Buzzer sounding in dash - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Buzzer sounding in dash (/showthread.php?tid=5766) |
Buzzer sounding in dash - Rose Mary - 02-23-2008 09:22 Hi group Left Willits, CA today, heading N on 101 back to Oregon. About 60 some miles into the drive a buzzer started sounding in the dash. No lights, all gauges in the normal range. Not overheated....hmm Checked all fluid levels before we left. Pulled over in a safe place and did a walk around, everything fine. When the radiator cools I'll recheck fluid level. When I turn the key on without starting the engine the buzzer comes on...not low air etc. If the rad. level ok , any thing I should be forwarned about if I drive on the Eureka, another 80 miles or so? Bird is running fine.... Thanks Rose Mary 82 FC 35 JP's White Bird Heading N on 101 between willits and Eureka Buzzer sounding in dash - Scott Forman - 02-23-2008 09:32 Check your levelers, if one is not fully stowed, it can move upon hitting a bump and that will activate the buzzer even if the 'Master Leveling' switch is off. A quick way to tell is to turn on 'Master Leveling' and see if you have a red light (assuming yours work). I have gotten a leveler buzzer before on my old 82 FC and my current 86 PT. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Rose Mary" > > Hi group > Left Willits, CA today, heading N on 101 back to Oregon. About 60 some > miles into the drive a buzzer started sounding in the dash. > No lights, all gauges in the normal range. Not overheated....hmm > Checked all fluid levels before we left. > > Pulled over in a safe place and did a walk around, everything fine. > When the radiator cools I'll recheck fluid level. > > When I turn the key on without starting the engine the buzzer comes > on...not low air etc. > > If the rad. level ok , any thing I should be forwarned about if I > drive on the Eureka, another 80 miles or so? > > Bird is running fine.... > > Thanks > Rose Mary > 82 FC 35 > JP's White Bird > Heading N on 101 > between willits and Eureka > Buzzer sounding in dash - Rose Mary - 02-23-2008 09:49 Scott that was exactly it! have had some rough patches of road. love these groups, thanks Rose Mary --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Check your levelers, if one is not fully stowed, it can move upon > hitting a bump and that will activate the buzzer even if the 'Master > Leveling' switch is off. A quick way to tell is to turn on 'Master > Leveling' and see if you have a red light (assuming yours work). > > I have gotten a leveler buzzer before on my old 82 FC and my current > 86 PT. > > Scott Forman > 86 PT38 > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com, "Rose Mary" > > > > > Hi group > > Left Willits, CA today, heading N on 101 back to Oregon. About 60 > some > > miles into the drive a buzzer started sounding in the dash. > > No lights, all gauges in the normal range. Not overheated....hmm > > Checked all fluid levels before we left. > > > > Pulled over in a safe place and did a walk around, everything fine. > > When the radiator cools I'll recheck fluid level. > > > > When I turn the key on without starting the engine the buzzer comes > > on...not low air etc. > > > > If the rad. level ok , any thing I should be forwarned about if I > > drive on the Eureka, another 80 miles or so? > > > > Bird is running fine.... > > > > Thanks > > Rose Mary > > 82 FC 35 > > JP's White Bird > > Heading N on 101 > > between willits and Eureka > > > Buzzer sounding in dash - Pete Masterson - 02-23-2008 10:15 Once, I had a mysterious buzzer come on in the dash. Nothing amiss. Gauges all ok. No warning lights. Checked everything as I sat by the side of the road. Buzzer quit when I shut down and came back on when I restarted. No error codes in the system. Complete puzzlement. Sat by the road for about half an hour (poking at this and that) in complete befuddlement. Started up again -- buzzer sounding. Continued on my way another 50 miles (to a SWBB rally) trying to ignore the buzzer. Next morning, no buzzer. No repeat ever since. Have driven 15,000 miles since then. Still OK. Still no idea what was going on or why the buzzer was sounding.
Just watch your gauges and keep your fingers crossed. PS. I wish BB had made the @$#$%!! buzzers easier to get to -- I'd have disconnected a wire if I could have located the darn thing. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 23, 2008, at 1:22 PM, Rose Mary wrote:
Buzzer sounding in dash - brad barton - 02-23-2008 14:15 Was your fuel mileage affected much by dragging your jacks down the road?? BradBarton00LXiDFW bbartonwx@...
