Old PACS inverter - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Old PACS inverter (/showthread.php?tid=6394) |
Old PACS inverter - krminyl@... - 02-26-2008 08:11 Scott,
I have the original owner's manual, with some wiring diagrams. I also have the PACS1500, but mine isn't wired to the ignition...do you have the remote on/off switch/reset panel underneath the cabinet, behind the driver'sseat?
If you need a copy of the owner's booklet, send me an off-forum email, with your home address, and I'll send you a copy.
"krminyl@aol.com"
Kevin McKeown
Yorba Linda, CA
1986 38' PT Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. Old PACS inverter - Scott Forman - 02-26-2008 11:09 My coach has the original PACS 1500w inverter, and I have just discovered that it works. The problem is that these things were wired from the factory to work only when the ignition is on...quite inconvenient. Does anyone know how the ignition interface can be disabled so that I can have inverter power any time? Scott Forman 86 PT38 Memphis Old PACS inverter - Scott Forman - 02-26-2008 14:01 My on/off/reset switch is on he bulkhead above the driver's head. I think I have the manual too, haven't tried to go through it yet. Scott --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Scott, > > I have the original owner's manual, with some wiring diagrams. I also have > the PACS1500, but mine isn't wired to the ignition...do you have the remote > on/off switch/reset panel underneath the cabinet, behind the driver's seat? > > If you need a copy of the owner's booklet, send me an off-forum email, with > your home address, and I'll send you a copy. > > _krminyl@..._ (mailto:krminyl@...) > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > > **************Ideas to please picky eaters. Watch video on AOL Living. > (http://living.aol.com/video/how-to-please-your-picky-eater/rachel- campos-duffy/ > 2050827?NCID=aolcmp00300000002598) > |
