Large Zip Dee Awning mount/fastener pulled out from Bird Skin - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Large Zip Dee Awning mount/fastener pulled out from Bird Skin (/showthread.php?tid=621) |
Large Zip Dee Awning mount/fastener pulled out from Bird Skin - luckyron1 - 05-16-2005 10:55 How does one re-secure the lower, rear, mount... i.e. the one the dogleg bar attaches to.... when the anchors/sleeves for the 3 screws are stripped out??? Anyone done this? Thanks. 2000 LXI P.S. caused by a narrow bridge, a parked DOT truck and an err in judgement. Large Zip Dee Awning mount/fastener pulled out from Bird Skin - randydupree - 05-16-2005 11:39 move it over 1/2'' and rescrew it..randydupree93wb ----- Original Message ----- From: luckyron1 To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 16, 2005 6:55 PM Subject: [WanderlodgeForum] Large Zip Dee Awning mount/fastener pulled out from Bird Skin How does one re-secure the lower, rear, mount... i.e. the one the dogleg bar attaches to.... when the anchors/sleeves for the 3 screws are stripped out??? Anyone done this? Thanks. 2000 LXI P.S. caused by a narrow bridge, a parked DOT truck and an err in judgement. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Large Zip Dee Awning mount/fastener pulled out from Bird Skin - ronmarabito2002 - 05-16-2005 13:09 You could probably secure some epoxy putty. Fill the holes and when set, re-drill and put your screws back in. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > How does one re-secure the lower, rear, mount... i.e. the one the > dogleg bar attaches to.... when the anchors/sleeves for the 3 screws > are stripped out??? > > Anyone done this? Thanks. > > 2000 LXI > > P.S. caused by a narrow bridge, a parked DOT truck and an err in > judgement. Large Zip Dee Awning mount/fastener pulled out from Bird Skin - Curt Sprenger - 05-16-2005 13:17 Can you get behind that wall? Curt Sprenger â87PT38, Anaheim, Calif. > --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > wrote: > > How does one re-secure the lower, rear, mount... i.e. the one the > > dogleg bar attaches to.... when the anchors/sleeves for the 3 screws > > are stripped out??? > > > > Anyone done this? Thanks. > > > > 2000 LXI > > > > P.S. caused by a narrow bridge, a parked DOT truck and an err in > > judgement. > Large Zip Dee Awning mount/fastener pulled out from Bird Skin - Mark Garber - 05-16-2005 13:21 I've found JB weld does an excellent job of just what Ron is talking about. As with any bonding agent, prep(cleaning the surface) is 75% of the battle. Mark, 80FC35, still in PA ronmarabito2002 You could probably secure some epoxy putty. Fill the holes and when set, re-drill and put your screws back in. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > How does one re-secure the lower, rear, mount... i.e. the one the > dogleg bar attaches to.... when the anchors/sleeves for the 3 screws > are stripped out??? > > Anyone done this? Thanks. > > 2000 LXI > > P.S. caused by a narrow bridge, a parked DOT truck and an err in > judgement. --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Yahoo! Mail Mobile Take Yahoo! Mail with you! Check email on your mobile phone. [Non-text portions of this message have been removed] Large Zip Dee Awning mount/fastener pulled out from Bird Skin - Jeff Miller - 05-16-2005 13:35 If they're screwed into the metal "riv-nut", then the old riv-nut can be drilled out and a new one installed. You can also try a Helicoil insert, large hardware stores carry them and most mechanics will know what you are talking about. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > How does one re-secure the lower, rear, mount... i.e. the one the > dogleg bar attaches to.... when the anchors/sleeves for the 3 screws > are stripped out??? > > Anyone done this? Thanks. > > 2000 LXI > > P.S. caused by a narrow bridge, a parked DOT truck and an err in > judgement. Large Zip Dee Awning mount/fastener pulled out from Bird Skin - Tom Warner - 05-16-2005 13:56 I have a lot of aluminum stock which I always find uses for when repairing my 1982. I restored a 1976 GMC motorhome and had the same problem you are experiencing,m pulled the bottom bracket off the body. I cut a piece of 1/4" aluminum(I polished it to a high luster) about 3" square and pop riveted it to the body with an additional piece on the other side of the body. Then I attached the awning bracket to that and its stronger then ever. Tom 1982 FC35 Vernon Center,NY At 07:39 PM 5/16/2005 -0400, you wrote: >move it over 1/2'' and rescrew it..randydupree93wb > ----- Original Message ----- > From: luckyron1 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, May 16, 2005 6:55 PM > Subject: [WanderlodgeForum] Large Zip Dee Awning mount/fastener pulled > out from Bird Skin > > > How does one re-secure the lower, rear, mount... i.e. the one the > dogleg bar attaches to.... when the anchors/sleeves for the 3 screws > are stripped out??? > > Anyone done this? Thanks. > > 2000 LXI > > P.S. caused by a narrow bridge, a parked DOT truck and an err in > judgement. > |
