CAT 3208 Air Filter - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: CAT 3208 Air Filter (/showthread.php?tid=636) |
CAT 3208 Air Filter - Scott - 05-18-2005 13:12 Just got home from Charleston SC where I was dealing with some Alternator issues on our 86FC35 I hope they are taken care of now... that will be another post. While there (waiting for two days) I decided to check the air filter for the CAT 3208 TURBO. It would smoke just a little when into the throttle..I thought hmmm.. so I was gonna check the fuel filter for water and the air filter. I am glad I did!! I thought that the big galvanized box had an element in it, just pry it open and there it would be!! WRONG.. the whole box is the filter!! I tried for 30 mins to try and pry the top of the box open to see the element..surely my guy that does my service has changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill-Farr # 049261-000 is very hard to find can anyone give me some advice or part # (wix or racor) INTERESTINGLY when I did finally get the box out I noticed that the paint inside the intake has begun to "flake" I actually found flakes of paint on top of the screen going into the motor!!!(THAT CAN'T BE GOOD) I will immediately cover the intake and wire brush the whole intake area where the filter sits...Does anyone know what type of paint to use is there a special type??? MIKE H your thoughts?? TIA Scott 86FC35 "RUBY" Murrells Inlet SC (still working on BP) CAT 3208 Air Filter - freewill2008 - 05-18-2005 13:42 I just walked into the local CarQuest parts store and gave them the filter number on my BB Service Parts Sheet. Seventy-some dollars later I was out the door with the filter element under my arm. The old filter didn't look bad at all, but the difference in power was obvious right away. As far as paint, the trick is surface preparation. If the surface is clean and just a little roughed up (steel wool or some other abrasive) then a decent paint should stay there for a long time. I like laquer thinner to clean metal surfaces B4 paint, but knowing this list, somebody will prolly know about a better cleaning agent. Use a solvent-based paint! 1986 - you prolly got some of the same crap they painted my 89 Chev pickup with. Lost a couple thou on that not-so-better idea. - Bob Griesel FC31 WLII 225T WA --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > Just got home from Charleston SC where I was dealing with some > Alternator issues on our 86FC35 I hope they are taken care of now... > that will be another post. While there (waiting for two days) I > decided to check the air filter for the CAT 3208 TURBO. It would > smoke just a little when into the throttle..I thought hmmm.. so I was > gonna check the fuel filter for water and the air filter. I am glad I > did!! I thought that the big galvanized box had an element in it, > just pry it open and there it would be!! WRONG.. the whole box is > the filter!! I tried for 30 mins to try and pry the top of the box > open to see the element..surely my guy that does my service has > changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill-Farr # > 049261-000 is very hard to find can anyone give me some advice or > part # (wix or racor) INTERESTINGLY when I did finally get the box > out I noticed that the paint inside the intake has begun to "flake" I > actually found flakes of paint on top of the screen going into the > motor!!!(THAT CAN'T BE GOOD) I will immediately cover the intake and > wire brush the whole intake area where the filter sits...Does anyone > know what type of paint to use is there a special type??? MIKE H your > thoughts?? TIA > Scott > 86FC35 "RUBY" > Murrells Inlet SC (still working on BP) CAT 3208 Air Filter - George Lowry - 05-18-2005 14:16 HI Scott, Farr was bought out by Fleetgard a few years ago and Fleetgard is owned by Cummins. Try a Cummins distributor - chances he will either have your filter in stock or can get it fast. A couple of numbers that might help - Farr Co. - 310-536-6300 in El Segundo, CA - Fleetgard Inc - (800) 251-6791 in Cookeville, TN. It has been a while since I got these numbers so area codes may have changed. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Scott wrote: > Just got home from Charleston SC where I was dealing with some > Alternator issues on our 86FC35 I hope they are taken care of now... > that will be another post. While there (waiting for two days) I > decided to check the air filter for the CAT 3208 TURBO. It would > smoke just a little when into the throttle..I thought hmmm.. so I was > gonna check the fuel filter for water and the air filter. I am glad I > did!! I thought that the big galvanized box had an element in it, > just pry it open and there it would be!! WRONG.. the whole box is > the filter!! I tried for 30 mins to try and pry the top of the box > open to see the element..surely my guy that does my service has > changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill-Farr # > 049261-000 is very hard to find can anyone give me some advice or > part # (wix or racor) INTERESTINGLY when I did finally get the box > out I noticed that the paint inside the intake has begun to "flake" I > actually found flakes of paint on top of the screen going into the > motor!!!(THAT CAN'T BE GOOD) I will immediately cover the intake and > wire brush the whole intake area where the filter sits...Does anyone > know what type of paint to use is there a special type??? MIKE H your > thoughts?? TIA > Scott > 86FC35 "RUBY" > Murrells Inlet SC (still working on BP) > > > > > > > > Yahoo! Groups Links > > > > > > > > > CAT 3208 Air Filter - Jeff Miller - 05-18-2005 14:50 The last two I bought had a FARR sticker under the Fleetguard sticker, were in stock at my local truck-parts supplier, about $50/ea. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > Just got home from Charleston SC where I was dealing with some > Alternator issues on our 86FC35 I hope they are taken care of now... > that will be another post. While there (waiting for two days) I > decided to check the air filter for the CAT 3208 TURBO. It would > smoke just a little when into the throttle..I thought hmmm.. so I was > gonna check the fuel filter for water and the air filter. I am glad I > did!! I thought that the big galvanized box had an element in it, > just pry it open and there it would be!! WRONG.. the whole box is > the filter!! I tried for 30 mins to try and pry the top of the box > open to see the element..surely my guy that does my service has > changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill-Farr # > 049261-000 is very hard to find can anyone give me some advice or > part # (wix or racor) INTERESTINGLY when I did finally get the box > out I noticed that the paint inside the intake has begun to "flake" I > actually found flakes of paint on top of the screen going into the > motor!!!(THAT CAN'T BE GOOD) I will immediately cover the intake and > wire brush the whole intake area where the filter sits...Does anyone > know what type of paint to use is there a special type??? MIKE H your > thoughts?? TIA > Scott > 86FC35 "RUBY" > Murrells Inlet SC (still working on BP) CAT 3208 Air Filter - Scott - 05-18-2005 14:58 Thanks George, Jeff, freewill, I have been to several places without luck I will try some good old phone work in the am..Is that the right part #??? anyone know?? TIA Scott 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > The last two I bought had a FARR sticker under the Fleetguard > sticker, were in stock at my local truck-parts supplier, about $50/ea. > > - Jeff Miller > http://www.wanderlodge.net > http://www.millercoachworks.com > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > wrote: > > Just got home from Charleston SC where I was dealing with some > > Alternator issues on our 86FC35 I hope they are taken care of > now... > > that will be another post. While there (waiting for two days) I > > decided to check the air filter for the CAT 3208 TURBO. It would > > smoke just a little when into the throttle..I thought hmmm.. so I > was > > gonna check the fuel filter for water and the air filter. I am glad > I > > did!! I thought that the big galvanized box had an element in it, > > just pry it open and there it would be!! WRONG.. the whole box is > > the filter!! I tried for 30 mins to try and pry the top of the box > > open to see the element..surely my guy that does my service has > > changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill- Farr > # > > 049261-000 is very hard to find can anyone give me some advice or > > part # (wix or racor) INTERESTINGLY when I did finally get the box > > out I noticed that the paint inside the intake has begun to "flake" > I > > actually found flakes of paint on top of the screen going into the > > motor!!!(THAT CAN'T BE GOOD) I will immediately cover the intake > and > > wire brush the whole intake area where the filter sits...Does > anyone > > know what type of paint to use is there a special type??? MIKE H > your > > thoughts?? TIA > > Scott > > 86FC35 "RUBY" > > Murrells Inlet SC (still working on BP) CAT 3208 Air Filter - Jeff Miller - 05-18-2005 15:10 If you have no luck before tomorrow noon, I will be out at the warehouse where I have a spare in the box, and will get the numbers off of the box. