more than one problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: more than one problem (/showthread.php?tid=5618) |
more than one problem - ingamar2 - 09-04-2007 15:17 First of all I went to the FMCA rally in Bend and on the way back I had new Trogan 105 batteries put in the coach in Pasco Wa. The next day on my way home I made a stop and I tried to start the bus and for a few second there was nothing and then it started to turn over and started but the tack didn't work. I didn't want to shut it off so I took off. I got to St Regis and stoped for lunch and shut the bus off and after lunch it start right off and the tack worked. Got home and have tried to start the bus and the tack works one out of every ten times I start the bus. Thats problem number one. Number two, I cked the voltage of the batteries and it was only about 12.4 for the first couple days at home pluged in. Then I cked one after noon and the voltage was at 14 so I cked the Heart invertor and it is set on about 12.9. I un-pluged the bus and then pluged it in about two hours later and the voltage has been holding at about 12.8. (these are my first new batteries sence I bought the bus so is that about right) The fridge went out now. If you unplug from shore power it will run on gas but will not run on anything if it is pluged in. The lights will come on for a second and go off. Last thing the alternator light goes on and off and if you switch to alter two the engine dies unless you have the RPM's up then it doesn't. Also the ck engine light comes on when switched to alternator two. Any ideas would be great. Craig Hovda Bigfork Mt 90 WBWL 40 more than one problem - Gregory OConnor - 09-04-2007 15:21 Did you mix 6 and 12 volt batteries?--- In WanderlodgeForum@yahoogroups.com, "ingamar2" > > First of all I went to the FMCA rally in Bend and on the way back I > had new Trogan 105 batteries put in the coach in Pasco Wa. The next > day on my way home I made a stop and I tried to start the bus and > for a few second there was nothing and then it started to turn over > and started but the tack didn't work. I didn't want to shut it off > so I took off. I got to St Regis and stoped for lunch and shut the > bus off and after lunch it start right off and the tack worked. Got > home and have tried to start the bus and the tack works one out of > every ten times I start the bus. Thats problem number one. Number > two, I cked the voltage of the batteries and it was only about 12.4 > for the first couple days at home pluged in. Then I cked one after > noon and the voltage was at 14 so I cked the Heart invertor and it > is set on about 12.9. I un-pluged the bus and then pluged it in > about two hours later and the voltage has been holding at about > 12.8. (these are my first new batteries sence I bought the bus so is > that about right) The fridge went out now. If you unplug from shore > power it will run on gas but will not run on anything if it is > pluged in. The lights will come on for a second and go off. Last > thing the alternator light goes on and off and if you switch to > alter two the engine dies unless you have the RPM's up then it > doesn't. Also the ck engine light comes on when switched to > alternator two. Any ideas would be great. > > Craig Hovda > Bigfork Mt > 90 WBWL 40 > more than one problem - Don Bradner - 09-04-2007 16:45 I would guess you have a short in the wiring inside the dash. I base that assumption on a couple of things: First, the alternator switch on my coach, which should be the same as yours, does not switch alternators. It only switches which one is being displayed. Second, I had a number of problems where I would get glitches, most notably the transmission degrading and going into do not shift mode, when various switches were operated, most often the headlights. I found that a wiring bundle (green wires) passed over a metal piece and had chafed a number of them so that they could short to ground. Besides covering the metal edge with some split rubber tubing, I wrapped each wire and then the bundle in rubber electrical tape. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Seven Feathers in Canyonville, Oregon. On 9/5/2007 at 3:17 AM ingamar2 wrote: >First of all I went to the FMCA rally in Bend and on the way back I >had new Trogan 105 batteries put in the coach in Pasco Wa. The next >day on my way home I made a stop and I tried to start the bus and >for a few second there was nothing and then it started to turn over >and started but the tack didn't work. I didn't want to shut it off >so I took off. I got to St Regis and stoped for lunch and shut the >bus off and after lunch it start right off and the tack worked. Got >home and have tried to start the bus and the tack works one out of >every ten times I start the bus. Thats problem number one. Number >two, I cked the voltage of the batteries and it was only about 12.4 >for the first couple days at home pluged in. Then I cked one after >noon and the voltage was at 14 so I cked the Heart invertor and it >is set on about 12.9. I un-pluged the bus and then pluged it in >about two hours later and the voltage has been holding at about >12.8. (these are my first new batteries sence I bought the bus so is >that about right) The fridge went out now. If you unplug from shore >power it will run on gas but will not run on anything if it is >pluged in. The lights will come on for a second and go off. Last >thing the alternator light goes on and off and if you switch to >alter two the engine dies unless you have the RPM's up then it >doesn't. Also the ck engine light comes on when switched to >alternator two. Any ideas would be great. > >Craig Hovda >Bigfork Mt >90 WBWL 40 more than one problem - erniecarpet@... - 09-04-2007 20:24 Craig, I wonder if the individuals that installed your batteries did not tighten the cables properly? Ernie Ekberg 83PT40 Livingston, Mt ---soon to be in TEXAS ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] more than one problem - ingamar2 - 09-05-2007 02:07 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Craig, I wonder if the individuals that installed your batteries did not > tighten the cables properly? > > Ernie Ekberg > 83PT40 > Livingston, Mt > ---soon to be in TEXAS > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > I cked the battery cable to see if they were wired correctly and if they