LXi headlight surround/bumper - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: LXi headlight surround/bumper (/showthread.php?tid=5848) |
LXi headlight surround/bumper - David Brady - 10-16-2007 11:05 Folks, Anyone have a solution for adhering the black bumper/ headlight surround on the front of the LXi. As many of you know, this faux bumper is merely a plastic outer shell (housing the turn signal and headlight coverings), glued to a plastic inner shell which holds four studs enabling the whole assembly to be attached to the front end-cap. On the LXi, the headlight surround often separates from the inner plastic shell. If one happens to lose a surround on the road, BB will provide a new one for the not-so-small sum of $1500 per side! Mine are working loose and I'd like to reattach them to the inner plastic shell. Anyone have a good solution for doing this? Glues, bolts, grommets, rivets... Any first hand experience? Thanks, David Brady '02 LXi, NC LXi headlight surround/bumper - somervillebus - 10-16-2007 12:08 --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > Anyone have a solution for adhering the black bumper/ > headlight surround on the front of the LXi. As many of > you know, this faux bumper is merely a plastic outer > shell (housing the turn signal and headlight coverings), glued > to a plastic inner shell which holds four studs enabling the > whole assembly to be attached to the front end-cap. On > the LXi, the headlight surround often separates from the > inner plastic shell. If one happens to lose a surround on the > road, BB will provide a new one for the not-so-small sum > of $1500 per side! Mine are working loose and I'd like > to reattach them to the inner plastic shell. Anyone have a > good solution for doing this? Glues, bolts, grommets, > rivets... Any first hand experience? > > Thanks, > David Brady > '02 LXi, NC I used liquid nails to reinforce mine last year...so far so good. There are different types of liquid nails, get the one that works on plastic. Home Depot/Lowes I had no idea those cost that much. I will be watching them closely. LXi headlight surround/bumper - somervillebus - 10-16-2007 12:11 --- In WanderlodgeForum@yahoogroups.com, "somervillebus" <somervillebus@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, David Brady > wrote: > > > > Folks, > > > > Anyone have a solution for adhering the black bumper/ > > headlight surround on the front of the LXi. As many of > > you know, this faux bumper is merely a plastic outer > > shell (housing the turn signal and headlight coverings), glued > > to a plastic inner shell which holds four studs enabling the > > whole assembly to be attached to the front end-cap. On > > the LXi, the headlight surround often separates from the > > inner plastic shell. If one happens to lose a surround on the > > road, BB will provide a new one for the not-so-small sum > > of $1500 per side! Mine are working loose and I'd like > > to reattach them to the inner plastic shell. Anyone have a > > good solution for doing this? Glues, bolts, grommets, > > rivets... Any first hand experience? > > > > Thanks, > > David Brady > > '02 LXi, NC > > > > > > > > > > > > > > > I used liquid nails to reinforce mine last year...so far so good. > There are different types of liquid nails, get the one that works on > plastic. Home Depot/Lowes I had no idea those cost that much. I will > be watching them closely. I forgot to sign: Slim Somerville 99 LXi > LXi headlight surround/bumper - David Brady - 10-16-2007 12:50 Hi Slim, Gluing is probably the best choice. The problem is that the original glue is gooped onto the surface and is impossible to remove w/o damaging the bumper. Whatever adhesive is chosen, it has to be very forgiving of the original glue remnants. The outer and inner bumpers are plastic. Anyone have additional suggestions for plastic to plastic adhesives? I assume that some sort of urethane would be the best. While I'm in there, I'm replacing the headlight clear plastic shield with 1/8" tempered glass. This may at some point become rock damaged. So, to add to the complexity, I'd like an adhesive which holds, but also allows me to disassemble the two parts if glass replacement becomes necessary... David Brady '02 LXi, NC somervillebus wrote: > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > Folks, > > > > Anyone have a solution for adhering the black bumper/ > > headlight surround on the front of the LXi. As many of > > you know, this faux bumper is merely a plastic outer > > shell (housing the turn signal and headlight coverings), glued > > to a plastic inner shell which holds four studs enabling the > > whole assembly to be