How many floor / levels does my black tank have? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How many floor / levels does my black tank have? (/showthread.php?tid=598) |
How many floor / levels does my black tank have? - Henry Claeys - 05-13-2005 15:05 Randy. (1) Thanks for your reply. Jim March had suggested a high pressure wash from above, through the commode, while your suggesting the reverse. Were you also suggesting a high pressure wash? (2) I don't have a high pressure washer. Which type/brand should I purchase if the high pressure washer is necessary. (3) Drain Valve. FYI, I had purchased a simple replacement valve because the old one was getting hard to close. I was planning on installing it over the weekend but then this happened meaning that I now have a new job to deal with before replacing the valve. Any advice on this matter is appreciated. Thanks. Henry@... 1979 FC 35, McAllen, Tx Date: Fri, 13 May 2005 16:52:59 -0400 From: randydupree Subject: Re: How many floors/levels does my black tank have? the tank is one level (two story outhouse?) and it has no baffles.sounds like all the liquid ran out leaving you a paper mache pie in the bottom.you may have to run a hose up the drain outlet to balst it free,wear a raincoat and wear gloves!! then,lets figure out the valve not closing deal! randydupree93wb http://www.dupreeproducts.com ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 13, 2005 2:19 PM Subject: [WanderlodgeForum] How many floors/levels does my black tank have? 1) I suspect that my black tank has a problem because I discovered, after 3 weeks of use, that the drain valve was not closing completely. (2) What confuses me is, even after apparently emptying the black system, I still see water when I look down the hole through the commode. Why is there water in the tank below the commode even after emptying the black tank? I never used to notice the water until I discovered the above described drain problem. Thanks. Henry@... 1979 FC 35, McAllen, Tx How many floor / levels does my black tank have? - randydupree - 05-13-2005 23:46 going down from the top is fine,as long as your drain is open.i have seen the drain pipe full of the "mud" as well as the tank,which will not allow it to drain.you may have to go at it from the bottom and the top,just make sure that it is draining so as not to flood the coach. a simple replacement valve must mean another type or brand valve?that means you will have to cut and glue the pipe etc.if you just fix the valve on the coach it takes only 5 minutes and $22 ! randydupree93wb ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 13, 2005 11:05 PM Subject: [WanderlodgeForum] How many floor / levels does my black tank have? Randy. (1) Thanks for your reply. Jim March had suggested a high pressure wash from above, through the commode, while your suggesting the reverse. Were you also suggesting a high pressure wash? (2) I don't have a high pressure washer. Which type/brand should I purchase if the high pressure washer is necessary. (3) Drain Valve. FYI, I had purchased a simple replacement valve because the old one was getting hard to close. I was planning on installing it over the weekend but then this happened meaning that I now have a new job to deal with before replacing the valve. Any advice on this matter is appreciated. Thanks. Henry@... 1979 FC 35, McAllen, Tx Date: Fri, 13 May 2005 16:52:59 -0400 From: randydupree Subject: Re: How many floors/levels does my black tank have? the tank is one level (two story outhouse?) and it has no baffles.sounds like all the liquid ran out leaving you a paper mache pie in the bottom.you may have to run a hose up the drain outlet to balst it free,wear a raincoat and wear gloves!! then,lets figure out the valve not closing deal! randydupree93wb http://www.dupreeproducts.com ----- Original Message ----- From: Henry Claeys To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 13, 2005 2:19 PM Subject: [WanderlodgeForum] How many floors/levels does my black tank have? 1) I suspect that my black tank has a problem because I discovered, after 3 weeks of use, that the drain valve was not closing completely. (2) What confuses me is, even after apparently emptying the black system, I still see water when I look down the hole through the commode. Why is there water in the tank below the commode even after emptying the black tank? I never used to notice the water until I discovered the above described drain problem. Thanks. Henry@... 1979 FC 35, McAllen, Tx ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
