Tag Axle Ride Height - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Tag Axle Ride Height (/showthread.php?tid=6006) |
Tag Axle Ride Height - Scott Forman - 11-18-2007 09:48 I feel like my tag axle is riding higher than it should, it it controlled by the same height control valves as the ther axles? Scott Forman 86 PT38 Memphis Tag Axle Ride Height - Glenn Allen - 11-19-2007 01:29 There should be a separate air pressure control valve for the Tag. I believe the ride height is controlled by the drive axle and the front axle. The tag has a pressure reducing valve that determines how much of the load it takes off the drive axle and adds to the tag/front. You can increase/decrease the tag air pressure by adjusting the PR valve on the cross member just in front of the transmission. If you don't get enough pressure on tag, the front axle could run light and the drive axle could run heavy. Also, in heavy braking, the tag can lock up if the tire does not have enough down force keeping it in contact with the road. Of course, I typing all of this from memory (dangerous). I will check my book later today to confirm my therories ![]() Glenn Allen 1986 PT-40 Marietta, GA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I feel like my tag axle is riding higher than it should, it it > controlled by the same height control valves as the ther axles? > > Scott Forman > 86 PT38 > Memphis > |
