Does anyone have wiring schemetics for a 92 WB40? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Does anyone have wiring schemetics for a 92 WB40? (/showthread.php?tid=5718) |
Does anyone have wiring schemetics for a 92 WB40? - mbrund - 09-26-2007 09:11 I am in need of info on the AC wiring diagram of a 1992 WB40 as I am preparing to replace the inverter. It currently has a Heart HF12- 2000U inverter and twin IOTA 45AMP battery chargers. I am looking to replace them with a single Xantrex RS3000 Inverter/Charger.The issue is that since the coach was designed for seperate inverter and chargers, the wiring is not properly setup for this type configuration. I believe I will need to pull the wiring from the AC breaker box 50AMP breakers (which I believe should come stright from the transfer switch) and route them to a new breaker box with two new 50 AMP breakers. These breakers would be ahead of the inverter and feed power from the power grid (shore or genny power) to the inverter which would pass them to the AC output of the inverter (via a transfer switch built inside the inverter). The output wires of the inverter would then attach to the original 50AMP breakers in the bedroom breaker panel. I am trying to figure out how the BB wiring is currently setup as the inverter seems to only power specific circuits in the coach when there is no other shore power. For example; the AC's are not on the inverter output circuit, and I believe the AC Florescents are also not on that circuit. So is the breaker panel isolated in some manner that allows this to occur, as there is no way that all three AC units can be on one leg of the 110 as it would cause an over current. I have not opened the breaker panel to look, but the only way I could see that working would be that the breaker panel is broken into two sections each driven by a transfer switch, OR, some other sensing circuit that keeps the AC off when the inverter is running. Does anyone have wiring schemetics for a 92 WB40? - mbulriss - 09-27-2007 02:13 Michael, I've got a full set for my 91 WB40 if that will help. I think they are real close. Call the next time you swing by Pipe Creek to check on your repairs and we can get together if you want to review them. They may not be as much help as you think they will be. They are mainly line drawings more than real schematics and not as useful as the older 80 model schematics like I had with Stagecoach. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > I am in need of info on the AC wiring diagram of a 1992 WB40 as I am > preparing to replace the inverter. It currently has a Heart HF12- > 2000U inverter and twin IOTA 45AMP battery chargers. I am looking to > replace them with a single Xantrex RS3000 Inverter/Charger.The issue > is that since the coach was designed for seperate inverter and > chargers, the wiring is not properly setup for this type > configuration. > > I believe I will need to pull the wiring from the AC breaker box > 50AMP breakers (which I believe should come stright from the transfer > switch) and route them to a new breaker box with two new 50 AMP > breakers. These breakers would be ahead of the inverter and feed > power from the power grid (shore or genny power) to the inverter > which would pass them to the AC output of the inverter (via a > transfer switch built inside the inverter). The output wires of the > inverter would then attach to the original 50AMP breakers in the > bedroom breaker panel. > > I am trying to figure out how the BB wiring is currently setup as the > inverter seems to only power specific circuits in the coach when > there is no other shore power. For example; the AC's are not on the > inverter output circuit, and I believe the AC Florescents are also > not on that circuit. So is the breaker panel isolated in some manner > that allows this to occur, as there is no way that all three AC units > can be on one leg of the 110 as it would cause an over current. > > I have not opened the breaker panel to look, but the only way I could > see that working would be that the breaker panel is broken into two > sections each driven by a transfer switch, OR, some other sensing > circuit that keeps the AC off when the inverter is running. > Does anyone have wiring schemetics for a 92 WB40? - mbrund - 09-27-2007 13:08 Mike, Thanks for the offer, I finally found the missing bluebox today (it was in the garage behind the trash bags of all places). So I was able to look at my electrical diagram and figured this all out finally. Michael Brundridge 92 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Michael, > > I've got a full set for my 91 WB40 if that will help. I think they > are real close. Call the next time you swing by Pipe Creek to check > on your repairs and we can get together if you want to review them. > They may not be as much help as you think they will be. They are > mainly line drawings more than real schematics and not as useful as > the older 80 model schematics like I had with Stagecoach. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > |
