92 WB Jacks - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 92 WB Jacks (/showthread.php?tid=640) |
92 WB Jacks - Lawrence Thornell - 05-18-2005 17:10 My buddy is having trouble with his jacks working on his 92 WB. He has changed out 2 relays(Is there a 3rd one he hasn't found?) Every thing checks as he has been instructed by HWH but the pump will not come on. HWH says it should work by receiving a ground when activated. He can make it(the pump) work by providing a hot wire, not a ground. Any ideas? Thanks LT 90 SP in Eclectic, AL. [Non-text portions of this message have been removed] 92 WB Jacks - ronmarabito2002 - 05-19-2005 02:43 Check the motor by applying power directly to the motor terminal. I recently had a problem and it was a broken wire under the termianl to the armature. Any generator/starter shop can repair it if it needs it. Mine showed practically no wear inside. Will outlast me for sure. R.E. (Ron Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > My buddy is having trouble with his jacks working on his 92 WB. He has changed out 2 relays(Is there a 3rd one he hasn't found?) Every thing checks as he has been instructed by HWH but the pump will not come on. HWH says it should work by receiving a ground when activated. He can make it(the pump) work by providing a hot wire, not a ground. Any ideas? > Thanks LT 90 SP in Eclectic, AL. > > > [Non-text portions of this message have been removed] 92 WB Jacks - Lawrence Thornell - 05-19-2005 02:56 Ron The pump will run when wired straight with a hot wire. HWH says + terminal should remain hot, then ground is applied when activated, + is not hot-ground is not applied. Thanks Lt 90 SP in Eclectic, AL, a two Bird town, 1000 people, 2 Birds ----- Original Message ----- From: "ronmarabito2002" To: Sent: Thursday, May 19, 2005 9:43 AM Subject: [WanderlodgeForum] Re: 92 WB Jacks > Check the motor by applying power directly to the motor terminal. I > recently had a problem and it was a broken wire under the termianl to > the armature. Any generator/starter shop can repair it if it needs it. > Mine showed practically no wear inside. Will outlast me for sure. > > R.E. (Ron Marabito, Dallas, TX 92WB40 > Moderator > > > --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > >> My buddy is having trouble with his jacks working on his 92 WB. He > has changed out 2 relays(Is there a 3rd one he hasn't found?) Every > thing checks as he has been instructed by HWH but the pump will not > come on. HWH says it should work by receiving a ground when > activated. He can make it(the pump) work by providing a hot wire, not > a ground. Any ideas? >> Thanks LT 90 SP in Eclectic, AL. >> >> >> [Non-text portions of this message have been removed] > > > > > > > Yahoo! Groups Links > > > > > > 92 WB Jacks - ronmarabito2002 - 05-19-2005 08:10 If the motor runs, then it has to be one of the two solenoids. If they were replaced, then check to see if they are wired correctly. I believe the key has to be on for them to be energized. Maybe not. I'm having a senior moment. Seems like when I replaced one of my solenoids, it required the addition of a ground wire. If none of this works, let me know. I'll go out to my coach and run back through it. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator. --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > Ron > The pump will run when wired straight with a hot wire. HWH says + terminal > should remain hot, then ground is applied when activated, + is not > hot-ground is not applied. > Thanks Lt 90 SP in Eclectic, AL, a two Bird town, 1000 people, 2 Birds > > ----- Original Message ----- > From: "ronmarabito2002" > To: > Sent: Thursday, May 19, 2005 9:43 AM > Subject: [WanderlodgeForum] Re: 92 WB Jacks > > > > Check the motor by applying power directly to the motor terminal. I > > recently had a problem and it was a broken wire under the termianl to > > the armature. Any generator/starter shop can repair it if it needs it. > > Mine showed practically no wear inside. Will outlast me for sure. > > > > R.E. (Ron Marabito, Dallas, TX 92WB40 > > Moderator > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > > > >> My buddy is having trouble with his jacks working on his 92 WB. He > > has changed out 2 relays(Is there a 3rd one he hasn't found?) Every > > thing checks as he has been instructed by HWH but the pump will not > > come on. HWH says it should work by receiving a ground when > > activated. He can make it(the pump) work by providing a hot wire, not > > a ground. Any ideas? > >> Thanks LT 90 SP in Eclectic, AL. > >> > >> > >> [Non-text portions of this message have been removed] > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > 92 WB Jacks - Lawrence Thornell - 05-20-2005 09:34 Thanks for the input Ron He has decided to carry it to Ron in Knoxville for professional assistance. LT ----- Original Message ----- From: "ronmarabito2002" To: Sent: Thursday, May 19, 2005 3:10 PM Subject: [WanderlodgeForum] Re: 92 WB Jacks > If the motor runs, then it has to be one of the two solenoids. If > they were replaced, then check to see if they are wired correctly. > I believe the key has to be on for them to be energized. Maybe > not. I'm having a senior moment. Seems like when I replaced one of > my solenoids, it required the addition of a ground wire. > > If none of this works, let me know. I'll go out to my coach and run > back through it. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator. > > > --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" > >> Ron >> The pump will run when wired straight with a hot wire. HWH says + > terminal >> should remain hot, then ground is applied when activated, + is > not >> hot-ground is not applied. >> Thanks Lt 90 SP in Eclectic, AL, a two Bird town, 1000 people, 2 > Birds >> >> ----- Original Message ----- >> From: "ronmarabito2002" >> To: >> Sent: Thursday, May 19, 2005 9:43 AM >> Subject: [WanderlodgeForum] Re: 92 WB Jacks >> >> >> > Check the motor by applying power directly to the motor > terminal. I >> > recently had a problem and it was a broken wire under the > termianl to >> > the armature. Any generator/starter shop can repair it if it > needs it. >> > Mine showed practically no wear inside. Will outlast me for > sure. >> > >> > R.E. (Ron Marabito, Dallas, TX 92WB40 >> > Moderator >> > >> > >> > --- In WanderlodgeForum@yahoogroups.com, "Lawrence Thornell" >> > >> >> My buddy is having trouble with his jacks working on his 92 > WB. He >> > has changed out 2 relays(Is there a 3rd one he hasn't found?) > Every >> > thing checks as he has been instructed by HWH but the pump will > not >> > come on. HWH says it should work by receiving a ground when >> > activated. He can make it(the pump) work by providing a hot > wire, not >> > a ground. Any ideas? >> >> Thanks LT 90 SP in Eclectic, AL. >> >> >> >> >> >> [Non-text portions of this message have been removed] >> > >> > >> > >> > >> > >> > >> > Yahoo! Groups Links >> > >> > >> > >> > >> > >> > > > > > > > > Yahoo! Groups Links > > > > > > |