Helping your favorite cause is as easy as instant messaging. You IM, we give. Learn more. Buzzer sounding in dash - Rose Mary - 02-23-2008 14:35 ha ha! Actually, one rear jack was only about an inch lower than the other, in it's normal place retracted and stored, not noticeable at all visually unless you squat and reference a point on the frame. just enough to jiggle the connection I suppose. It's off and on now, bumpy 101 at times. at least now I know what the buzzer is when it goes. Will deal with it at home, the jacks need some R&R anyway, as per JP's short fix it list. Pete, did you use your leveling jacks when you spent the night? Maybe yours had shook down a little...if you used them for your stay when you lifted the levelers they parked correctly and stayed. I will check the hydraulic resevoir in the morning. Haven't been needing to use them but know we've got some drips from the levelers. Need to get them rebuilt I know. thanks rose mary --- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...> wrote: > > Was your fuel mileage affected much by dragging your jacks down the road??Brad Barton 00LXiDFW bbartonwx@... > > > To: WanderlodgeForum@...: aeonix1@...: Sat, 23 Feb 2008 14:15:07 -0800Subject: Re: [WanderlodgeForum] Buzzer sounding in dash > > > > > Once, I had a mysterious buzzer come on in the dash. Nothing amiss. Gauges all ok. No warning lights. Checked everything as I sat by the side of the road. Buzzer quit when I shut down and came back on when I restarted. No error codes in the system. Complete puzzlement. Sat by the road for about half an hour (poking at this and that) in complete befuddlement. Started up again -- buzzer sounding. Continued on my way another 50 miles (to a SWBB rally) trying to ignore the buzzer. > > Next morning, no buzzer. No repeat ever since. Have driven 15,000 miles since then. Still OK. Still no idea what was going on or why the buzzer was sounding. > > Just watch your gauges and keep your fingers crossed. > > PS. I wish BB had made the @$#$%!! buzzers easier to get to -- I'd have disconnected a wire if I could have located the darn thing. > > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > On Feb 23, 2008, at 1:22 PM, Rose Mary wrote: > > Hi group > Left Willits, CA today, heading N on 101 back to Oregon. About 60 some > miles into the drive a buzzer started sounding in the dash. > No lights, all gauges in the normal range. Not overheated....hmm > Checked all fluid levels before we left. > > Pulled over in a safe place and did a walk around, everything fine. > When the radiator cools I'll recheck fluid level. > > When I turn the key on without starting the engine the buzzer comes > on...not low air etc. > > If the rad. level ok , any thing I should be forwarned about if I > drive on the Eureka, another 80 miles or so? > > Bird is running fine.... > > Thanks > Rose Mary > 82 FC 35 > JP's White Bird > Heading N on 101 > between willits and Eureka > > > > > > > > > > _________________________________________________________________ > Helping your favorite cause is as easy as instant messaging. You IM, we give. > http://im.live.com/Messenger/IM/Home/?source=text_hotmail_join > Buzzer sounding in dash - brad barton - 02-23-2008 14:56 I have the same problem. Only thing is, the buzzer goes off. Just the level-warning light stays on. It's a bad sensor I'll try to have replaced ata Wanderlodge Rally someday. BradBarton00LXiDFW bbartonwx@...
Shed those extra pounds with MSN and The Biggest Loser! Learn more. Buzzer sounding in dash - Pete Masterson - 02-23-2008 15:17 I suppose it could have been a low or out of position jack. The California freeways are notoriously bumpy. They've never given any trouble before or since. But it's not one of the things that came to mind to check. They do take quite a long time to clear the lights on the HWH panel when raising them -- but I always do a walk around and check to see that the jacks are fully retracted before moving the coach. Probably didn't affect the fuel mileage much. Might even improve it... Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 23, 2008, at 6:35 PM, Rose Mary wrote:
Buzzer sounding in dash - Larry Dill - 02-23-2008 16:14 Rosemary,
I had the same thing happen to me, what I have learned from it is, if the buzzer sounds right away turn on the leveling master switch, if one of the red light lights up then you know immediately it is a leveler jack... HTH Sea Ya Larry NYC 84 35FCSB ----- Original Message ----
