade junk. The term "liquid" will turn up more industrial sites where you have a better chance of getting something that can actuate a relay and will probably last longer, too.) -Ryan '86 PT-40 8V92 Tri-Cities, WA On 9/1/07, Jay Darst > > While replumbing the new water heater, found a sensor that is 1/2"NPT > that has a single, very small wire that runs over to a relay which > powers the 120V to the water heater. > > Appears to be a safety device so that the heating element is not ruined > when there is no water present. > > The sensor I removed is severly corroded. > > Can anyone point me in the direction of a replacement? > > Thanks > Jay Darst > 85PT40 > Springfield/Sullivan, IL > Shopping hard for my next Prevost to turn...and keeping my old Bird > which I love dearly. > water heater water sensor - Jay Darst - 09-02-2007 00:31 In case anyone wants to know... Ralph Fullenwider had the find/fix for this... "Making one is faster for me, Ace hardware and get a pvc plug, I can't remember the size off hand Jay, but any grey 2 part epoxy will do and a brass machine screw with 2 nuts with washers between them. The screw goes through the plug in a hole you drill, I taped mine to get a tighter fit and have more adjustment on the length and of course epoxy seal. Then end of the screw goes out to just even or slightly past the concave of the inside of the edge of the plug. This is a BB part, no one else uses this type of sensor. but hell, it is nothing to make one, put a screw in it, drip epoxy on both sides and let the new home made sensor sit for 24 hours then install it. JB Weld is a good choice." Thanks Ralph!!!!!! Jay Darst 85PT40 Springfield/Sullivan, IL --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > While replumbing the new water heater, found a sensor that is 1/2"NPT > that has a single, very small wire that runs over to a relay which > powers the 120V to the water heater. > > Appears to be a safety device so that the heating element is not ruined > when there is no water present. > > The sensor I removed is severly corroded. > > Can anyone point me in the direction of a replacement? > > Thanks > Jay Darst > 85PT40 > Springfield/Sullivan, IL > Shopping hard for my next Prevost to turn...and keeping my old Bird > which I love dearly. > water heater water sensor - Jay Darst - 09-02-2007 14:16 THE HOMEMADE SENSOR COMPLETES THE GROUND FOR THE RELAY. THE RELAY ENERGIZES AND THE WATER HEATER NOW HAS 120V. I made 3 of them. I used a brass fitting, I think its called a bushing. It has 1/2"NPT on the outside and 3/8"NPT threads on the inside. I used a stainless steel machine screw, couldn't find a brass machine screw. Run a washer and a nut down nearlY to the head of the machine screw, leaving room to easily attach an electrical connector. Then using a leather punch, put a hole in a piece of cardboard just a little smaller than the machine screw. The cardboard should be larger than the overall fitting. Now set the machine screw, washer, nut and cardboard on something that will keep the naked end of the machine screw facing toward the sky. Now set the brass fitting over the machine screw so that it does not touch the screw. The brass fitting is now sitting on the cardboard, strattling the machine screw. Drip epoxy in the brass fitting til its nearly full. Let it set for 2 hours- don't mess with it. AFTER 2 hours, remove the cardboard. It'll be stuck to the epoxy so just scrape it off. I tested the finished product in a bowl of water with ohm meter/continuity tester, werks grate! Thanks again RALPH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Its Sunday night and I'm dam near done with the water heater replacement. Need a couple brass fittings to finish up the cold water line to heater. Replacing the water heater is a PIA. I'm glad its dam near behind me now ;~} If anyone needs a sensor, I have 2 more left over. Did I say THANKS RALPH?!! Jay Darst 85PT40 Springfield/Sullivan, IL --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > In case anyone wants to know... > > Ralph Fullenwider had the find/fix for this... > > "Making one is faster for me, Ace hardware and get a pvc plug, I > can't > remember the size off hand Jay, but any grey 2 part epoxy will do and > a brass machine screw with 2 nuts with washers between them. > > The screw goes through the plug in a hole you drill, I taped mine to > get a tighter fit and have more adjustment on the length and of > course epoxy seal. > > Then end of the screw goes out to just even or slightly past the > concave of the inside of the edge of the