attached to the front end-cap. On > > the LXi, the headlight surround often separates from the > > inner plastic shell. If one happens to lose a surround on the > > road, BB will provide a new one for the not-so-small sum > > of $1500 per side! Mine are working loose and I'd like > > to reattach them to the inner plastic shell. Anyone have a > > good solution for doing this? Glues, bolts, grommets, > > rivets... Any first hand experience? > > > > Thanks, > > David Brady > > '02 LXi, NC > > I used liquid nails to reinforce mine last year...so far so good. > There are different types of liquid nails, get the one that works on > plastic. Home Depot/Lowes I had no idea those cost that much. I will > be watching them closely. > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.488 / Virus Database: 269.14.12/1072 - Release Date: 10/15/2007 5:55 PM > [Non-text portions of this message have been removed] LXi headlight surround/bumper - somervillebus - 10-16-2007 13:16 David, I noticed at the RITV last year a couple of people had removed the clear plastic headlight cover completely from the cover assembly. To tell the truth it looked very nice. It beats the oxidized clear lens. I'll probably do the same if need be. I think in the meantime I'll go out and liquid nail the entire cover to the bus to keep them from being stolen after finding "ouch" what they cost. Slim Somerville 99 LXi Tennessee --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Hi Slim, > > Gluing is probably the best choice. The > problem is that the original glue is gooped onto > the surface and is impossible to remove w/o > damaging the bumper. Whatever adhesive is chosen, > it has to be very forgiving of the original glue > remnants. The outer and inner bumpers are plastic. > Anyone have additional suggestions for plastic to plastic > adhesives? I assume that some sort of urethane would > be the best. While I'm in there, I'm replacing the headlight > clear plastic shield with 1/8" tempered glass. This may > at some point become rock damaged. So, to add to > the complexity, I'd like an adhesive which holds, but > also allows me to disassemble the two parts if > glass replacement becomes necessary... > > David Brady > '02 LXi, NC > > somervillebus wrote: > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > Folks, > > > > > > Anyone have a solution for adhering the black bumper/ > > > headlight surround on the front of the LXi. As many of > > > you know, this faux bumper is merely a plastic outer > > > shell (housing the turn signal and headlight coverings), glued > > > to a plastic inner shell which holds four studs enabling the > > > whole assembly to be attached to the front end-cap. On > > > the LXi, the headlight surround often separates from the > > > inner plastic shell. If one happens to lose a surround on the > > > road, BB will provide a new one for the not-so-small sum > > > of $1500 per side! Mine are working loose and I'd like > > > to reattach them to the inner plastic shell. Anyone have a > > > good solution for doing this? Glues, bolts, grommets, > > > rivets... Any first hand experience? > > > > > > Thanks, > > > David Brady > > > '02 LXi, NC > > > > I used liquid nails to reinforce mine last year...so far so good. > > There are different types of liquid nails, get the one that works on > > plastic. Home Depot/Lowes I had no idea those cost that much. I will > > be watching them closely. > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.488 / Virus Database: 269.14.12/1072 - Release Date: 10/15/2007 5:55 PM > > > > > > [Non-text portions of this message have been removed] > LXi headlight surround/bumper - brad barton - 10-16-2007 13:43 Slim and David, I have the same problem..scratched hazed headlight covers..one of which had to be reglued. I like your idea of glass covers..maybe scrap auto glass. Cheaper window glass is probably okay though. I've enclosed a link to one of the many plastic headlight protectors. They're frequently used on older Mercedes whose headlight lenses are often $90 or more. When I bought my coach from Paul Davis, Ryan refinished the plastic bumper cover, but didn't polish the headlight covers. I have to replace the "A" water pump and toilet compressor. I assume I'll go back with OEM parts unless anyone has a better idea. Brad Barton 00LXiDFWbbartonwx@... To: WanderlodgeForum@...: somervillebus@...: Wed, 17 Oct 2007 01:16:56 +0000Subject: [WanderlodgeForum] Re: LXi headlight surround/bumper David,I noticed at the RITV last year a couple of people had removed the clear plastic headlight cover completely from the cover assembly. To tell the truth it looked very nice. It beats the oxidized clear lens. I'll probably do the same if need be. I think in the meantime I'll go out and liquid nail the entire cover to the bus to keep them from being stolen after finding "ouch" what they cost. Slim Somerville99 LXiTennessee--- In WanderlodgeForum@yahoogroups.com, David Brady problem is that the original glue is gooped onto> the surface and is impossible to remove w/o> damaging the bumper. Whatever adhesive is chosen,> it has to be very forgiving of the original glue> remnants. The outer and inner bumpers are plastic.