Wandering steering - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Wandering steering (/showthread.php?tid=575) Pages: 1 2 |
Wandering steering - bgehl_6399 - 05-11-2005 01:42 I was wondering if anyone has any information on tightening up a steering box on a 1979FC35? My coach wanders something terrible in windy conditions. I have check all the steering linkage and it all is tight. It apears all the play is in the steering box. I can turn the wheel about 1/16 of a turn before the wheels start to move. Any information would be appreciated. Thanks Brian Gehl 79FC35 Springville, IA. Wandering steering - Tom Warner - 05-11-2005 02:29 Its just possible Brian that its the king pins binding that is your problem. Have you taken the weight off the front end and turned the steering wheel lock to lock while you inject grease into each kingpin? Thats the proper way to grease them and if they arent greased properly you will get this darting action while driving. tom 1982 FC35 Vernon Center,NY At 01:42 PM 5/11/2005 +0000, you wrote: >I was wondering if anyone has any information on tightening up a >steering box on a 1979FC35? My coach wanders something terrible in >windy conditions. I have check all the steering linkage and it all is >tight. It apears all the play is in the steering box. I can turn the >wheel about 1/16 of a turn before the wheels start to move. Any >information would be appreciated. >Thanks > >Brian Gehl >79FC35 >Springville, IA. Wandering steering - Curt Sprenger - 05-11-2005 02:50 Be sure all the components are tight from the steering box to the coach frame...resolved the wandering problem our 1974 had. Curt Sprenger â87PT38, Anaheim, Calif. Tom Warner wrote: > Its just possible Brian that its the king pins binding that is your > problem. Have you taken the weight off the front end and turned the > steering wheel lock to lock while you inject grease into each kingpin? > Thats the proper way to grease them and if they arent greased properly > you > will get this darting action while driving. > > tom > 1982 FC35 > Vernon Center,NY > > At 01:42 PM 5/11/2005 +0000, you wrote: > >I was wondering if anyone has any information on tightening up a > >steering box on a 1979FC35? My coach wanders something terrible in > >windy conditions. I have check all the steering linkage and it all is > >tight. It apears all the play is in the steering box. I can turn the > >wheel about 1/16 of a turn before the wheels start to move. Any > >information would be appreciated. > >Thanks > > > >Brian Gehl > >79FC35 > >Springville, IA. > > > > -- Wandering steering - Mike Hohnstein - 05-11-2005 03:50 The steering box likes to come loose from the frame. Make sure the bolts are tight. Check all pivot points for excessive clearance, tie rods, drag link etc. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: bgehl_6399 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 11, 2005 8:42 AM Subject: [WanderlodgeForum] Wandering steering I was wondering if anyone has any information on tightening up a steering box on a 1979FC35? My coach wanders something terrible in windy conditions. I have check all the steering linkage and it all is tight. It apears all the play is in the steering box. I can turn the wheel about 1/16 of a turn before the wheels start to move. Any information would be appreciated. Thanks Brian Gehl 79FC35 Springville, IA. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Wandering steering - randydupree - 05-11-2005 04:10 there is an adjustment on the box.i just adjusted the one on woodys bird.what apita..lucky i have a pit.there is a steel plate with 6 bolts that you have to remove,then you need a 3/4 wrench and a short stubby screwdriver. best deal is take it somewhere that knows how to adjust the box..randydupree93wb ----- Original Message ----- From: bgehl_6399 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 11, 2005 9:42 AM Subject: [WanderlodgeForum] Wandering steering I was wondering if anyone has any information on tightening up a steering box on a 1979FC35? My coach wanders something terrible in windy conditions. I have check all the steering linkage and it all is tight. It apears all the play is in the steering box. I can turn the wheel about 1/16 of a turn before the wheels start to move. Any information would be appreciated. Thanks Brian Gehl 79FC35 Springville, IA. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Wandering steering - George Lowry - 05-11-2005 05:36 Brian, You have received some very good information here. IF, after following all of their advice, you still have a problem, go to <http://www.babsteering.com>, Get their (800) number and call and talk to Bill. He has forgotten more about power steering than most people will ever know. Be sure to have all the information about which power steering unit you have, the pump, etc. so he can give you the exact information you need. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD bgehl_6399 wrote: > I was wondering if anyone has any information on tightening up a > steering box on a 1979FC35? My coach wanders something terrible in > windy conditions. I have check all the steering linkage and it all is > tight. It apears all the play is in the steering box. I can turn the > wheel about 1/16 of a turn before the wheels start to move. Any > information would be appreciated. > Thanks > > Brian Gehl > 79FC35 > Springville, IA. > > > > > > > > Yahoo! Groups Links > > > > > > > > > Wandering steering - bgehl_6399 - 05-11-2005 05:47 Thanks for all the advice, I am going to try greasing the king pins with the wheels off the ground first. I always greased them with the front end on the ground. We have a trip to Governor Dodge park in WI. this weekend and I will test it out on that trip. If that doesn't fix it I think I will try to adjust the steering box. I have already checked everything for tightness. Thanks again and I will let you know how it turns out. Brian Gehl 79FC35 Springville, IA. --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > there is an adjustment on the box.i just adjusted the one on woodys bird.what apita..lucky i have a pit.there is a steel plate with 6 bolts that you have to remove,then you need a 3/4 wrench and a short stubby screwdriver. best deal is take it somewhere that knows how to adjust the box..randydupree93wb > ----- Original Message ----- > From: bgehl_6399 > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 11, 2005 9:42 AM > Subject: [WanderlodgeForum] Wandering steering > > > I was wondering if anyone has any information on tightening up a > steering box on a 1979FC35? My coach wanders something terrible in > windy conditions. I have check all the steering linkage and it all is > tight. It apears all the play is in the steering box. I can turn the > wheel about 1/16 of a turn before the wheels start to move. Any > information would be appreciated. > Thanks > > Brian Gehl > 79FC35 > Springville, IA. > > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] Wandering steering - Ron Sprague - 05-11-2005 18:20 I have a leaking steering box on a 82FCSB that I would like to fix, but I don't know how to gain access to it. Perhaps if we can both get the same proceedure, we can soplve both problems. Ron Sprague 82FCSB > > From: "bgehl_6399" <bgehl@...> > Date: 2005/05/11 Wed AM 09:42:54 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Wandering steering > > [Non-text portions of this message have been removed] Wandering steering - randydupree - 05-11-2005 23:09 some leaks have been fixed by venting the system.randydupree93wb ----- Original Message ----- From: Ron Sprague To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 12, 2005 2:20 AM Subject: Re: [WanderlodgeForum] Wandering steering I have a leaking steering box on a 82FCSB that I would like to fix, but I don't know how to gain access to it. Perhaps if we can both get the same proceedure, we can soplve both problems. Ron Sprague 82FCSB > > From: "bgehl_6399" <bgehl@...> > Date: 2005/05/11 Wed AM 09:42:54 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Wandering steering > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Wandering steering - Mike Hohnstein - 05-12-2005 01:33 Remove battery box and there it is. I find a floor jack is a good tool to expidite the process. I would remove the batteries first. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: Ron Sprague To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 12, 2005 1:20 AM Subject: Re: [WanderlodgeForum] Wandering steering I have a leaking steering box on a 82FCSB that I would like to fix, but I don't know how to gain access to it. Perhaps if we can both get the same proceedure, we can soplve both problems. Ron Sprague 82FCSB > > From: "bgehl_6399" <bgehl@...> > Date: 2005/05/11 Wed AM 09:42:54 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Wandering steering > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