plug. > > This is a BB part, no one else uses this type of sensor. but hell, it > is nothing to make one, put a screw in it, drip epoxy on both sides > and let the new home made sensor sit for 24 hours then install it. > > JB Weld is a good choice." > > > > While replumbing the new water heater, found a sensor that is > 1/2"NPT > > that has a single, very small wire that runs over to a relay which > > powers the 120V to the water heater. > > > > Appears to be a safety device so that the heating element is not > ruined > > when there is no water present. > > > > The sensor I removed is severly corroded. > > > > Can anyone point me in the direction of a replacement? > > > > Thanks > > Jay Darst > > 85PT40 > > Springfield/Sullivan, IL > > Shopping hard for my next Prevost to turn...and keeping my old Bird > > which I love dearly. > > > water heater water sensor - Gregory OConnor - 09-02-2007 16:44 Cool deal, I lost a heating element because I did not fill the tank prior to plugging the coach into shorepower with the waterheater switch turned on. Campingworld said It takes less than 30 seconds of dry runtime to cook an element. I considered a magnetic switch for turning the water heater on (like a tablesaw switch). I would shure like to hang a lp waterheater outside. the big lp fuel tank is wasted on minor demand of cook top and refer. I wonder what OHM continuity is on water that is deionized???? would it be more conductive or less??? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > THE HOMEMADE SENSOR COMPLETES THE GROUND FOR THE RELAY. THE RELAY > ENERGIZES AND THE WATER HEATER NOW HAS 120V. > > I made 3 of them. I used a brass fitting, I think its called a > bushing. It has 1/2"NPT on the outside and 3/8"NPT threads on the > inside. I used a stainless steel machine screw, couldn't find a brass > machine screw. > > Run a washer and a nut down nearlY to the head of the machine screw, > leaving room to easily attach an electrical connector. Then using a > leather punch, put a hole in a piece of cardboard just a little > smaller than the machine screw. The cardboard should be larger than > the overall fitting. Now set the machine screw, washer, nut and > cardboard on something that will keep the naked end of the machine > screw facing toward the sky. > > Now set the brass fitting over the machine screw so that it does not > touch the screw. The brass fitting is now sitting on the cardboard, > strattling the machine screw. Drip epoxy in the brass fitting til its > nearly full. > > Let it set for 2 hours- don't mess with it. > > AFTER 2 hours, remove the cardboard. It'll be stuck to the epoxy so > just scrape it off. > > I tested the finished product in a bowl of water with ohm > meter/continuity tester, werks grate! > > Thanks again RALPH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! > > Its Sunday night and I'm dam near done with the water heater > replacement. Need a couple brass fittings to finish up the cold water > line to heater. > > Replacing the water heater is a PIA. > > I'm glad its dam near behind me now ;~} > > If anyone needs a sensor, I have 2 more left over. > > Did I say THANKS RALPH?!! > > Jay Darst > 85PT40 > Springfield/Sullivan, IL > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > wrote: > > > > In case anyone wants to know... > > > > Ralph Fullenwider had the find/fix for this... > > > > "Making one is faster for me, Ace hardware and get a pvc plug, I > > can't > > remember the size off hand Jay, but any grey 2 part epoxy will do > and > > a brass machine screw with 2 nuts with washers between them. > > > > The screw goes through the plug in a hole you drill, I taped mine > to > > get a tighter fit and have more adjustment on the length and of > > course epoxy seal. > > > > Then end of the screw goes out to just even or slightly past the > > concave of the inside of the edge of the plug. > > > > This is a BB part, no one else uses this type of sensor. but hell, > it > > is nothing to make one, put a screw in it, drip epoxy on both sides > > and let the new home made sensor sit for 24 hours then install it. > > > > JB Weld is a good choice." > > > > > > While replumbing the new water heater, found a sensor that is > > 1/2"NPT > > > that has a single, very small wire that runs over to a relay which > > > powers the 120V to the water heater. > > > > > > Appears to be a safety device so that the heating element is not > > ruined > > > when there is no water present. > > > > > > The sensor I removed is severly corroded. > > > > > > Can anyone point me in the direction of