were all tight and everything looks good. I put in six new t105 so no I didn't mix 6 and 12v. I pulled the dash out yesterday but didn't have time to ck it close. Will do that today and maybe I will find the problems with the alternators. Why would the votage go to 14 and then down to 12.8 and stay there. And could that have done damage to the circit board on the fridge. Craig Hovda Bigfork Mt 90 WBWL > > [Non-text portions of this message have been removed] > more than one problem - David Brady - 09-05-2007 02:45 Take the cables off the battery and measure the resistance (ohms) from connector to connector. Resistance should read zero. You may have a faulty cable. A battery at rest should read 12.6V and one charging should read 13.8V. I don't think you damaged any printed circuit cards. David Brady '02 LXi, NC ingamar2 wrote: > > --- In WanderlodgeForum@yahoogroups.com > > > > > Craig, I wonder if the individuals that installed your batteries > did not > > tighten the cables properly? > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > ---soon to be in TEXAS > > > > > > > > ************************************** Get a sneak peek of the all- > new AOL at > > http://discover.aol.com/memed/aolcom30tour > <http://discover.aol.com/memed/aolcom30tour> > > I cked the battery cable to see if they were wired correctly and > if they were all tight and everything looks good. I put in six new > t105 so no I didn't mix 6 and 12v. I pulled the dash out yesterday > but didn't have time to ck it close. Will do that today and maybe I > will find the problems with the alternators. > > Why would the votage go to 14 and then down to 12.8 and stay there. > And could that have done damage to the circit board on the fridge. > > Craig Hovda > Bigfork Mt > 90 WBWL > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.485 / Virus Database: 269.13.5/990 - Release Date: 9/4/2007 10:36 PM > [Non-text portions of this message have been removed] more than one problem - ingamar2 - 09-05-2007 02:48 --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Take the cables off the battery and measure the resistance (ohms) > from connector to connector. Resistance should read zero. You > may have a faulty cable. A battery at rest should read 12.6V and > one charging should read 13.8V. I don't think you damaged any > printed circuit cards. > > David Brady > '02 LXi, NC > > ingamar2 wrote: > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > Craig, I wonder if the individuals that installed your batteries > > did not > > > tighten the cables properly? > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Mt > > > ---soon to be in TEXAS > > > > > > > > > > > > ************************************** Get a sneak peek of the all- > > new AOL at > > > http://discover.aol.com/memed/aolcom30tour > > <http://discover.aol.com/memed/aolcom30tour> > > > I cked the battery cable to see if they were wired correctly and > > if they were all tight and everything looks good. I put in six new > > t105 so no I didn't mix 6 and 12v. I pulled the dash out yesterday > > but didn't have time to ck it close. Will do that today and maybe I > > will find the problems with the alternators. > > > > Why would the votage go to 14 and then down to 12.8 and stay there. > > And could that have done damage to the circit board on the fridge. > > > > Craig Hovda > > Bigfork Mt > > 90 WBWL > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ----------------------------------------------------------------- ------- > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.485 / Virus Database: 269.13.5/990 - Release Date: 9/4/2007 10:36 PM > > > > I will ck that out today. Craig Hovda Bigfork Mt 90 WBWL > > [Non-text portions of this message have been removed] > more than one problem - Richard Hayden - 09-05-2007 04:28 Yes, I have the standard 6, T105's in a series/parallel arrangement. Why? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 04, 2007 8:21 PM Subject: [WanderlodgeForum] Re: more than one problem Did you mix 6 and 12 volt batteries?--- In WanderlodgeForum@yahoogroups.com "ingamar2" > > First of all I went to the FMCA rally in Bend and on the way back I > had new Trogan 105 batteries put in the coach in Pasco Wa. The next > day on my way home I made a stop and I tried to start the bus and > for a few second there was nothing and then it started to turn over > and started but the tack didn't work. I didn't want to shut it off > so I took off. I got to St Regis and stoped for lunch and shut the > bus off and after lunch it start right off and the tack worked. Got > home and have tried to start the bus and the tack works one out of > every ten times I start the bus. Thats problem number one. Number > two, I cked the voltage of the batteries and it was only about 12.4 > for the first couple days at home pluged in. Then I cked one after > noon and the voltage was at 14 so I cked the Heart invertor and it > is set on about 12.9. I un-pluged the bus and then pluged it in > about two hours later and the voltage has been holding at about > 12.8. (these are my first new batteries sence I bought the bus so is > that about right) The fridge went out now. If you unplug from shore > power it will run on gas but will not run on anything if it is > pluged in. The lights will come on for a second and go off. Last > thing the alternator light goes on and off and if you switch to > alter two the engine dies unless you have the RPM's up then it > doesn't. Also the ck engine light comes on when switched to > alternator two. Any ideas would be great. > > Craig Hovda > Bigfork Mt > 90 WBWL 40 > [Non-text portions of this message have been removed] more than one problem - martingregg598 - 09-05-2007 15:18 Craig, sorry to here about your electrical problems, you know the 105, are not the problem. Dad and I had a great time parked next to you and Shelly at Bend, thanks for the hospitality. Did you get the card I left in the door at Celillo rest area? My wife and I were going by on our way home Sunday and saw your coach parked, but you were out and about. With all the weird stuff going on electrically, can't help but wonder if there is a ground problem somewhere. My coach is down for now as I am building a new genorator slide bracket and have a z-bracket wore out on the throttle positioning cable for the trany. Marty Gregg 95 BMC 37 Kennewick, WA. |
