Frequency of oil & filter changes, etc - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Frequency of oil & filter changes, etc (/showthread.php?tid=6536) |
Frequency of oil & filter changes, etc - Ryan Wright - 03-29-2008 13:45 What do you all recommend for oil & filter changes on the 8V92? My generator manual (Yanmar/Kohler 12.5kw) says oil & filter every 150 hours, air & fuel filters at 300 hours, so I'm following that for him. However, I don't see recommendations for the 8V. I changed everything on it 1000 miles ago, so in terms of miles I'm OK, but time wise - I changed it last summer shortly after I bought the coach. I doubt I'll put more than 2000 - 3000 miles a year on the thing in the near term. Also, when should the engine air filter be cleaned & what's the procedure on that? I'm particular about maintenance and just want to make sure I keep up with the details. Thanks! -Ryan '86 PT-40 8V92 Frequency of oil & filter changes, etc - Don Bradner - 03-29-2008 14:41 Table 4-1 of the document at http://www.detroitdiesel.com/pdf/vocations/Lube-Oil-Fuel-Requirements.pdf calls for every 15,000 miles for "Motor Coach" applications, and 6,000 miles for "Transit Coach" applications. An RV application probably covers the spread between those two. Note that there is no time on either, but probably that's because an OTR coach or transit coach will hit those miles more than once per year. I run between 6 and 15K miles per year, and therefore choose to go with annual replacement (and did with SOBs in the past also). My first year with an 8V has turned out to be a 15-month year, because of the inability of CCW to get the drain plug out, but it was only an 8K+ mile stretch so I'm not too concerned. When you don't run even 6K miles it gets quite a bit subjective (different ideas for everybody). I've not had any years with mileage as low as you have, so I'm not sure what I would do if I were you. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 3/29/2008 at 5:45 PM Ryan Wright wrote: >What do you all recommend for oil & filter changes on the 8V92? > >My generator manual (Yanmar/Kohler 12.5kw) says oil & filter every 150 >hours, air & fuel filters at 300 hours, so I'm following that for him. >However, I don't see recommendations for the 8V. I changed everything >on it 1000 miles ago, so in terms of miles I'm OK, but time wise - I >changed it last summer shortly after I bought the coach. I doubt I'll >put more than 2000 - 3000 miles a year on the thing in the near term. > >Also, when should the engine air filter be cleaned & what's the >procedure on that? I'm particular about maintenance and just want to >make sure I keep up with the details. > >Thanks! > >-Ryan >'86 PT-40 8V92 > >------------------------------------ > >Yahoo! Groups Links > > > Don Bradner 90 PT40 "Blue Thunder" Eureka, CA Frequency of oil & filter changes, etc - ronmarabito2002 - 03-29-2008 15:36 8V92 at 6000 miles or 12 months. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > What do you all recommend for oil & filter changes on the 8V92? > > My generator manual (Yanmar/Kohler 12.5kw) says oil & filter every 150 > hours, air & fuel filters at 300 hours, so I'm following that for him. > However, I don't see recommendations for the 8V. I changed everything > on it 1000 miles ago, so in terms of miles I'm OK, but time wise - I > changed it last summer shortly after I bought the coach. I doubt I'll > put more than 2000 - 3000 miles a year on the thing in the near term. > > Also, when should the engine air filter be cleaned & what's the > procedure on that? I'm particular about maintenance and just want to > make sure I keep up with the details. > > Thanks! > > -Ryan > '86 PT-40 8V92 > Frequency of oil & filter changes, etc - Gregory OConnor - 03-29-2008 17:45 Unlike most of the good folks on the forum I am not a fan of over maintaining. For the most part, I'm lazy and cheap. I always looked at the 12 month date to change factor with little reguard but did the oilchange exersize annualy as I have a bum odometer and oil was cheap. I never do oil analysis because I dont think I would open the engine if the result dictated a need. Now that an oil change is $140.00 parts I might do an oil analysis to check the condition of the oil and need for change at my Aug 10 change date. You never need to change the airfilter if it doesnt get dirty. This is where time and mile prompts are of little value . My dump truck runs off road so I air blow clean once then replace the filter about 4 times per the year. My 94pt and most trucks have a gauge that shows air filter issue. . I like to set the new filter in; start the truck then try to pull it out prior to locking it inplace. this will test for a tight seal. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > 8V92 at 6000 miles or 12 months. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > What do you all recommend for oil & filter changes on the 8V92? > > > > My generator manual (Yanmar/Kohler 12.5kw) says oil & filter every 150 > > hours, air & fuel filters at 300 hours, so I'm following that for him. > > However, I don't see recommendations for the 8V. I changed everything > > on it 1000 miles ago, so in terms of miles I'm OK, but time wise - I > > changed it last summer shortly after I bought the coach. I doubt I'll > > put more than 2000 - 3000 miles a year on the thing in the near term. > > > > Also, when should the engine air filter be cleaned & what's the > > procedure on that? I'm particular about maintenance and just want to > > make sure I keep up with the details. > > > > Thanks! > > > > -Ryan > > '86 PT-40 8V92 > > > Frequency of oil & filter changes, etc - Pete Masterson - 03-30-2008 05:08 FWIW, the '95 DD Series 60 has a 'forever' air filter. You blow it clean with compressed air and put it back in. In theory, it never needs to be replaced. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Mar 29, 2008, at 9:45 PM, Gregory OConnor wrote: <snip> Frequency of oil & filter changes, etc - p_a_lazar - 03-30-2008 06:01 That's really interesting Pete. Our 97 has a disposable and we just had it replaced for the second time in 64K miles. I know we didn't *need* to have it done, but it wasn't all that expensive and a real pain to change, so when I have an opportunity to get it done reasonably, I do it. ![]() Paul 97wb43 --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > FWIW, the '95 DD Series 60 has a 'forever' air filter. You blow it > clean with compressed air and put it back in. In theory, it never > needs to be replaced. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > Frequency of oil & filter changes, etc - Ryan Wright - 03-30-2008 06:29 Thank you all for the replies. I'll go ahead and stick with once a year, then, unless my mileage increases dramatically. -Ryan '86 PT-40 8V92 On 3/29/08, Ryan Wright > What do you all recommend for oil & filter changes on the 8V92? Frequency of oil & filter changes, etc - David Brady - 03-30-2008 07:11 Ditto here Paul. My '02 has the factory OEM paper disposable unit. Under the conditions I subject my coach to, the paper element lasts a long time: 100K plus miles. In fact, they work better once broken in; i.e., once they've accumulated a layer of outer dust which functions as a prefilter. The folks over on the DetroitDiesel forum strongly recommend against the aftermarket cleanable lifetime air filters. David Brady '02 BlueBird LXi p_a_lazar wrote:
Frequency of oil & filter changes, etc - Pete Masterson - 03-30-2008 14:05 As far as I can tell, the 'forever' filter on my DD Series 60 is an OEM unit. They may have had second thoughts after going with it or it was a Blue Bird idea at the time. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Mar 30, 2008, at 12:11 PM, David Brady wrote: Ditto here Paul. My '02 has the factory OEM paper disposable unit. Frequency of oil & filter changes, etc - Gregory OConnor - 03-30-2008 15:07 Pete, that brings up a good point about taking part numbers off a broken or worn part to make a change. You can not tell if the PO (previous owner)used the correct replacement. The forever cleanable filters are good but if you blow air inward the sharp dust may clog or open holes in the fabric. I bet owner-operators do a good job but employee drivers and shop techs may not cop to blowing a hole in a $250.00 filter. You can tell if the filter seals up by trying to remove it with the Detroit running. GregoryO'Connor 94ptRomoland --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > As far as I can tell, the 'forever' filter on my DD Series 60 is an > OEM unit. They may have had second thoughts after going with it or it > was a Blue Bird idea at the time. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Mar 30, 2008, at 12:11 PM, David Brady wrote: > > > Ditto here Paul. My '02 has the factory OEM paper disposable unit. > > Under the conditions I subject my coach to, the paper element lasts a > > long time: 100K plus miles. In fact, they work better once broken in; > > i.e., once they've accumulated a layer of outer dust which functions > > as a prefilter. > > > > The folks over on the DetroitDiesel forum strongly recommend > > against the aftermarket cleanable lifetime air filters. > > > > David Brady > > '02 BlueBird LXi > > > > p_a_lazar wrote: > >> > >> That's really interesting Pete. Our 97 has a disposable and we just > >> had it replaced for the second time in 64K miles. I know we didn't > >> *need* to have it done, but it wasn't all that expensive and a real > >> pain to change, so when I have an opportunity to get it done > >> reasonably, I do it. ![]() > >> > >> Paul > >> 97wb43 > >> > >> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > >> wrote: > >> > > >> > FWIW, the '95 DD Series 60 has a 'forever' air filter. You blow it > >> > clean with compressed air and put it back in. In theory, it never > >> > needs to be replaced. > >> > > |
