Air Height valves - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Height valves (/showthread.php?tid=6354) Pages: 1 2 |
Air Height valves - birdshill123 - 02-13-2008 07:12 We are on the road in Mexico and have had some problems with the left rear height valve. We had stopped for lunch and the whole unit was leaning to the left. Stayed at a toll booth overnite and took it to a shop in the morning. They replced the valve and it sat level and I thought all as OK. We are in Mazatlan now and I noticed that when I used the air braks my air guage dropped more than normal. Step would come out after being stopped for 2 minutes. I crawled under and the air is coming out the exhauts port on the new valve. I can see the allen head set screw for adjusting the valve and I have a suspicion that it is just out of adjustment. Or they may have installed the wrong valve?? I would loosen that set screw but I dont have any supports for the Bird and am afraid it might dump the air from the bags and crush me. Not too many good mechanics in this area but we might try a KW dealer on Friday. Any suggestions appreciated I figure my life is worth more than an hours labor!! I do have one hydraulic jack and could drive the unit up on a 2 by 10. Bruce 1988 FC35 Air Height valves - John McGinnis - 02-13-2008 17:37 Bruce, I don't know what the specific problem might be with the leak in leveling system but FWIW I'd like to suggest while your in that area working you might want to take the time to replace the swivel ball joint on the end of the connecting rod on the air leveler. It's a $3.00 part and after 20 years of road grime it will seaze up and break off. That happen to me on the first day of ownership of my bird. I thought I had an air leak or ruptured air bag until we crawled around underneath and found the rod hanging loose. Driving in some road conditions it would wiggle around and catch and the bag would inflat then others it would deflat. Somewhere I have the NAPA & Carquest part numbers for the ball joint. Maybe Bill Pape will come on, I sent him a NAPA ball joint awhile back he lives on his bird & mine is in storage so he can get to the parts number quicker. Good luck. John 88FC35 Air Height valves - birdshill123 - 02-14-2008 01:24 Thank you John: It is fixed. This is a great story . After we got to Mazatlan I got on the city bus to the Kenworth dealer. They were not interested in working on a BB. Same with the IHC dealer. I tried a few large tire shops as sometimes in Mexico they do air barke work and air suspension. No luck. Finally I got on the city bus again. They are all privately owned and have air brakes and doors. I asked the driver if he knew of a good shop. Took me right to a street full of trucks and shops. The first shop was strictly outdoors but they were working on a newer fire truck and an 06 KW. I told them my story. In 2 minutes I was on the back of a 100 cc motorcycle with the mechanic. At the CG he climbed under despite my warnings about safety ( macho). He weighed all of about 110 lbs. 15 minutes later we were done. Apparently the air supply line and adapter fitting were not tight! Kind of like a Doctor that makes house calls!! I will check those ball ends. Probably a Haldex or Bendix part. Bruce 1988 FC35 Air Height valves - Mike Hohnstein - 02-14-2008 01:26 Great out come, glad it's fixed.
MH
Air Height valves - Fred Hulse - 02-14-2008 02:32 Bruce
We need a few of thoseguys around here.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Air Height valves - Gregory OConnor - 02-14-2008 03:53 The airline fittings were tight, something made it grow loose. (look for the cause) If it is simply vibration from the rough roads the one loose fitting will not be unique to your bus. Some hoses that have swival ends twist a bit radialy when cinched tight. The hose always trys to relax and untwist in the direction of loosing up the fitting. I have also seen teflon tape used on threaded fittings that were not pipe thread. Pipe thread male ends have deeper vallys at the tip. when you connect a pipe thread, the tapered male jams into the even opening of the female. (one of the reason plastic female pipe thread splits) Teflon is needed on pipe thread only. On washer mounted unions (hose bib) and the taper angle unions (jic) Teflon tape is not used. It may even act as a lubricant to loosen up the hose or get in the way of a good seat. I like your stories. I get a mental picture of you on a Dino bus ;Market baskets on the roof ;chickens running up and down the isle ;the driver in a big sombra'o and a local kid looking back at your chef hat from the seat forward. The return trip must have been a sight to see: Mistro the Mechanic driving a moped down a dirt city street while you balance an 80# toolbox on your lap ,trying to hold on to the driver and that hat. You have 'Too much fun' GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "birdshill123" . Apparently the air supply > line and adapter fitting were not tight! Kind of like a Doctor that > makes house calls!! > Air Height valves - John McGinnis - 02-14-2008 05:41 Bruce, Not sure may be a Bendix, it looks just like the conneting rod end on the linkage rod to a Holly Carb. When I bought my bus after a serious going over we were on our way to the KOA to stay for a few days so the PO could go over all the internal systems with us, on our way to the KOA the wife was following us in the car and she noticed the bus would raise and lower as we were traveling down the road. Oddly while in the bus we did not notice any diffenence until we got to the KOA and the left rear was sagging about 6". We raised the bus with the levelers, slid a 12 ton under and crawled around, that's when we noticed the rod just floping around, this was on a Sat afternoon in Petosky MI, nothing open until Monday AM, ths was an oppurtunity to give the bus a serious going over. At 9:00, Monday AM we went to Carquest with the broken part in hand. The young lady asked how many did we need, I asked how much & when she said $3 I got four, I replaced the 2 in the rear and 1 on the front, I have a spare, total time of repair 30 minutes for all three. We were on the road at 11:00 AM heading home. When I got home I went to our local Carquest & they didn't carry them but I found them at NAPA so I bought a few more to share. I liked your story, it is ingenious & nerving how folks in other parts of the world are willing to work on things & in conditions when we here in America want to R&R and not take the time to diagnose and repair. John 88FC35 Air Height valves - birdshill123 - 02-14-2008 06:16 Greg: You have a vivid imagination ! But if you have ever been to Mazatlan the traffic is horrendous. The bus drivers do not get a salary. They receive the fare less a license fee. They are not regulated so the competition for passengers is something else. They constantly whip in and out of traffic and rob the other guy's passenger from the curb. The busses are all std. transmission with a 2 speed axle. You have to see them shifting and making change all at the same time. They truly are amazing. So the ride on the back of that little moto was exciting! My chef's hat is under glass until next year!! Bruce 1988FC35 Air Height valves - birdshill123 - 02-14-2008 06:31 John: After you are in Mexico for a while one learns not to simply R&R. They have shops that overhaul just about anything: blenders, washing machines, carburators, fuel pumps, water pumps and boosters. You can still buy fuel pump kits for the older cars. Some on this forum may remember when you could go to a parts store and buy the fuel pump diaphragms. But it is a country of contrasts. There are diagnostic specialists with the latest test equipment to read the trouble codes in most late model cars. Any flat rate mechanic would be shocked at the way the mechanics work. These fellows cannot afford a lot of tools so the dealerships have a tool crib. You will see them going to the wicket with a work order and getting a 9/16 wrench and a vise grip! They are not super fast but lots of good mechanics. Labor rates vary from around $25.00 at dealerships to $5.00 in the little pueblos. Parts that are imported from the USA are about 50% higher. But there are a lot of parts that are either made in Mexico or come from Latin America. These are inexpensive and of good quality. Time for a Cerveza!! Bruce 1988 FC35 Air Height valves - PM7088@... - 02-14-2008 06:33 -------------- Original message -------------- |
