chassis heater problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: chassis heater problem (/showthread.php?tid=5990) Pages: 1 2 |
chassis heater problem - erniecarpet@... - 11-15-2007 04:36 Robert, I assume you have the front chassis thermostat set to a warmer temp. And you have the winter/summer switch, the front heat switch to on.and the aux pump switched to on. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] chassis heater problem - erniecarpet@... - 11-15-2007 04:39 Oh- and you can visually check your small water pumps to see that they are moving- thus insuring coolant movement. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] chassis heater problem - Robert & Teri Rahn - 11-15-2007 06:33 I have been trying to figure this situation out for several days now and cant seem to solve it. The chassis heater under the sofa up front and the dash heaters do not blow hot air, All the other ones work great. This morning I replaced the two sporlan valves in the back with manual valves to make sure they werent the problem and they werent. The auxillary pump works and runs but is it possible that it is not working good enough? I thought that there may be air in the lines up front so I installed a valve with a female hose connector in the wheelwell under the sofa chassis heater. There was a lot of coolant in that line and it was quite a mess to put it on. I did put hose pressure on after I installed it and it quickly started to overflow out of the coolannt cap that was removed. I located a small bleed screw on the line below the dash heater and coolant sprayed out of it as soon as I loosened it. What should I do, im sure puzzled. Should I put another t in somewhere with a valve on either side and then hook the hose to it and shut one side then the other to clear any possible blocks, or am I overlooking some component. Robert Rahn 88 pt 40 warner robins ga chassis heater problem - pattypape - 11-15-2007 08:14 Robert, Our front radiator FC has three Sporlan valves, and two gate valves, although the drawing shows three gate valves. Your rear radiator is probably plumbed different, But my guess is: you have not found all the valves , look for another Sporlan valve (maybe up front, near the cold heater) and another gate valve. Do you have a front heater switch on the dash?????? Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > I have been trying to figure this situation out for several days now > and cant seem to solve it. The chassis heater under the sofa up front > and the dash heaters do not blow hot air, All the other ones work > great. This morning I replaced the two sporlan valves in the back > with manual valves to make sure they werent the problem and they > werent. The auxillary pump works and runs but is it possible that it > is not working good enough? I thought that there may be air in the > lines up front so I installed a valve with a female hose connector in > the wheelwell under the sofa chassis heater. There was a lot of > coolant in that line and it was quite a mess to put it on. I did put > hose pressure on after I installed it and it quickly started to > overflow out of the coolannt cap that was removed. I located a small > bleed screw on the line below the dash heater and coolant sprayed out > of it as soon as I loosened it. > > What should I do, im sure puzzled. Should I put another t in > somewhere with a valve on either side and then hook the hose to it > and shut one side then the other to clear any possible blocks, or am > I overlooking some component. > > Robert Rahn > 88 pt 40 > warner robins ga > chassis heater problem - Robert & Teri Rahn - 11-15-2007 10:43 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: >The water pump is definately working and I cant find any more valves other than the two sporlin valves and the five red handle valves. I wish I had some sort of map showing where everything was going. I can feel the lines up front and they are cold for sure and the ones in the real are warm. > Oh- and you can visually check your small water pumps to see that they are > moving- thus insuring coolant movement. > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > chassis heater problem - erniecarpet@... - 11-15-2007 20:31 Robert, maybe I should have been a little bit more clear on the pumps I was referring too. I did not mean the engine water pump, rather the 2 small booster pumps located by the sporlan valves. On mine, you can see the shaft rotation when they are in operation. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] chassis heater problem - sfedeli3 - 11-16-2007 02:24 Robert, It took me two years to figure out that one of the gate valves was not opening- even though the handle was turning. My guess is that the gate valve controlling flow to or from the front loop is closed- permanently. I know I hated to do it, but eventually you should check to make sure that the threads are not stripped in the gate on the valves. Most of the innards can be removed without pulling the hoses off. You just have to hold the body firmly with a large wrench while unscrewing the valve shaft and gate assembly. