Resoring Dull Paintwork - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Resoring Dull Paintwork (/showthread.php?tid=6218) |
Resoring Dull Paintwork - ebirder2000@... - 01-14-2008 01:17 Justin,
The trick with our old alkaline based finishes is to first remove the oxidation. This is the part that takes the most work (elbow grease) and is so time consuming. There is no "easy" way around this step.I used a very mild rubbing compound made by Turtle Wax (green labeled plastic container) to remove oxidation then Iimmediately waxed it over with almost any kind of wax or polish. I stuck with Turtle Wax. Once the shine is restored the maintenance is relatively simple. Or at least as easy as waxing one of these things gets. I have never had much luck using power polishers on the sides of the bus because there are so many obstructions. I do however use power buffers for the wheels.
Steve Anderson
79 FC 35
On the road.
In a message dated 1/14/2008 9:19:44 A.M. US Mountain Standard Time, justin@... writes:
Start the year off right. Easy ways to stay in shape in the new year. Resoring Dull Paintwork - jmoorelewy - 01-14-2008 04:19 Does anyone have any advice on the best way to restore dull paintwork on my 1982 FC 35. I can get the shone back but it takes a lot of elbow grease, any tricks? Justin 1982 FC35 Distant Drums in CA Resoring Dull Paintwork - Pete Masterson - 01-14-2008 06:46 Old paint becomes oxidized and dull. Polishing compound followed by a good waxing can bring the shine back to the paint. Polishing compound, when improperly applied can damage already thin paint, so care in application is required. Repeating wax application every six months or so (depending on storage and local weather conditions) is usually required. Elbow grease is required in a generous dose. Completely repainting the coach with a clear coat as a final painting step will refresh the paint. It will set you back at least $10,000 for a professional job. (The $10,000 is for a just-over-the-border shop in Mexico. A high-quality job in a US shop is likely to be much more expensive.) As an alternative, a graphics/sign shop might be able to install a full-coach wrap. (These are what are used to make full-bus advertisements.) Most full-coach wraps will cost upwards of $10,000 to design, produce, and apply the plastic film. The claimed life is 10 years, but few wraps or large area graphics are left on that long, so that's probably just a guess by the film manufacturers. Note that advertisement on your coach may impact your insurance cost. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jan 14, 2008, at 8:19 AM, jmoorelewy wrote:
Resoring Dull Paintwork - Gregory OConnor - 01-14-2008 08:40 Clay bar rubbed over the paint with a lubricant do about the best job on cleaning the single stage paint jobs of earlier paint systems. On the colorcoat/clearcoat paint systems clay only helps flatten out the clear coat to make it shine. Others may suggest 'mop and glow'. The results are unbelievably terrific but the product is temporary and the residue is almost impossible to clean out of the many crevices once it gets chalky from the sun. Candidates not, but Mop-N-Glow should stay in the kitchen I was approached by an advertiser to wrap my bus with an advertisement and receive a monthly fee but we could not agree on the placement of the three hour side effect disclaimer. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > Old paint becomes oxidized and dull. Polishing compound followed by a > good waxing can bring the shine back to the paint. Polishing > compound, when improperly applied can damage already thin paint, so > care in application is required. Repeating wax application every six > months or so (depending on storage and local weather conditions) is > usually required. > > Elbow grease is required in a generous dose. > > Completely repainting the coach with a clear coat as a final painting > step will refresh the paint. It will set you back at least $10,000 > for a professional job. (The $10,000 is for a just-over-the- border > shop in Mexico. A high-quality job in a US shop is likely to be much > more expensive.) > > As an alternative, a graphics/sign shop might be able to install a > full-coach wrap. (These are what are used to make full-bus > advertisements.) Most full-coach wraps will cost upwards of $10,000 > to design, produce, and apply the plastic film. The claimed life is > 10 years, but few wraps or large area graphics are left on that long, > so that's probably just a guess by the film manufacturers. Note that > advertisement on your coach may impact your insurance cost. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jan 14, 2008, at 8:19 AM, jmoorelewy wrote: > > > Does anyone have any advice on the best way to restore dull paintwork > > on my 1982 FC 35. > > > > I can get the shine back but it takes a lot of elbow grease, any > > tricks? > > > > > > Justin > > > > 1982 FC35 Distant Drums in CA > > > Resoring Dull Paintwork - Jon - 01-14-2008 09:03 --- In WanderlodgeForum@yahoogroups.com, "jmoorelewy" wrote: > > Does anyone have any advice on the best way to restore dull paintwork > on my 1982 FC 35. > > I can get the shone back but it takes a lot of elbow grease, any tricks? > > > Justin > > 1982 FC35 Distant Drums in CA > Justin they have some wax out there but I don't recall the name but it has a pait pigment in it and if you have small scrathes or spider web type of cracks in your paint job this will do a wonderfull job of covering up those items. I use this on my bus and it really makes a difference in the shine. Jon Rebel Bird Resoring Dull Paintwork - ronmarabito2002 - 01-14-2008 11:56 Try a product called "Dry Wash N Guard" sold by individual retailers. There are many amoung the RV Group. For severe oxidation, they have a product called "Oxygone". A very severe problem might take multiple applications, but once done, keeping a coat of "Dry Wash N Guard" on it will make it look quite nice. This is all I use on my coach. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "jmoorelewy" > > Does anyone have any advice on the best way to restore dull paintwork > on my 1982 FC 35. > > I can get the shone back but it takes a lot of elbow grease, any tricks? > > > Justin > > 1982 FC35 Distant Drums in CA > Resoring Dull Paintwork - brad barton - 01-14-2008 15:17 Don't be so anxious to slick up the outside. First-time guests will be more impressed on how much nicer it looks inside. Brad Barton 00LXiDFW bbartonwx@...
Put your friends on the big screen with Windows Vista® + Windows Liveâ¢. Start now! |
