light bulb part no. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: light bulb part no. (/showthread.php?tid=6521) |
light bulb part no. - Stephen Birtles - 03-26-2008 04:09 Go to home depot in low voltage lighting section you will able to obtain them there Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > Anyone have the part number for the 12V light bulb that > inserts into the flush mounted ceiling lamps? It's a small > glass bulb, no base, with two conductors coming out > the bottom. > > Thanks, > David Brady > '02 LXi, NC > light bulb part no. - Chris Fogleman - 03-26-2008 04:11 BB Parts here part number is 4558011 and we have them in stock give us a call at 478-825-0330
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of David Brady Sent: Wednesday, March 26, 2008 8:32 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] light bulb part no. Folks, Anyone have the part number for the 12V light bulb that inserts into the flush mounted ceiling lamps? It's a small glass bulb, no base, with two conductors coming out the bottom. Thanks, David Brady '02 LXi, NC light bulb part no. - ronmarabito2002 - 03-26-2008 04:25 Sounds like an MR 16 Halogen. They are available at most hardware stores, Home Depot and Lowes. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, David Brady > > Folks, > > Anyone have the part number for the 12V light bulb that > inserts into the flush mounted ceiling lamps? It's a small > glass bulb, no base, with two conductors coming out > the bottom. > > Thanks, > David Brady > '02 LXi, NC > light bulb part no. - David Brady - 03-26-2008 04:31 Folks, Anyone have the part number for the 12V light bulb that inserts into the flush mounted ceiling lamps? It's a small glass bulb, no base, with two conductors coming out the bottom. Thanks, David Brady '02 LXi, NC light bulb part no. - brad barton - 03-26-2008 04:45 David, If you're talking about the Halogen bulbs, they're also available at lighting stores...and you might check the filaments. Sometimes..you can thump the bulbs with your fingers and get them to work again. I had to replace mine with rubber gloves to get more traction. BradBarton00LXiDFW bbartonwx@...
How well do you know your celebrity gossip? Talk celebrity smackdowns here. light bulb part no. - David Brady - 03-26-2008 05:41 Thanks for the help everyone. David '02 LXi, NC Chris Fogleman wrote:
light bulb part no. - Pete Masterson - 03-26-2008 06:33 If the bulb is like what's in my coach, they're from "under cabinet lights" sold in home centers. They are a low voltage halogen bulb. Check out your hardware store or a larger home center (Home Depot or Lowes). Hint. Clean the bulb carefully, and handle with a cloth or rubber gloves. Skin oil (fingerprints) can cause the bulb to heat unevenly (they get _very_ hot) and will cause them to fail prematurely. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Mar 26, 2008, at 8:31 AM, David Brady wrote:
