Onan Cooling System Repair - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Onan Cooling System Repair (/showthread.php?tid=5970) |
Onan Cooling System Repair - birdshill123 - 11-11-2007 12:12 Bill Pape has written an excellent article about redoing the cooling system and insulating the generator compartment in his 88 FC. His article provided encouragement for me to do the same. I have posted some pictures in the photo section under " Onan Cooling System Repair" and will add this post to the files area with the same title. Unlike the earlier FC's, the Silver Editions (87 to 89) do not use a Perkins genset. Rather they utilize an Onan DKD 8.0 powered by a Kuboto diesel. It is not on a slide out and the compartment is very tight due to space limitations. BB chose to use pyramidal foam for sound insulation. This material is probably the best there is for sound attenuation but it is designed for broadcast studios not for the harsh environment of a diesel generator compartment that is partially open to the outside and subject to diesel fumes, road grime, water and dirt. Interestingly enough when I contacted BB they still sell and recommend that foam. After 20 years the foam in my compartment had deteriorated and was quickly falling off making a mess of the genset area. Just checking the oil required a Hazmat suit! Bill discovered that once you remove the genset there is a lot of other remedial work to be done. I concur. I have divided the article into 3 areas: tools and safety, parts required and R & R. TOOLS AND SAFETY Removing the Genset will require you to be under your Bird for extended periods. This cannot be done without raising the MH , unless you are very skinny. Looking at photos of the last RATS most of us will not qualify as "skinny" ! I used the HWH jacks to raise the Bird and then used jack stands, hydraulic jacks and an air over hydraulic jack . My Bird was "in the air" for almost 4 weeks and never moved. All the wheels were blocked. I keep a large fire extinguisher handy whenever fuel is involved. I also used some 3M dust masks when removing the insulation and glue. These are not the cheap masks that come in a 50 pack. They are in a 2 or 3 pack and considerably more expensive. Even better would be a real breathing apparatus. Most of the tools required are basic mechanic's hand tools. Bill used a wooden mover's dolly to hold the generator. I had one of those 2 wheeled dollies that you can find at Sam's and Costco. It has an extra set of wheels so that it can be used as a 4 wheel cart. Better yet would have been a pallet jack, motorcycle lift or even a transmission jack. Removing the foam insulation requires a good stiff putty knife. Most of it just falls off but lots of glue and dirt remains. I washed the whole area down with Simple Green. Then I used a knotted wire wheel on my 4.5 inch grinder. I was worried that a clean surface would be necessary for the new glue to work. You need a 17 mm. wrench to remove the adapter at the exhaust manifold. I used lots of PB blaster on some of the rusty sheet metal screws and the tailpipe clamps and hangers. My shop is well equipped so I was able to use air tools on stuck fasteners. PARTS REQUIRED We live in Mexico part of the year and that is where I did the work. Most parts had to come from Tucson or elsewhere so I was very careful about making sure I had everything that was necessary. You would not have that problem. I am not a big fan of NAPA as their parts prices are usually very high. I bought all the Gates hoses at http://www.rockauto.com . They are about 35 to 40 % less than NAPA. You can use this code over and over to get an additional 5% 8288812705329 The following are approximate prices: Hoses and clamps $205.00 Motors and blowers $260.36 Insulation $300.00 Glue $64.50 Thermostat, gasket and fan belt $35.00 Rad repair $142.00 As well there is the cost of many shop supplies: sheet metal screws ( I used stainless), paint, engine shampoo, wire ties, nuts and bolts, muffler clamps and hangers, freight, taxes and misc. The total probably approaches $1100.00 Bill Pape posted the part #'s for some of the above but I will recap and add some. Motor for Cooling fan 4M099 Blower for Cooling Fan 4C592 Small fan w/motor 4C448 One inch Gates hose 24916 This is for a 5 foot length You need 3 sticks Gates Rad hoses 21794 You will need 4 of these Onan 90 degree hose CH22038 This is a Gates # for the one inch molded hose . Onan wanted about $25.00 Glue 3M Super 90 spray adhesive Note that I only paid $142.00 for rad recore. This was done in Mexico. Figure on about $240.00 in the USA. My parts sources were as follows: Gates items http://www.rockauto.com Blowers,etc. Grainger Glue Home Depot Onan OEM parts Curtis Service Corp. 908-561-3393 Insulation: Due to some special circumstances I ordered my insulation through a Mexican company. BUT Steven Birtles is the best place for this product http://www.capeinnovation.com Wire ties http://www.happyterminals.com Bolts, screws: http://www.boltdepot.com R & R In order to remove the genie follow these steps: 1. Drain the rad 2. Remove the lower front panel of the compartment and the rad tank 3. 