> Anyone have additional suggestions for plastic to plastic> adhesives? I assume that some sort of urethane would> be the best. While I'm in there, I'm replacing the headlight> clear plastic shield with 1/8" tempered glass. This may> at some point become rock damaged. So, to add to> the complexity, I'd like an adhesive which holds, but> also allows me to disassemble the two parts if> glass replacement becomes necessary...> > David Brady> '02 LXi, NC> > somervillebus wrote:> >> > --- In WanderlodgeForum@yahoogroups.com > > >> > > Folks,> > >> > > Anyone have a solution for adhering the black bumper/> > > headlight surround on the front of the LXi. As many of> > > you know, this faux bumper is merely a plastic outer> > > shell (housing the turn signal and headlight coverings), glued> > > to a plastic inner shell which holds four studs enabling the> > > whole assembly to be attached to the front end-cap. On> > > the LXi, the headlight surround often separates from the> > > inner plastic shell. If one happens to lose a surround on the> > > road, BB will provide a new one for the not-so-small sum> > > of $1500 per side! Mine are working loose and I'd like> > > to reattach them to the inner plastic shell. Anyone have a> > > good solution for doing this? Glues, bolts, grommets,> > > rivets... Any first hand experience?> > >> > > Thanks,> > > David Brady> > > '02 LXi, NC> >> > I used liquid nails to reinforce mine last year...so far so good.> > There are different types of liquid nails, get the one that works on> > plastic. Home Depot/Lowes I had no idea those cost that much. I will> > be watching them closely.> >> > > > ----------------------------------------------------------------> >> > No virus found in this incoming message.> > Checked by AVG Free Edition. > > Version: 7.5.488 / Virus Database: 269.14.12/1072 - Release Date: 10/15/2007 5:55 PM> > > > > > [Non-text portions of this message have been removed]> _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Café. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_OctWLtagl\ ine [Non-text portions of this message have been removed] LXi headlight surround/bumper - g_man1146 - 10-17-2007 05:16 Slim, David, That is what I did to mine. Looks great and no more problems with dirt accumulating between the headlights and the "clear" cover. Works for me! Photo: http://www.photosleeve.com/d/292474-2/IMG_0928.JPG Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "somervillebus" <somervillebus@...> wrote: > > David, > > I noticed at the RITV last year a couple of people had removed the > clear plastic headlight cover completely from the cover assembly. > To tell the truth it looked very nice. It beats the oxidized clear > lens. I'll probably do the same if need be. I think in the meantime > I'll go out and liquid nail the entire cover to the bus to keep them > from being stolen after finding "ouch" what they cost. > > > > Slim Somerville > 99 LXi > Tennessee > LXi headlight surround/bumper - David Brady - 10-17-2007 13:18 Look'n good Rich. Thanks for the photo. David Brady '02 LXi, NC g_man1146 wrote: > > Slim, David, > That is what I did to mine. Looks great and no more problems with > dirt accumulating between the headlights and the "clear" cover. Works > for me! > Photo: http://www.photosleeve.com/d/292474-2/IMG_0928.JPG > <http://www.photosleeve.com/d/292474-2/IMG_0928.JPG> > > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com > > <somervillebus@...> wrote: > > > > David, > > > > I noticed at the RITV last year a couple of people had removed the > > clear plastic headlight cover completely from the cover assembly. > > To tell the truth it looked very nice. It beats the oxidized clear > > lens. I'll probably do the same if need be. I think in the meantime > > I'll go out and liquid nail the entire cover to the bus to keep > them > > from being stolen after finding "ouch" what they cost. > > > > > > > > Slim Somerville > > 99 LXi > > Tennessee > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.488 / Virus Database: 269.14.13/1074 - Release Date: 10/16/2007 2:14 PM > [Non-text portions of this message have been removed] |
