Water Pump Running - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water Pump Running (/showthread.php?tid=5969) |
Water Pump Running - erniecarpet@... - 11-11-2007 07:49 I found that in the street side cabinet- just under the slide out drawer-pull the drawer out, 2 screws holds the top. There you will see the hoses that go to the outside fill and hot water heater. Mine had come loose- and since you can't see this area, easily, I overlooked it. This is beside the bed. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] Water Pump Running - Scott Forman - 11-11-2007 11:27 Last night was the first time I have slept in my coach in total silence (i.e., no generator, no A/C, no fans, nothing). As a result, I was able to hear that every once in a while (maybe 20-30 minutes?) the water pump will kick on very briefly, like for maybe one second. There are no leaks in the plumbing that I have found. Is this normal? Scott Forman 86 PT38 Memphis Water Pump Running - krminyl@... - 11-11-2007 11:51 This has happened with my '86 a few times...it always indicated a leak...each time it was a small drip every minute or so at the water heater...once it was a leaking QEST (sp?) fitting (now all replaced), and the second time it was an actual leak in the water heater tank itself, requiring replacement of the water heater. I too have replaced the accumulator tank with a demand Shurflo 5.7gpm pump. Don't overlook it...you need to find the leak otherwise you could be in line for wood damage, carpeting, mold and mildew, etc. Good luck.... Kevin McKeown Yorba Linda, CA 1986 38' PT (For Sale...no leaks) ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] Water Pump Running - Bob Lawrence - 11-11-2007 12:32 Nope...probably have a very very small leak..So many hose clamps..so little time to find them all. Bob Lawrence 84 PT36 Fernly, Nv > Last night was the first time I have slept in my coach in total silence > (i.e., no generator, no A/C, no fans, nothing). As a result, I was > able to hear that every once in a while (maybe 20-30 minutes?) the > water pump will kick on very briefly, like for maybe one second. There > are no leaks in the plumbing that I have found. Is this normal? > > Scott Forman > 86 PT38 > Memphis > Water Pump Running - Rob Robinson - 11-11-2007 12:59 Scott if you have a Reverse Osmosis system like I have then the pump may come on from time to time. My RO system is always making RO water and when it's full it dumps the excess into the grey water tank. This process puts a drain on the pressure tank which drops the pressure and causes the pump to come on periodically. However, it does not come on every half hour as you say yours does. On 11/11/2007, Scott Forman <sforman@...> wrote: > > cLast night was the first time I have slept in my coach in total silence > > (i.e., no generator, no A/C, no fans, nothing). As a result, I was > able to hear that every once in a while (maybe 20-30 minutes?) the > water pump will kick on very briefly, like for maybe one second. There > are no leaks in the plumbing that I have found. Is this normal? > > Scott Forman > 86 PT38 > Memphis > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Water Pump Running - Pete Masterson - 11-11-2007 13:13 I have the 'demand' pump with no expansion tank. It doesn't run unless a faucet is on. If you get intermittent running, then there is a small leak somewhere -- but that can be tricky to find. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at On Nov 11, 2007, at 6:32 PM, Bob Lawrence wrote: > Nope...probably have a very very small leak..So many hose clamps..so > little time to find them all. > Bob Lawrence > 84 PT36 > Fernly, Nv >> Last night was the first time I have slept in my coach in total > silence >> (i.e., no generator, no A/C, no fans, nothing). As a result, I was >> able to hear that every once in a while (maybe 20-30 minutes?) the >> water pump will kick on very briefly, like for maybe one second. > There >> are no leaks in the plumbing that I have found. Is this normal? >> >> Scott Forman >> 86 PT38 >> Memphis >> > > > > > > Yahoo! Groups Links > > > Water Pump Running - Leroy Eckert - 11-12-2007 00:02 Another source could be the toilet tank guts. krminyl@... wrote: This has happened with my '86 a few times...it always indicated a leak...each time it was a small drip every minute or so at the water heater...once it was a leaking QEST (sp?) fitting (now all replaced), and the second time it was an actual leak in the water heater tank itself, requiring replacement of the water heater. I too have replaced the accumulator tank with a demand Shurflo 5.7gpm pump. Don't overlook it...you need to find the leak otherwise you could be in line for wood damage, carpeting, mold and mildew, etc. Good luck.... Kevin McKeown Yorba Linda, CA 1986 38' PT (For Sale...no leaks) ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