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > Thanks George, Jeff, freewill, I have been to several places without > luck I will try some good old phone work in the am..Is that the right > part #??? anyone know?? > TIA > Scott > 86FC35 > SC > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > The last two I bought had a FARR sticker under the Fleetguard > > sticker, were in stock at my local truck-parts supplier, about > $50/ea. > > > > - Jeff Miller > > http://www.wanderlodge.net > > http://www.millercoachworks.com > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > > wrote: > > > Just got home from Charleston SC where I was dealing with some > > > Alternator issues on our 86FC35 I hope they are taken care of > > now... > > > that will be another post. While there (waiting for two days) I > > > decided to check the air filter for the CAT 3208 TURBO. It would > > > smoke just a little when into the throttle..I thought hmmm.. so I > > was > > > gonna check the fuel filter for water and the air filter. I am > glad > > I > > > did!! I thought that the big galvanized box had an element in it, > > > just pry it open and there it would be!! WRONG.. the whole box > is > > > the filter!! I tried for 30 mins to try and pry the top of the > box > > > open to see the element..surely my guy that does my service has > > > changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill- > Farr > > # > > > 049261-000 is very hard to find can anyone give me some advice or > > > part # (wix or racor) INTERESTINGLY when I did finally get the > box > > > out I noticed that the paint inside the intake has begun > to "flake" > > I > > > actually found flakes of paint on top of the screen going into > the > > > motor!!!(THAT CAN'T BE GOOD) I will immediately cover the intake > > and > > > wire brush the whole intake area where the filter sits...Does > > anyone > > > know what type of paint to use is there a special type??? MIKE H > > your > > > thoughts?? TIA > > > Scott > > > 86FC35 "RUBY" > > > Murrells Inlet SC (still working on BP) CAT 3208 Air Filter - Scott - 05-18-2005 15:11 Thanks Jeff... Scott 86FC35 Sc --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > If you have no luck before tomorrow noon, I will be out at the > warehouse where I have a spare in the box, and will get the numbers > off of the box. > > - Jeff Miller > http://www.wanderlodge.net > http://www.millercoachworks.com > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > wrote: > > Thanks George, Jeff, freewill, I have been to several places > without > > luck I will try some good old phone work in the am..Is that the > right > > part #??? anyone know?? > > TIA > > Scott > > 86FC35 > > SC > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > The last two I bought had a FARR sticker under the Fleetguard > > > sticker, were in stock at my local truck-parts supplier, about > > $50/ea. > > > > > > - Jeff Miller > > > http://www.wanderlodge.net > > > http://www.millercoachworks.com > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > > > wrote: > > > > Just got home from Charleston SC where I was dealing with some > > > > Alternator issues on our 86FC35 I hope they are taken care of > > > now... > > > > that will be another post. While there (waiting for two days) I > > > > decided to check the air filter for the CAT 3208 TURBO. It > would > > > > smoke just a little when into the throttle..I thought hmmm.. so > I > > > was > > > > gonna check the fuel filter for water and the air filter. I am > > glad > > > I > > > > did!! I thought that the big galvanized box had an element in > it, > > > > just pry it open and there it would be!! WRONG.. the whole box > > is > > > > the filter!! I tried for 30 mins to try and pry the top of the > > box > > > > open to see the element..surely my guy that does my service has > > > > changed it WRONG AGAIN..(feeling stupid here) Well the Kamfill- > > Farr > > > # > > > > 049261-000 is very hard to find can anyone give me some advice > or > > > > part # (wix or racor) INTERESTINGLY when I did finally get the > > box > > > > out I noticed that the paint inside the intake has begun > > to "flake" > > > I > > > > actually found flakes of paint on top of the screen going into > > the > > > > motor!!!(THAT CAN'T BE GOOD) I will immediately cover the > intake > > > and > > > > wire brush the whole intake area where the filter sits...Does > > > anyone > > > > know what type of paint to use is there a special type??? MIKE > H > > > your > > > > thoughts?? TIA > > > > Scott > > > > 86FC35 "RUBY" > > > > Murrells Inlet SC (still working on BP) |
