doorbell - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: doorbell (/showthread.php?tid=623) |
doorbell - Ernest Ekberg - 05-16-2005 14:09 My barrel chair finally wiped out the doorbell controls that were mounted on the sidewall. Since this is all a circuit board, is there a simple fix for this? I don't care if it plays 50 tunes- just so that it rings. Ernie-83PT40 in Texas- doorbell - erniecarpet@... - 05-16-2005 19:28 Thanks, John. Is the receiver battery operated or did you use the exiting house wiring? Ernie [Non-text portions of this message have been removed] doorbell - John - 05-16-2005 21:50 Ernie, My door bell was also shot on my "Bird and I just replaced it with an inexpensive wireless unit that I purchased at Lowes. http://www.lowes.com/lowes/lkn?action=productDetail&productId=77189- 234-LE-6140&lpage=none http://tinyurl.com/cnq65 I used a piece of aluminum to cover the old door bell switch hole and then mounted the new switch to it. the door bell unit itself can be mounted anywhere inside of the 'Bird, so that it is out of the way of that wildly swinging chair. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > My barrel chair finally wiped out the doorbell controls that were > mounted on the sidewall. Since this is all a circuit board, is there a > simple fix for this? I don't care if it plays 50 tunes- just so that it > rings. Ernie-83PT40 in Texas- doorbell - John Stiles - 05-17-2005 00:45 Ernie, When I replaced my non-functioning doorbell I went to Lowes and bought a battery powered doorbell (2 C-type) to install. It utilizes the original wiring and doorbell button (although I replaced mine with a newer nicer one) and of course doesn't serinade you with Disney tunes but at least we know someone is outside. Now if I had my wishes one of those doorbells like on the Adams family..... Hope this helps, John John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Thanks, John. Is the receiver battery operated or did you use the exiting > house wiring? Ernie > > > [Non-text portions of this message have been removed] doorbell - John - 05-17-2005 04:11 Ernie, Both the door bell switch and the receiver are battery operated. The battery for the outside switch comes with the kit, but you have to supply the two C cell batteries for the receiver. Since I live in my "Bird full time and have it parked next to my shop when I'm here at home, I have an identical kit in my shop, so that if the door bell for either the 'Bird, or the shop is rung, it sounds inside the 'Bird and in my office in the shop. The unit works within about 100 feet of the outside switch and the receivers can also be set for different frequencies, so that they will not sound each other, if that is what you want. I just taped up the door switch wires and tucked them up inside the hole that the original switch covered. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA //////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Thanks, John. Is the receiver battery operated or did you use the exiting > house wiring? Ernie > > > [Non-text portions of this message have been removed] |
