Minor but annoying problems - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Minor but annoying problems (/showthread.php?tid=5691) |
Minor but annoying problems - Wilhelmus Schreurs - 09-20-2007 08:24 A few other things happened while on our 4k mile journey, which I hope you can help me with. Gauges - they are driving me crazy. Oil Temp gauge - boucing all over the place, then lost it, now bouncing again. Wiring to the sender seems ok, but did not check the sender. Pyrometer - moves very little, stays now about 300deg mark, sometimes it bounces up to 800 or so. Speedometer - working fine, then it was very erratic, now seems to be working fine. Is this like a magnetic pickup off the rear drivers wheel? Generator - runs fine, voltage, current all ok, but only runs for about 40 minutes at a time. I thought that it could be the oil pressure switch as the contact was loose, but that made no difference. The last time I ran it, all was fine then it quit and the oil pressure gauge went hard to the right, now it won't start. Please help. Thanks in advance. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail at http://mrd.mail.yahoo.com/try_beta?.intl=ca [Non-text portions of this message have been removed] Minor but annoying problems - Pete Masterson - 09-20-2007 09:12 My generator started quitting after about 40 minutes ... and I found that the cooling fan wasn't working -- the generator was shutting down to avoid damage due to overheating. SInce your coach is somewhat older, I don't know if your genny set up is different, however. It would start then run for 30 seconds or so once it was warmed up, then stop again. Re start once it had cooled down would run for 30-40 minutes, etc. There's also a water level sensor that could be part of the problem. I think Gardner had some experience with that... (Perhaps he'll join in....) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Sep 20, 2007, at 1:24 PM, Wilhelmus Schreurs wrote: <snip> > > Generator - runs fine, voltage, current all ok, but only runs for > about 40 minutes at a time. > I thought that it could be the oil pressure switch as the contact > was loose, but that made no difference. The last time I ran it, all > was fine then it quit and the oil pressure gauge went hard to the > right, now it won't start. <snip> [Non-text portions of this message have been removed] Minor but annoying problems - Wilhelmus Schreurs - 09-20-2007 11:33 Thanks Pete: I did check the fan, and the cooling water temp went to 160 deg and stayed there. The water level is fine. BUT the oil gauge did show 50 psi then poof, it is hard right and now it won't start. Any other suggestions would be appreciated. Thanks Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, September 20, 2007 2:12:07 PM Subject: Re: [WanderlodgeForum] Minor but annoying problems My generator started quitting after about 40 minutes ... and I found that the cooling fan wasn't working -- the generator was shutting down to avoid damage due to overheating. SInce your coach is somewhat older, I don't know if your genny set up is different, however. It would start then run for 30 seconds or so once it was warmed up, then stop again. Re start once it had cooled down would run for 30-40 minutes, etc. There's also a water level sensor that could be part of the problem. I think Gardner had some experience with that... (Perhaps he'll join in....) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@mac. com On Sep 20, 2007, at 1:24 PM, Wilhelmus Schreurs wrote: <snip> > > Generator - runs fine, voltage, current all ok, but only runs for > about 40 minutes at a time. > I thought that it could be the oil pressure switch as the contact > was loose, but that made no difference. The last time I ran it, all > was fine then it quit and the oil pressure gauge went hard to the > right, now it won't start. <snip> [Non-text portions of this message have been removed] Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail at http://mrd.mail.yahoo.com/try_beta?.intl=ca [Non-text portions of this message have been removed] Minor but annoying problems - Rob Robinson - 09-20-2007 12:57 Bill I would call Power Tech and talk to Jeff Jones (parts) or Matt in service. Very knowledgeable and helpful. Their number is 352 365-2777. On 20/09/2007, Wilhelmus Schreurs > > Thanks Pete: > I did check the fan, and the cooling water temp went to 160 deg and stayed > there. The water level is fine. BUT the oil gauge did show 50 psi then poof, > it is hard right and now it won't start. > > Any other suggestions would be appreciated. > Thanks > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > ----- Original Message ---- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, September 20, 2007 2:12:07 PM > Subject: Re: [WanderlodgeForum] Minor but annoying problems > > My generator started quitting after about 40 minutes ... and I found > that the cooling fan wasn't working -- the generator was shutting > down to avoid damage due to overheating. SInce your coach is somewhat > older, I don't know if your genny set up is different, however. > > It would start then run for 30 seconds or so once it was warmed up, > then stop again. Re start once it had cooled down would run for 30-40 > minutes, etc. > > There's also a water level sensor that could be part of the problem. > I think Gardner had some experience with that... (Perhaps he'll join > in....) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@mac. com > > On Sep 20, 2007, at 1:24 PM, Wilhelmus Schreurs wrote: > <snip> > > > > Generator - runs fine, voltage, current all ok, but only runs for > > about 40 minutes at a time. > > I thought that it could be the oil pressure switch as the contact > > was loose, but that made no difference. The last time I ran it, all > > was fine then it quit and the oil pressure gauge went hard to the > > right, now it won't start. > <snip> > > [Non-text portions of this message have been removed] > > Be smarter than spam. See how smart SpamGuard is at giving junk email the > boot with the All-new Yahoo! Mail at > http://mrd.mail.yahoo.com/try_beta?.intl=ca > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Minor but annoying problems - Stephen Birtles - 09-21-2007 00:39 Bad ground in the area of the dashboard Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > A few other things happened while on our 4k mile journey, which I hope you can help me with. > Gauges - they are driving me crazy. > > Oil Temp gauge - boucing all over the place, then lost it, now bouncing again. Wiring to the sender seems ok, but did not check the sender. > > Pyrometer - moves very little, stays now about 300deg mark, sometimes it bounces up to 800 or so. > > Speedometer - working fine, then it was very erratic, now seems to be working fine. Is this like a magnetic pickup off the rear drivers wheel? > > Generator - runs fine, voltage, current all ok, but only runs for about 40 minutes at a time. > I thought that it could be the oil pressure switch as the contact was loose, but that made no difference. The last time I ran it, all was fine then it quit and the oil pressure gauge went hard to the right, now it won't start. > > Please help. Thanks in advance. > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail at http://mrd.mail.yahoo.com/try_beta?.intl=ca > > > [Non-text portions of this message have been removed] > |
