Sun checked tires - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Sun checked tires (/showthread.php?tid=6318) |
Sun checked tires - Fred Hulse - 02-03-2008 02:47 While at the Q rallyLucas Willemsefound some sidewall cracking on the left side tires that I figure were exposed to the southern sun before I could get my cover and sunshade built,being these and the balance of the 8 tires were but four years old, I was thinking to replace the three that have the sun exposure and replace the balance at the normal seven year life span. Is there any reason not to do this? Fred & Jeanne Hulse
Sharon & Sheryl
Morristown Arizona 1997 Wanderlodge WLWB41 Sun checked tires - Gregory OConnor - 02-03-2008 04:24 Fred,It may be good to put your bus on a steering tire rotation. If you replace a 2 tire set every 2 years, you never have tires older than 8years. The other advantage is you never steer on tires older than 2years. If one of the three is in better shape I would pair it with the duel and keep it sun damaged exposed so you can keep an eye on it or just replace it and drop a new on the tag. Lucas would not have made a suggestion if the tires were perfect, notice he said nothing about Jeanne's chili. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > > While at the Q rally Lucas Willemse found some sidewall cracking on the left side tires that I figure were exposed to the southern sun before I could get my cover and sunshade built,being these and the balance of the 8 tires were but four years old, I was thinking to replace the three that have the sun exposure and replace the balance at the normal seven year life span. > Is there any reason not to do this? > Fred & Jeanne Hulse > Sharon & Sheryl > Morristown Arizona > 1997 Wanderlodge WLWB41 > Sun checked tires - Fred Hulse - 02-03-2008 04:32 I think I understand your suggestion as:
Get two new fronts and put the one that is best of the three on the duals.
Makes good economic sense to me.
Then go have a bowl of Jeanne's chili,right?
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Sun checked tires - Gregory OConnor - 02-03-2008 05:01 Fred, close, Chili first. It is not necessary to match tire wear/size across an axle but it is necessary to match tire size in pairs on the duel. Greg --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > I think I understand your suggestion as: > Get two new fronts and put the one that is best of the three on the duals. > Makes good economic sense to me. > Then go have a bowl of Jeanne's chili,right? > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > Sun checked tires - Bob Lawrence - 02-03-2008 05:59 Hi Fred, When you replace tires on duel wheels, make sure they are the same. Replacing one means that one tire doesn't have the same diameter as the other one (wear pattern) so the bigger diameter tire will have to carry more weight. Not good. Bob Lawrence 84 PT36 Boulder City, Nv > I think I understand your suggestion as: > Get two new fronts and put the one that is best of the three on the duals. > Makes good economic sense to me. > Then go have a bowl of Jeanne's chili,right? > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > Sun checked tires - Fred Hulse - 02-03-2008 11:57 Bob Lawrence
Thank you for that information
It was nice to catch up to you @ Q.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Sun checked tires - pwgoddu - 02-04-2008 15:49 I wonder if I can pop in with a question. I've been following this discussion and wasn't clear on the comment on matching duals. How would you match the size (other than nominal tire size)? If you take two steer axle tires and move them aft to the drive axle would you then put them on the same side to make sure they are the same? Then move the two drive tires to the tag?? Thanks - Popeye (Pete) --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi Fred, > When you replace tires on duel wheels, make sure they are the same. > Replacing one means that one tire doesn't have the same diameter as the > other one (wear pattern) so the bigger diameter tire will have to carry > more weight. Not good. > Bob Lawrence > 84 PT36 > Boulder City, Nv > > > I think I understand your suggestion as: > > Get two new fronts and put the one that is best of the three on the > duals. > > Makes good economic sense to me. > > Then go have a bowl of Jeanne's chili,right? > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WLWB41 > > > Sun checked tires - Fred Hulse - 02-05-2008 06:07 The statement of matching duals simply expained is that the tires need to be the same in size or diameter and width in order for both tires to carry their equal share of the load.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Sun checked tires - Bob Lawrence - 02-05-2008 13:25 Yep, Take the steer tires and put them on the same side..i.e. both on left drive axle...or right axle. Then move the old tires to tag status. Bob Lawrence 84 PT36 Boulder City, Nv > I wonder if I can pop in with a question. I've been following this > discussion and wasn't clear on the comment on matching duals. How > would you match the size (other than nominal tire size)? If you take > two steer axle tires and move them aft to the drive axle would you > then put them on the same side to make sure they are the same? Then > move the two drive tires to the tag?? > > Thanks - > > Popeye (Pete) > > |
