6v92 cooling fan stuck - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 6v92 cooling fan stuck (/showthread.php?tid=6017) |
6v92 cooling fan stuck - krazykerley - 11-20-2007 16:35 I have an 83 PT40 with 6v92. My cooling fan is always on. Has anyone had any issues with this? 6v92 cooling fan stuck - erniecarpet@... - 11-20-2007 21:00 On the rear of your engine, there is a sensor with 2 wires coming from it. The wires, if removed, will tell the fan to come on. Those wires go to a relay behind the tag axle mud flap that directs the hydraulics to activate the fan. I don't believe it would hurt that your fan stays on. Ernie Ekberg 83PT40 Weatherford, Tx **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) [Non-text portions of this message have been removed] 6v92 cooling fan stuck - ronmarabito2002 - 11-21-2007 03:15 Two things to check. First make sure you do not have your fan override switch in the on position on the dash, then if it is still on, your alarmstat on the rear of the engine is bad and needs to be replaced. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "krazykerley" > > I have an 83 PT40 with 6v92. My cooling fan is always on. Has anyone > had any issues with this? > 6v92 cooling fan stuck - antique405@... - 11-21-2007 07:04 My 83 did not have the overide but i installed one. Looking at the engine on the left head you will see a brass switch screwed into the head, or i think it is the head. There will be a air line on the top and bottom of the switch. This controls the air pressure going to the fan switch. The system uses air pressure to keep the fan off i guess so if you loose air on the system the fan will run. You need to check and make sure you have air pressure to the switch which should be the lower one. The line going to the switch runs along the top of the engine to the rear. If you have air on the incoming line you can put air pressure on the other line and see if the fan shuts off. Paul Downey Versailles Ky 83PT35 Our Rollin Home **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) [Non-text portions of this message have been removed] 6v92 cooling fan stuck - krazykerley - 11-21-2007 14:32 Yes, I don't have a fan over switch either. It does have that 'air switch' on the drivers side head...or actually i think its in a house near it. Anyway I have air to it and going through it. I can bypass it and put or to it or just unhook it and it stays running all the time. It is supposed to cut into fuel economy and horsepower of the coach if it runs all the time. Definitely won't overheat though. 6v92 cooling fan stuck - krazykerley - 11-21-2007 14:33 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > On the rear of your engine, there is a sensor with 2 wires coming from it. > The wires, if removed, will tell the fan to come on. Those wires go to a relay > behind the tag axle mud flap that directs the hydraulics to activate the fan. > I don't believe it would hurt that your fan stays on. > > Ernie Ekberg > 83PT40 > Weatherford, Tx > > > > > **************************************Check out AOL's list of 2007's hottest > products. > (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) > > > [Non-text portions of this message have been removed] > I don't seem to have any electrical sensors like that and I dont have a fan overide also...? 6v92 cooling fan stuck - erniecarpet@... - 11-21-2007 20:37 I don't have a fan over-ride switch either. Those didn't come standard till the 84 models. Ernie Ekberg 83PT40 Weatherford, Tx **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) [Non-text portions of this message have been removed] 6v92 cooling fan stuck - antique405@... - 11-21-2007 20:46 If you put air pressure on the line going to the front of the engine and the fan still runs you have a problem with the switch that controls the fan. I have not been into that part of the system YET. Hopefully someone has been into that part of the system. Paul Downey Versailles Ky 83PT35 For Sale Our Rollin Home **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) [Non-text portions of this message have been removed] |