From: Rose Mary To: WanderlodgeForum@yahoogroups.com Sent: Saturday, February 23, 2008 9:35:58 PM Subject: [WanderlodgeForum] Re: Buzzer sounding in dash ha ha! Actually, one rear jack was only about an inch lower than the other, in it's normal place retracted and stored, not noticeable at all visually unless you squat and reference a point on the frame. just enough to jiggle the connection I suppose. It's off and on now, bumpy 101 at times. at least now I know what the buzzer is when it goes. Will deal with it at home, the jacks need some R&R anyway, as per JP's short fix it list. Pete, did you use your leveling jacks when you spent the night? Maybe yours had shook down a little...if you used them for your stay when you lifted the levelers they parked correctly and stayed. I will check the hydraulic resevoir in the morning. Haven't been needing to use them but know we've got some drips from the levelers. Need to get them rebuilt I know. thanks rose mary --- In "WanderlodgeForum%40yahoogroups.com", brad barton <bbartonwx@. ..> wrote: > > Was your fuel mileage affected much by dragging your jacks down the road??Brad Barton 00LXiDFW bbartonwx@.. . > > > To: WanderlodgeForum@ ...: aeonix1@...: Sat, 23 Feb 2008 14:15:07 -0800Subject: Re: [WanderlodgeForum] Buzzer sounding in dash > > > > > Once, I had a mysterious buzzer come on in the dash. Nothing amiss. Gauges all ok. No warning lights. Checked everything as I sat by the side of the road. Buzzer quit when I shut down and came back on when I restarted. No error codes in the system. Complete puzzlement. Sat by the road for about half an hour (poking at this and that) in complete befuddlement. Started up again -- buzzer sounding. Continued on my way another 50 miles (to a SWBB rally) trying to ignore the buzzer. > > Next morning, no buzzer. No repeat ever since. Have driven 15,000 miles since then. Still OK. Still no idea what was going on or why the buzzer was sounding. > > Just watch your gauges and keep your fingers crossed. > > PS. I wish BB had made the @$#$%!! buzzers easier to get to -- I'd have disconnected a wire if I could have located the darn thing. > > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > On Feb 23, 2008, at 1:22 PM, Rose Mary wrote: > > Hi group > Left Willits, CA today, heading N on 101 back to Oregon. About 60 some > miles into the drive a buzzer started sounding in the dash. > No lights, all gauges in the normal range. Not overheated.. ..hmm > Checked all fluid levels before we left. > > Pulled over in a safe place and did a walk around, everything fine. > When the radiator cools I'll recheck fluid level. > > When I turn the key on without starting the engine the buzzer comes > on...not low air etc. > > If the rad. level ok , any thing I should be forwarned about if I > drive on the Eureka, another 80 miles or so? > > Bird is running fine.... > > Thanks > Rose Mary > 82 FC 35 > JP's White Bird > Heading N on 101 > between willits and Eureka > > > > > > > > > > ____________ _________ _________ _________ _________ _________ _ > Helping your favorite cause is as easy as instant messaging. You IM, we give. > http://im.live. com/Messenger/ IM/Home/? source=text_ hotmail_join > Looking for last minute shopping deals? Find them fast with Yahoo! Search. Buzzer sounding in dash - Alex Smith - 02-24-2008 05:55 To Rose Mary and other FC Owners, I had this same problem this past December. Warning buzzer and light. All gauges, oil & temp, where reading normal. Oil and coolant levels were normal. I needed to make a quick trip but knew we would go crazy listening to that buzzer. Satisfying myself that all engine systems where OK and that the problem was in the alarm-sensor system, I disconnected the buzzer(light stayed on). By removing the front, drivers side panel, I was able to locate a small control box made by Kysor Cadillac. It is very difficult to see and even more difficult to get to. One of the lugs was labeled something like alarm audio or buzzer, or wording to that affect. Disconnecting that, the buzzer when out and we were able to make our trip in peace. Upon returning, I reconnected the alarm, and started disconnecting each senor lug individually until I found which sensor was the problem. I turned out to be the oil senor. From inside the Coach, looking into the doghouse, I found a oil senor on the cylinder head on the right side. It has one wire running to it. After removing the senor, I when to NAPA and by looking at the pictures in the catalog we where able to select one that was most appropriate (no part number on the existing). This fixed the problem, no buzzer, no idiot light. The senor had developed a small oil leak. I had concern that the problem was the Kysor Cadillac control box and was relieved to find out it is ok. A fellow Blue Birder, Lucas Willemse, advised that the company is now called Medallion Kysor. Their phone is 616-850-8048 if you ever have the need. Hope this may you and others if this problem comes up again. Alex Smith 82FC35RB Tallahassee --- In WanderlodgeForum@yahoogroups.com, "Rose Mary" wrote: > > Hi group > Left Willits, CA today, heading N on 101 back to Oregon. About 60 some > miles into the drive a buzzer started sounding in the dash. > No lights, all gauges in the normal range. Not overheated....hmm > Checked all fluid levels before we left. > > Pulled over in a safe place and did a walk around, everything fine. > When the radiator cools I'll recheck fluid level. > > When I turn the key on without starting the engine the buzzer comes > on...not low air etc. > > If the rad. level ok , any thing I should be forwarned about if I > drive on the Eureka, another 80 miles or so? > > Bird is running fine.... > > Thanks > Rose Mary > 82 FC 35 > JP's White Bird > Heading N on 101 > between willits and Eureka > |