3. Remove fuel lines and cap ( fitting is JIC and available at any hose shop, Parker 6 PNTX-S) . Mark fuel lines for proper reinstall. Make note of hose routing. 4. Disconnect all the coach batteries and remove genset battery. While you have the battery out is a good time to charge it and then test. Mine had a dead cell. 5. There are 2 one inch cooling hoses that connect to the rad. MARK these and disconnect from the rad. 6. Disconnect the wiring at the large cooling fan. Also disconnect the ground cables at the back of the genset tray 7. Undo the exhaust pipe. I was unable to undo mine until the genie was removed. I removed the muffler and tied the pipe up. Once the genie was lowered I was able to use a long handled 17 mm wrench and a cheater. I had sprayed the bolts for 2 days! 8. There is a plastic wire connector on the back of the 12 volt control box that has to be unplugged. 9. As I stated I was using a dollie to hold the genset. I dumped the air and used the HWH jacks to raise the MH part way. I then used an air over hydraulic jack to lift the MH and slipped my dolly under the genset. This jack is easy to control. Once the dolly was under I SLOWLY lowered the MH until the genie was almost resting on the dolly. I jacked one end of the genie up slightly with a floor jack, removed the bolts and lowered onto the dolly. Did the same with the other 2 bolts. The other jacks I mentioned earlier would have made this much easier. 10. Next I jacked the MH up with the HWH and the air/hydraulic jack. This allowed me enough room to stick my head into the compartment and undo the high voltage cables. I made notes on the wiring layout. BB had marked the wires with wire tags. 11. With jackstands in place I crawled under and disconnected the 2 cooling hoses from the rad. 12. Now the genie was wheeled out!! 13. Next I undid the 4 bolts holding the rad and blower assembly to the MH . I used a floor jack under the rad guard. The above is almost the easy part. The removing of the insulation, cleaning , derusting and painting all the sheet metal, assembling the cooling fan and motor, cleaning the genie, replacing the thermostat onan hose and fan belt is very time consuming. I am fussy and used all new hardware. Either stainless or Grade 5 plated. Do not try and save $ by using other than the Gates wire reinforced hose. It is made for applications like this. Any other hose would either kink or deteriorate from the heat. I took digital pictures of most of the assembly so that I could route the lines and hoses just like the OEM. BB likes to assemble things without ever thinking that they may have to be serviced some day. The electrical connections in the fan box are ridiculous. Permanent crimps with some silly rubber condom that fits over the wires. I cut them and cursed! I used male and female extension cord ends for the new fan. My preference would be twist locks but I am 65 miles from those types of parts. The fan only draws about 3 amps. I removed the plywood firewall at the rear. Once it is off you can see all the cooling hoses and how they are connected. Again I marked everything. I used my bench grinder with a wire wheel to clean up all the one inch hose connectors and the one to one and a half inch adapters. I painted all the surfaces that were to be insulated with flat black paint The new insulation can be cut with an Olfa knife ( box cutter). I used the #M 90 spray adhesive and applied 2 coats to both the insulation and the other surface. It holds well. The rest of the job is simply reverse of the removal. I primed the engine with the electric fuel pump and it fired right away. I haven't taken it out of the shop to see if it is any quieter. This is not a one weekend job. Many hours are required to do a good job. Thanks go to Bill Pape who provided lots of advice!! Bruce 1988 FC35 |
