Power steering pump disaster - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Power steering pump disaster (/showthread.php?tid=6033) |
Power steering pump disaster - Gardner Yeaw - 11-25-2007 08:12 WOW!!!What pleasant a surprise when the power steering quits on a narrow winding country road. I was bringing the coach home to install tank heaters for a trip north next weekend. I felt a little unfamiliar twitch in the steering followed shortly by another as I was entering a bend in the road. I suddenly felt the wheel fighting me and pushing back. It felt like the front end was locking up or falling apart. I hit the brakes and pulled wheel with all my might to keep it on the road. After stopping I couldn't see what was wrong so I assumed the power steering pump just quit. I managed to disconnect the toad and make a very difficult three point turn, reconnect the toad and return to the storage facility very slowly. After I opened up the front end and swung out the radiator I could see the belt was off the pulley. I reached in to see if the pump was frozen and the pulley fell off in my hand. The hub had disintegrated and only the three spokes were left. Fluid was dripping from the front pump bearing and the shaft was scraped up. The bolt was still tight in the front of the shaft. So I am perusing the forum data to locate pump suppliers. I assume the pump will be easier than the pulley. Does anyone know where I might find the pulley before I start calling the likley candidates? So much for this weekend's trip. Gardner 78FC33 Power steering pump disaster - Mike Hohnstein - 11-25-2007 08:53 Good thing you weren't on yer way to Alaska. Now might be the time to install the 87 and up 6.5" dia. pump pulley, greatly reduces the incidence of pump cavitation. Cavitation is what kills most FC pumps due to the lousy sump configuration. A larger sump down by the pump with a small fill/check chamber under the engine cover is a great upgrade. One of the better things I've done to mine I'll tell you. Power Steering Specialist 614 882 2422 These guys have supplied me successfully with the things I need for some projects requiring very obscure parts. MH ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 25, 2007 2:12 PM Subject: [WanderlodgeForum] Power steering pump disaster WOW!!!What pleasant a surprise when the power steering quits on a narrow winding country road. I was bringing the coach home to install tank heaters for a trip north next weekend. I felt a little unfamiliar twitch in the steering followed shortly by another as I was entering a bend in the road. I suddenly felt the wheel fighting me and pushing back. It felt like the front end was locking up or falling apart. I hit the brakes and pulled wheel with all my might to keep it on the road. After stopping I couldn't see what was wrong so I assumed the power steering pump just quit. I managed to disconnect the toad and make a very difficult three point turn, reconnect the toad and return to the storage facility very slowly. After I opened up the front end and swung out the radiator I could see the belt was off the pulley. I reached in to see if the pump was frozen and the pulley fell off in my hand. The hub had disintegrated and only the three spokes were left. Fluid was dripping from the front pump bearing and the shaft was scraped up. The bolt was still tight in the front of the shaft. So I am perusing the forum data to locate pump suppliers. I assume the pump will be easier than the pulley. Does anyone know where I might find the pulley before I start calling the likley candidates? So much for this weekend's trip. Gardner 78FC33 [Non-text portions of this message have been removed] Power steering pump disaster - Stephen Birtles - 11-25-2007 09:31 http://www.levysteering.com Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > WOW!!!What pleasant a surprise when the power steering quits on a > narrow winding country road. > > I was bringing the coach home to install tank heaters for a trip > north next weekend. I felt a little unfamiliar twitch in the steering > followed shortly by another as I was entering a bend in the road. I > suddenly felt the wheel fighting me and pushing back. It felt like > the front end was locking up or falling apart. I hit the brakes and > pulled wheel with all my might to keep it on the road. > > After stopping I couldn't see what was wrong so I assumed the power > steering pump just quit. I managed to disconnect the toad and make a > very difficult three point turn, reconnect the toad and return to the > storage facility very slowly. After I opened up the front end and > swung out the radiator I could see the belt was off the pulley. I > reached in to see if the pump was frozen and the pulley fell off in > my hand. The hub had disintegrated and only the three spokes were > left. Fluid was dripping from the front pump bearing and the shaft > was scraped up. The bolt was still tight in the front of the shaft. > > So I am perusing the forum data to locate pump suppliers. I assume > the pump will be easier than the pulley. Does anyone know where I > might find the pulley before I start calling the likley candidates? > > > So much for this weekend's trip. > > Gardner > 78FC33 > Power steering pump disaster - Gardner Yeaw - 11-25-2007 11:31 Mike, Do you have a part number for the larger pulley? I think for now I just want to get back on the road. The weather is turning cold and working outdoors will be bad enough just getting it back together, let alone trying fanacy upgrades. The pulley would be simple, but relocating the sump is a later project. