Can I weld on my exhaust. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Can I weld on my exhaust. (/showthread.php?tid=6003) |
Can I weld on my exhaust. - antique405@... - 11-17-2007 06:29 Johnny. All my auto information states that if you are going to weld on the vehicle to disconnect the battery. Paul Downey Versailles Ky 83PT 35 ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] Can I weld on my exhaust. - Johnny M Slone - 11-17-2007 11:21 My exhaust needs some repair where the stack attaches to the muffler. Is it possible to weld a new piece of pipe without removing the muffler from the coach. It would be an easy fix if welding will not harm any of the electronics. Any body have any experience doing this. Thanks, Johnny M Slone Pikevile, Ky 98 LXI 41 Can I weld on my exhaust. - Rob Robinson - 11-17-2007 11:41 Nope On 17/11/2007, Johnny M Slone > > My exhaust needs some repair where the stack attaches to the muffler. > Is it possible to weld a new piece of pipe without removing the muffler > from the coach. It would be an easy fix if welding will not harm any of > the electronics. > Any body have any experience doing this. > Thanks, > Johnny M Slone > Pikevile, Ky > 98 LXI 41 > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Can I weld on my exhaust. - Curt Sprenger - 11-17-2007 13:35 That's good advise for sure! But, I've welded on many vehicles, did not disconnect the battery, being sure the ground clamp is close to the area that's getting the weld process; so far so good. I would not put the ground clamp on the front or the rear of the vehicle and weld on the opposite end of the vehicle. On Nov 17, 2007 3:29 PM, > Johnny. All my auto information states that if you are going to weld on > the > vehicle to disconnect the battery. > > Paul Downey > Versailles Ky > 83PT 35 > > > ************************************** See what's new at > http://www.aol.com > > [Non-text portions of this message have been removed] > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] Can I weld on my exhaust. - Leroy Eckert - 11-17-2007 15:48 Disconnecting the battery is probably a good idea just in case. However, I have had many exhaust systems installed on cars installed at the muffler shop and I have yet to see a shop disconnect the battery. Curt Sprenger That's good advise for sure! But, I've welded on many vehicles, did not disconnect the battery, being sure the ground clamp is close to the area that's getting the weld process; so far so good. I would not put the ground clamp on the front or the rear of the vehicle and weld on the opposite end of the vehicle. On Nov 17, 2007 3:29 PM, > Johnny. All my auto information states that if you are going to weld on > the > vehicle to disconnect the battery. > > Paul Downey > Versailles Ky > 83PT 35 > > > ************************************** See what's new at > http://www.aol.com > > [Non-text portions of this message have been removed] > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA --------------------------------- Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. [Non-text portions of this message have been removed] Can I weld on my exhaust. - Gregory OConnor - 11-18-2007 14:41 I weld on many cars and tractors and never disconnect the battery, 'always intend too'. The added step cant hurt and it is a good practice, 'I forget to put the seat down also'. I welded a few things to my bus and ran a plasma cutter over some steel and only disconnected it from shore power to keep the ground path out of the shore line. I think the key is to grind a very good ground point for the welder to return the current (design a path of least resistance). I can see having the motorhome plugged into shore may prove an issue?? Remember that the weld will repair the result of a problem and a strong weld will pass the weak link to another stress area like a $$$ casted manifold. Some times it is best to fit a sleeve over a crack and U bolt it inplace (allows movement where the crack-failure proved movement is needed) or replace all the rubber hangers and or motormounts that were the cause of the resulted muffler system crack. The failure cause may also have been excessive heat or rust. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Johnny M Slone" > > My exhaust needs some repair where the stack attaches to the muffler. > Is it possible to weld a new piece of pipe without removing the muffler > from the coach. It would be an easy fix if welding will not harm any of > the electronics. > Any body have any experience doing this. > Thanks, > Johnny M Slone > Pikevile, Ky > 98 LXI 41 > Can I weld on my exhaust. - Glenn Allen - 11-19-2007 01:44 I hit a low hanging limb with our farm tractor and cracked the exhaust where the pipe enters the muffler. I was able to weld the two back together. This has been about 6 years ago and it is still holding today. Just make sure that where you weld is not rusted very much (only surface rust that can be removed). You will need enough metal thickness to support the depth of weld. If you are not a welder, find someone with a MIG or TIG welder to do the work. Glenn Allen 1986 PT-40 Marietta, GA --- In WanderlodgeForum@yahoogroups.com, "Johnny M Slone" > > My exhaust needs some repair where the stack attaches to the muffler. > Is it possible to weld a new piece of pipe without removing the muffler > from the coach. It would be an easy fix if welding will not harm any of > the electronics. > Any body have any experience doing this. > Thanks, > Johnny M Slone > Pikevile, Ky > 98 LXI 41 > Can I weld on my exhaust. - Johnny M Slone - 11-20-2007 12:46 --- In WanderlodgeForum@yahoogroups.com, "Glenn Allen" wrote: > > I hit a low hanging limb with our farm tractor and cracked the exhaust > where the pipe enters the muffler. I was able to weld the two back > together. This has been about 6 years ago and it is still holding > today. Just make sure that where you weld is not rusted very much > (only surface rust that can be removed). You will need enough metal > thickness to support the depth of weld. > > If you are not a welder, find someone with a MIG or TIG welder to do > the work. > > Glenn Allen > 1986 PT-40 > Marietta, GA > > --- In WanderlodgeForum@yahoogroups.com, "Johnny M Slone" > > > > > My exhaust needs some repair where the stack attaches to the muffler. > > Is it possible to weld a new piece of pipe without removing the > muffler > > from the coach. It would be an easy fix if welding will not harm any > of > > the electronics. > > Any body have any experience doing this. > > Thanks, > > Johnny M Slone > > Pikevile, Ky > > 98 LXI 41 > > >Thanks for all the advice. I'm going to disconnect the batteries and make the repair without removing the muffler. Johnny M Slone Pikeville, KY 98 LXI |