a replacement? > > > > > > Thanks > > > Jay Darst > > > 85PT40 > > > Springfield/Sullivan, IL > > > Shopping hard for my next Prevost to turn...and keeping my old > Bird > > > which I love dearly. > > > > > > water heater water sensor - bloomas - 09-03-2007 05:33 ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 02, 2007 11:44 PM Subject: [WanderlodgeForum] Re: water heater water sensor Gregory There is a 1988 PT 40 in northern Ca. that the old water heater was replace with a lp water heater installed in the same space that the old came out of and it is vented to the out side.It also has a 120 volt element. Bob Loomas 1985 PT 36 Cool deal, I lost a heating element because I did not fill the tank prior to plugging the coach into shorepower with the waterheater switch turned on. Campingworld said It takes less than 30 seconds of dry runtime to cook an element. I considered a magnetic switch for turning the water heater on (like a tablesaw switch). I would shure like to hang a lp waterheater outside. the big lp fuel tank is wasted on minor demand of cook top and refer. I wonder what OHM continuity is on water that is deionized???? would it be more conductive or less??? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > THE HOMEMADE SENSOR COMPLETES THE GROUND FOR THE RELAY. THE RELAY > ENERGIZES AND THE WATER HEATER NOW HAS 120V. > > I made 3 of them. I used a brass fitting, I think its called a > bushing. It has 1/2"NPT on the outside and 3/8"NPT threads on the > inside. I used a stainless steel machine screw, couldn't find a brass > machine screw. > > Run a washer and a nut down nearlY to the head of the machine screw, > leaving room to easily attach an electrical connector. Then using a > leather punch, put a hole in a piece of cardboard just a little > smaller than the machine screw. The cardboard should be larger than > the overall fitting. Now set the machine screw, washer, nut and > cardboard on something that will keep the naked end of the machine > screw facing toward the sky. > > Now set the brass fitting over the machine screw so that it does not > touch the screw. The brass fitting is now sitting on the cardboard, > strattling the machine screw. Drip epoxy in the brass fitting til its > nearly full. > > Let it set for 2 hours- don't mess with it. > > AFTER 2 hours, remove the cardboard. It'll be stuck to the epoxy so > just scrape it off. > > I tested the finished product in a bowl of water with ohm > meter/continuity tester, werks grate! > > Thanks again RALPH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! > > Its Sunday night and I'm dam near done with the water heater > replacement. Need a couple brass fittings to finish up the cold water > line to heater. > > Replacing the water heater is a PIA. > > I'm glad its dam near behind me now ;~} > > If anyone needs a sensor, I have 2 more left over. > > Did I say THANKS RALPH?!! > > Jay Darst > 85PT40 > Springfield/Sullivan, IL > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > wrote: > > > > In case anyone wants to know... > > > > Ralph Fullenwider had the find/fix for this... > > > > "Making one is faster for me, Ace hardware and get a pvc plug, I > > can't > > remember the size off hand Jay, but any grey 2 part epoxy will do > and > > a brass machine screw with 2 nuts with washers between them. > > > > The screw goes through the plug in a hole you drill, I taped mine > to > > get a tighter fit and have more adjustment on the length and of > > course epoxy seal. > > > > Then end of the screw goes out to just even or slightly past the > > concave of the inside of the edge of the plug. > > > > This is a BB part, no one else uses this type of sensor. but hell, > it > > is nothing to make one, put a screw in it, drip epoxy on both sides > > and let the new home made sensor sit for 24 hours then install it. > > > > JB Weld is a good choice." > > > > > > While replumbing the new water heater, found a sensor that is > > 1/2"NPT > > > that has a single, very small wire that runs over to a relay which > > > powers the 120V to the water heater. > > > > > > Appears to be a safety device so that the heating element is not > > ruined > > > when there is no water present. > > > > > > The sensor I removed is severly corroded. > > > > > > Can anyone point me in the direction of a replacement? > > > > > > Thanks > > > Jay Darst > > > 85PT40 > > > Springfield/Sullivan, IL > > > Shopping hard for my next Prevost to turn...and keeping my old > Bird > > > which I love dearly. > > > > > > [Non-text portions of this message have been removed] |