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > I have been trying to figure this situation out for several days now > and cant seem to solve it. The chassis heater under the sofa up front > and the dash heaters do not blow hot air, All the other ones work > great. This morning I replaced the two sporlan valves in the back > with manual valves to make sure they werent the problem and they > werent. The auxillary pump works and runs but is it possible that it > is not working good enough? I thought that there may be air in the > lines up front so I installed a valve with a female hose connector in > the wheelwell under the sofa chassis heater. There was a lot of > coolant in that line and it was quite a mess to put it on. I did put > hose pressure on after I installed it and it quickly started to > overflow out of the coolannt cap that was removed. I located a small > bleed screw on the line below the dash heater and coolant sprayed out > of it as soon as I loosened it. > > What should I do, im sure puzzled. Should I put another t in > somewhere with a valve on either side and then hook the hose to it > and shut one side then the other to clear any possible blocks, or am > I overlooking some component. > > Robert Rahn > 88 pt 40 > warner robins ga > chassis heater problem - Robert & Teri Rahn - 11-16-2007 05:24 Shane that is great news becaus the valve that seems to remain cold is the one next to the transmission dipstick and looks to be very difficult to remove. Is that the one that went bad on yours? RObert -- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Robert, > > It took me two years to figure out that one of the gate valves was not > opening- even though the handle was turning. My guess is that the gate > valve controlling flow to or from the front loop is closed- > permanently. I know I hated to do it, but eventually you should check > to make sure that the threads are not stripped in the gate on the > valves. Most of the innards can be removed without pulling the hoses > off. You just have to hold the body firmly with a large wrench while > unscrewing the valve shaft and gate assembly. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > > > > I have been trying to figure this situation out for several days now > > and cant seem to solve it. The chassis heater under the sofa up front > > and the dash heaters do not blow hot air, All the other ones work > > great. This morning I replaced the two sporlan valves in the back > > with manual valves to make sure they werent the problem and they > > werent. The auxillary pump works and runs but is it possible that it > > is not working good enough? I thought that there may be air in the > > lines up front so I installed a valve with a female hose connector in > > the wheelwell under the sofa chassis heater. There was a lot of > > coolant in that line and it was quite a mess to put it on. I did put > > hose pressure on after I installed it and it quickly started to > > overflow out of the coolannt cap that was removed. I located a small > > bleed screw on the line below the dash heater and coolant sprayed out > > of it as soon as I loosened it. > > > > What should I do, im sure puzzled. Should I put another t in > > somewhere with a valve on either side and then hook the hose to it > > and shut one side then the other to clear any possible blocks, or am > > I overlooking some component. > > > > Robert Rahn > > 88 pt 40 > > warner robins ga > > > chassis heater problem - Howard O. Truitt - 11-16-2007 05:30 Robert, I have switch[s] on the dash that must be own for the front heaters to work. Howard Truitt, Camilla, Ga. 86 PT40 ----- Original Message ----- From: Robert & Teri Rahn To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 15, 2007 1:33 PM Subject: [WanderlodgeForum] chassis heater problem I have been trying to figure this situation out for several days now and cant seem to solve it. The chassis heater under the sofa up front and the dash heaters do not blow hot air, All the other ones work great. This morning I replaced the two sporlan valves in the back with manual valves to make sure they werent the problem and they werent. The auxillary pump works and runs but is it possible that it is not working good enough? I thought that there may be air in the lines up front so I installed a valve with a female hose connector in the wheelwell under the sofa chassis heater. There was a lot of coolant in that line and it was quite a mess to put it on. I did put hose pressure on after I installed it and it quickly started to overflow out of the coolannt cap that was removed. I located a small bleed screw on the line below the dash heater and coolant sprayed out of it as soon as I loosened it. What should I do, im sure puzzled. Should I put another t in somewhere with a valve on either side and then hook the hose to it and shut one side then the other to clear any possible blocks, or am I overlooking some component. Robert Rahn 88 pt 40 warner robins ga ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.486 / Virus Database: 269.15.34/1134 - Release Date: 11/16/2007 9:52 AM [Non-text portions of this message have been removed] chassis heater problem - sfedeli3 - 11-16-2007 22:22 Robert- It was the valve that closes the line coming out of the water pump body. I would have never known, had I not pulled the water pump and replaced it this past summer. The gate valves are made to service, and the cap around the shaft has threads and can be spun off- allowing you to remove the gate altogether. Removing the whole valve assembly would be nearly impossible without removing the water pump. Just be ready to stuff a rag or some putty in the hole to keep the coolant from draining while you shop around for a replacement gate. A large plumbing supply house should be able to get you one. -Shane --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > Shane that is great news becaus the valve that seems to remain cold > is the one next to the transmission dipstick and looks to be very > difficult to remove. Is that the one that went bad on yours? RObert > -- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> > wrote: > > > > Robert, > > > > It took me two years to figure out that one of the gate valves was > not > > opening- even though the handle was turning. My guess is that the > gate > > valve controlling flow to or from the front loop is closed- > > permanently. I know I hated to do it, but eventually you should > check > > to make sure that the threads are not stripped in the gate on the > > valves. Most of the innards can be removed without pulling the hoses > > off. You just have to hold the body firmly with a large wrench while > > unscrewing the valve shaft and gate assembly. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > |