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Good thing you weren't on yer way to Alaska. > Now might be the time to install the 87 and up 6.5" > dia. pump pulley, greatly reduces the incidence of pump cavitation. Cavitation is what kills most FC pumps due to the lousy sump configuration. A larger sump down by the pump with a small fill/check chamber under the engine cover is a great upgrade. One of the better things I've done to mine I'll tell you. > Power Steering Specialist > 614 882 2422 > These guys have supplied me successfully with the things I need for some projects requiring very obscure parts. > MH > ----- Original Message ----- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, November 25, 2007 2:12 PM > Subject: [WanderlodgeForum] Power steering pump disaster > > > WOW!!!What pleasant a surprise when the power steering quits on a > narrow winding country road. > > I was bringing the coach home to install tank heaters for a trip > north next weekend. I felt a little unfamiliar twitch in the steering > followed shortly by another as I was entering a bend in the road. I > suddenly felt the wheel fighting me and pushing back. It felt like > the front end was locking up or falling apart. I hit the brakes and > pulled wheel with all my might to keep it on the road. > > After stopping I couldn't see what was wrong so I assumed the power > steering pump just quit. I managed to disconnect the toad and make a > very difficult three point turn, reconnect the toad and return to the > storage facility very slowly. After I opened up the front end and > swung out the radiator I could see the belt was off the pulley. I > reached in to see if the pump was frozen and the pulley fell off in > my hand. The hub had disintegrated and only the three spokes were > left. Fluid was dripping from the front pump bearing and the shaft > was scraped up. The bolt was still tight in the front of the shaft. > > So I am perusing the forum data to locate pump suppliers. I assume > the pump will be easier than the pulley. Does anyone know where I > might find the pulley before I start calling the likley candidates? > > So much for this weekend's trip. > > Gardner > 78FC33 > > > > > > [Non-text portions of this message have been removed] > Power steering pump disaster - Gardner Yeaw - 11-25-2007 11:47 Stephen, Thanks. I am having trouble crossreferencing, but I assume a phone call will work tomorrow. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > http://www.levysteering.com > > Stephen 77fc35 > > > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > WOW!!!What pleasant a surprise when the power steering quits on a > > narrow winding country road. > > > > I was bringing the coach home to install tank heaters for a trip > > north next weekend. I felt a little unfamiliar twitch in the steering > > followed shortly by another as I was entering a bend in the road. I > > suddenly felt the wheel fighting me and pushing back. It felt like > > the front end was locking up or falling apart. I hit the brakes and > > pulled wheel with all my might to keep it on the road. > > > > After stopping I couldn't see what was wrong so I assumed the power > > steering pump just quit. I managed to disconnect the toad and make a > > very difficult three point turn, reconnect the toad and return to the > > storage facility very slowly. After I opened up the front end and > > swung out the radiator I could see the belt was off the pulley. I > > reached in to see if the pump was frozen and the pulley fell off in > > my hand. The hub had disintegrated and only the three spokes were > > left. Fluid was dripping from the front pump bearing and the shaft > > was scraped up. The bolt was still tight in the front of the shaft. > > > > So I am perusing the forum data to locate pump suppliers. I assume > > the pump will be easier than the pulley. Does anyone know where I > > might find the pulley before I start calling the likley candidates? > > > > > > So much for this weekend's trip. > > > > Gardner > > 78FC33 > > > Power steering pump disaster - david edwards - 11-26-2007 03:38 Gardner: While you're working on the pump over the cold months, you might want to consider some upgrades to the whole system. I have some pictures here of what I did to mine. FC power steering systems run too hot. (put an infrared thermometer on the reservoir after driving), partly because the low pressure lines run close to the exhaust manifold. I replaced all my lines with high temperature lines, insulated them with firesleeve where they pass by the manifold, doubled the size of the reservoir and added a cooler. Reduced running temperatures by about 100 degrees. Kerry 82 FC 35 Denver ________________________________________________________________________________\ ____ Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ |
