88 pt 40 how many alternators? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 88 pt 40 how many alternators? (/showthread.php?tid=6002) |
88 pt 40 how many alternators? - Robert & Teri Rahn - 11-17-2007 10:29 I was just cleaning up the engine after my recent coolant valve repairs and noticed a belt hanging way up in front of the engine. It appears that the alternator belt or belts are broken and off. This alternator is up high in front of the motor and although easy to see looks quite difficult to access for the belt repair. Are there two alternators? What is the best method for this repair? Robert Rahn 1988 pt 40 Warner Robins, Ga 88 pt 40 how many alternators? - Don Bradner - 11-17-2007 10:40 Should be a metal plate under the bed, directly above that alternator. About a zillion screws around the outside - oh the joys of modern power screwdrivers! Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 11/17/2007 at 10:29 PM Robert & Teri Rahn wrote: >I was just cleaning up the engine after my recent coolant valve repairs >and noticed a belt hanging way up in front of the engine. It appears >that the alternator belt or belts are broken and off. This alternator >is up high in front of the motor and although easy to see looks quite >difficult to access for the belt repair. Are there two alternators? >What is the best method for this repair? > >Robert Rahn >1988 pt 40 >Warner Robins, Ga 88 pt 40 how many alternators? - Mike McMahan - 11-17-2007 10:43 Robert, My 89 PT 40 had two alternators. The one you are seeing on top of the motor can be accessed easily from a trap door under the bed. The other alternator is on the passenger side of the coach at the back of the bus. Look to the inside of the frame rail and you will see it roughly under the ac compressor. It is actually harder to service that the upper unit. Mike Mcmahan 96 PT 42 --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > I was just cleaning up the engine after my recent coolant valve repairs > and noticed a belt hanging way up in front of the engine. It appears > that the alternator belt or belts are broken and off. This alternator > is up high in front of the motor and although easy to see looks quite > difficult to access for the belt repair. Are there two alternators? > What is the best method for this repair? > > Robert Rahn > 1988 pt 40 > Warner Robins, Ga > 88 pt 40 how many alternators? - Rob Robinson - 11-17-2007 18:57 Mike and Don have given you the spoken truth. I and Randy Dupree have done this several times. As Don says the trap door is there so go for it. Cover all surfaces, especially the bed OK. While in there replace the lines to the compressor. Curt will chime in here with more expertise. He and Randy are the experienced guys on these two lines. Believe me when I say those two lines are failing and this is your chance to save yourself $20K. On 17/11/2007, Don Bradner > > Should be a metal plate under the bed, directly above that alternator. > About a zillion screws around the outside - oh the joys of modern power > screwdrivers! > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > On 11/17/2007 at 10:29 PM Robert & Teri Rahn wrote: > > >I was just cleaning up the engine after my recent coolant valve repairs > >and noticed a belt hanging way up in front of the engine. It appears > >that the alternator belt or belts are broken and off. This alternator > >is up high in front of the motor and although easy to see looks quite > >difficult to access for the belt repair. Are there two alternators? > >What is the best method for this repair? > > > >Robert Rahn > >1988 pt 40 > >Warner Robins, Ga > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] 88 pt 40 how many alternators? - Don Bradner - 11-17-2007 19:11 The way I read Randy's post about the compressor coolant line, I thought it was necessary to access from below. You are saying it is accessible from above? Where should I look, in relation to looking down right above the alternator? Having replaced that alternator I have no problems with accessing things through that hole. On 11/17/2007 at 10:57 PM Rob Robinson wrote: >Mike and Don have given you the spoken truth. I and Randy Dupree have done >this several times. As Don says the trap door is there so go for it. Cover >all surfaces, especially the bed OK. While in there replace the lines to >the >compressor. Curt will chime in here with more expertise. He and Randy are >the experienced guys on these two lines. Believe me when I say those two >lines are failing and this is your chance to save yourself $20K. > > >On 17/11/2007, Don Bradner >> >> Should be a metal plate under the bed, directly above that alternator. >> About a zillion screws around the outside - oh the joys of modern