Propane Heater Removal - COMPLETED - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Propane Heater Removal - COMPLETED (/showthread.php?tid=5997) |
Propane Heater Removal - COMPLETED - akav8r - 11-16-2007 14:24 Just a word of THANKS for all of your input on my heater removal problem. I was able to remove two of them today with a bit more pushing, pulling, and prying. Dru my situation was the same as yours, I had to remove the complete unit before taking the "guts" out of the case. Two screws in the front and completely remove the outside plate(pushing/prying)and of course gas and elec. connections inside then came the pulling. I had my local LP tech out today to check my system out for leaks etc. I have one furnace that seems to work properly, one that will not light, and one that is full of dirt from bugs. My next step is to clean and troubleshoot these units.(more questions for the group????) Also had my fridge, stove top and oven checked as well with no aparent problems. ![]() THANKS again - until my next problem. Wendel, GA 82 FC35 SB "Momentary lapse of reason" |