power >> screwdrivers! >> >> Don Bradner >> 90 PT40 "Blue Thunder" >> Eureka, CA >> >> On 11/17/2007 at 10:29 PM Robert & Teri Rahn wrote: >> >> >I was just cleaning up the engine after my recent coolant valve repairs >> >and noticed a belt hanging way up in front of the engine. It appears >> >that the alternator belt or belts are broken and off. This alternator >> >is up high in front of the motor and although easy to see looks quite >> >difficult to access for the belt repair. Are there two alternators? >> >What is the best method for this repair? >> > >> >Robert Rahn >> >1988 pt 40 >> >Warner Robins, Ga >> >> >> > > > >-- >Rob, Sue & Merlin Robinson >94 WLWB > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > 88 pt 40 how many alternators? - Rob Robinson - 11-17-2007 19:27 Don first of all I'm fwding your email directly to Randy OK. Secondly there are two lines to the compressor. The end of one is easily accessible from the trap door we are talking about. The rest of the story is another question. The second line comes from below and over the top of the engine. Both Randy and Curt Sprenger have done this job and it is not for the layman. I don't want the scare you but this is a real concern for any BB over ten years old. Last week Randy had a fellow drop by and while he pointed out the two problem hoses (gentle nudge) the whole f$#king thing fell apart, coolant shower and Randy had a two day job instead of the planed 3 hour tune up. Everyone of you out there should be checking these coolant lines. On 17/11/2007, Don Bradner > > The way I read Randy's post about the compressor coolant line, I thought > it was necessary to access from below. You are saying it is accessible from > above? Where should I look, in relation to looking down right above the > alternator? Having replaced that alternator I have no problems with > accessing things through that hole. > > On 11/17/2007 at 10:57 PM Rob Robinson wrote: > > >Mike and Don have given you the spoken truth. I and Randy Dupree have > done > >this several times. As Don says the trap door is there so go for it. > Cover > >all surfaces, especially the bed OK. While in there replace the lines to > >the > >compressor. Curt will chime in here with more expertise. He and Randy are > >the experienced guys on these two lines. Believe me when I say those two > >lines are failing and this is your chance to save yourself $20K. > > > > > >On 17/11/2007, Don Bradner > wrote: > >> > >> Should be a metal plate under the bed, directly above that alternator. > >> About a zillion screws around the outside - oh the joys of modern power > >> screwdrivers! > >> > >> Don Bradner > >> 90 PT40 "Blue Thunder" > >> Eureka, CA > >> > >> On 11/17/2007 at 10:29 PM Robert & Teri Rahn wrote: > >> > >> >I was just cleaning up the engine after my recent coolant valve > repairs > >> >and noticed a belt hanging way up in front of the engine. It appears > >> >that the alternator belt or belts are broken and off. This alternator > >> >is up high in front of the motor and although easy to see looks quite > >> >difficult to access for the belt repair. Are there two alternators? > >> >What is the best method for this repair? > >> > > >> >Robert Rahn > >> >1988 pt 40 > >> >Warner Robins, Ga > >> > >> > >> > > > > > > > >-- > >Rob, Sue & Merlin Robinson > >94 WLWB > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] 88 pt 40 how many alternators? - Rob Robinson - 11-17-2007 21:12 Robert my mistake on identities. My apologies. The info I provided stands and if it was my rig I'd replace them both. I am not fooling with you or anyone on this issue. We are warning you about a possible major engine failure so please, as a minimum, check the lines, or better replace them.. On 17/11/2007, Robert & Teri Rahn > > I was just cleaning up the engine after my recent coolant valve repairs > and noticed a belt hanging way up in front of the engine. It appears > that the alternator belt or belts are broken and off. This alternator > is up high in front of the motor and although easy to see looks quite > difficult to access for the belt repair. Are there two alternators? > What is the best method for this repair? > > Robert Rahn > 1988 pt 40 > Warner Robins, Ga > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] 88 pt 40 how many alternators? - ciao70@... - 11-17-2007 22:04 Mike...can you describe how you replaced these coolant lines on the road. Did you remove the starter? etc. thanks Jim Barone 1991WLWB in Tubac AZ. ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] 88 pt 40 how many alternators? - Robert & Teri Rahn - 11-18-2007 01:58 Okay so I access the alternator from the hole under the bed. Sounds great. What are the compressor lines? There is a compressor in the cooling system? Sounds like the lines will fail and cause the engine problems then that is the 20 thousand dollars? Im sold for sure, but where do I get these lines, coachworks? Robert Rahn 1988 pt 40 Warner Robins. Ga. In WanderlodgeForum@yahoogroups.com, "Rob Robinson" wrote: > > Don first of all I'm fwding your email directly to Randy OK. Secondly there > are two lines to the compressor. The end of one is easily accessible from > the trap door we are talking about. The rest of the story is another > question. The second line comes from below and over the top of the engine. > Both Randy and Curt Sprenger have done this job and it is not for the > layman. I don't want the scare you but this is a real concern for any BB > over ten years old. Last week Randy had a fellow drop by and while he > pointed out the two problem hoses (gentle nudge) the whole f$#king thing > fell apart, coolant shower and Randy had a two day job instead of the planed > 3 hour tune up. Everyone of you out there should be checking these coolant > lines. > > On 17/11/2007, Don Bradner > > > > The way I read Randy's post about the compressor coolant line, I thought > > it was necessary to access from below. You are saying it is accessible from > > above? Where should I look, in relation to looking down right above the > > alternator? Having replaced that alternator I have no problems with > > accessing things through that hole. > > > > On 11/17/2007 at 10:57 PM Rob Robinson wrote: > > > > >Mike and Don have given you the spoken truth. I and Randy Dupree have > > done > > >this several times. As Don says the trap door is there so go for it. > > Cover > > >all surfaces, especially the bed OK. While in there replace the lines to > > >the > > >compressor. Curt will chime in here with more expertise. He and Randy are > > >the experienced guys on these two lines. Believe me when I say those two > > >lines are failing and this is your chance to save yourself $20K. > > > > > > > > >On 17/11/2007, Don Bradner > > wrote: > > >> > > >> Should be a metal plate under the bed, directly above that alternator. > > >> About a zillion screws around the outside - oh the joys of modern power > > >> screwdrivers! > > >> > > >> Don Bradner > > >> 90 PT40 "Blue Thunder" > > >> Eureka, CA > > >> > > >> On 11/17/2007 at 10:29 PM Robert & Teri Rahn wrote: > > >> > > >> >I was just cleaning up the engine after my recent coolant valve > > repairs > > >> >and noticed a belt hanging way up in front of the engine. It appears > > >> >that the alternator belt or belts are broken and off. This alternator > > >> >is up high in front of the motor and although easy to see looks quite > > >> >difficult to access for the belt repair. Are there two alternators? > > >> >What is the best method for this repair? > > >> > > > >> >Robert Rahn > > >> >1988 pt 40 > > >> >Warner Robins, Ga > > >> > > >> > > >> > > > > > > > > > > > >-- > > >Rob, Sue & Merlin Robinson > > >94 WLWB > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > 88 pt 40 how many alternators? - robert nloomas - 11-18-2007 02:51 --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" When I replace the cooling lines on the air compressor I was not able to reach them from the top.Had to do the job from below and under the coach useing a off set 7/8 open end wrench.Yes it is a nasty dirty job one that needs to be done on the older birds. Bob Loomas 1985 PT 36 > > Mike and Don have given you the spoken truth. I and Randy Dupree have done > this several times. As Don says the trap door is there so go for it. Cover > all surfaces, especially the bed OK. While in there replace the lines to the > compressor. Curt will chime in here with more expertise. He and Randy are > the experienced guys on these two lines. Believe me when I say those two > lines are failing and this is your chance to save yourself $20K. > > > On 17/11/2007, Don Bradner > > > > Should be a metal plate under the bed, directly above that alternator. > > About a zillion screws around the outside - oh the joys of modern power > > screwdrivers! > > > > Don Bradner > > 90 PT40 "Blue Thunder" > > Eureka, CA > > > > On 11/17/2007 at 10:29 PM Robert & Teri Rahn wrote: > > > > >I was just cleaning up the engine after my recent coolant valve repairs > > >and noticed a belt hanging way up in front of the engine. It appears > > >that the alternator belt or belts are broken and off. This alternator > > >is up high in front of the motor and although easy to see looks quite > > >difficult to access for the belt repair. Are there two alternators? > > >What is the best method for this repair? > > > > > >Robert Rahn > > >1988 pt 40 > > >Warner Robins, Ga > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
