Fuel Injectors - 77 FC33 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fuel Injectors - 77 FC33 (/showthread.php?tid=6561) |
Fuel Injectors - 77 FC33 - erniecarpet@... - 04-06-2008 08:40 The dog house has 2 hinges, each with a set screw. The base has 2 screws on the firewall and various bolts around the base under the carpet. It takes 2 to handle the top part of the dog house- its' heavy.
Ernie Ekberg 83PT40 Livingston, Montana currently in oakley, kansas Planning your summer road trip? Check out AOL Travel Guides. Fuel Injectors - 77 FC33 - c.martha37 - 04-06-2008 10:35 My mechanic says that the engine has to come out to replace the injector on the passenger side. Is this true? Is there something he's missing, does the floor board come out so the valve covers can be removed, this seems to be the problem. Joe in Sebastian Fuel Injectors - 77 FC33 - Jon - 04-06-2008 12:05 --- In WanderlodgeForum@yahoogroups.com, "c.martha37" > > My mechanic says that the engine has to come out to replace the > injector on the passenger side. Is this true? Is there something he's > missing, does the floor board come out so the valve covers can be > removed, this seems to be the problem. Joe in Sebastian If you have the original Blue Box somewhere it gives details on how to disassemble the Dog house so you can get at the Vlv covers. I just went over to Bruces site and tried to find the photo's I took while taking my apart but could not locate them. Its not that hard of a job, just time consuming. The dog house will come oft with about an hour worth of labor. Let me know if you have a blue box instruction book for this operation. And I would say you should be able to remove those injectors with the dog house removed. Jon > Jon\Rebel Bird Fuel Injectors - 77 FC33 - c.martha37 - 04-09-2008 13:03 Thanks much. --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > The dog house has 2 hinges, each with a set screw. The base has 2 screws on > the firewall and various bolts around the base under the carpet. It takes 2 to > handle the top part of the dog house- its' heavy. > > Ernie Ekberg > 83PT40 > Livingston, Montana > > currently in oakley, kansas > > > > **************Planning your summer road trip? Check out AOL Travel Guides. > (http://travel.aol.com/travel-guide/united-states?ncid=aoltrv00030000000\ 016) > Fuel Injectors - 77 FC33 - c.martha37 - 04-09-2008 13:05 John, thanks for the info. I do not have 'blue box'. I downloaded some info from the archive files on this forum. I'll send to mechanic and forward this information to him. Thanks. --- In WanderlodgeForum@yahoogroups.com, "Jon" > > --- In WanderlodgeForum@yahoogroups.com, "c.martha37" > > > > > My mechanic says that the engine has to come out to replace the > > injector on the passenger side. Is this true? Is there something > he's > > missing, does the floor board come out so the valve covers can be > > removed, this seems to be the problem. Joe in Sebastian > > > If you have the original Blue Box somewhere it gives details on how to > disassemble the Dog house so you can get at the Vlv covers. I just > went over to Bruces site and tried to find the photo's I took while > taking my apart but could not locate them. Its not that hard of a job, > just time consuming. The dog house will come oft with about an hour > worth of labor. Let me know if you have a blue box instruction book > for this operation. And I would say you should be able to remove > those injectors with the dog house removed. Jon > > > Jon\Rebel Bird > Fuel Injectors - 77 FC33 - Stephen Birtles - 04-09-2008 13:51 If you will send me your email I will send you the owners manuals for the 77 bird Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "c.martha37" > > My mechanic says that the engine has to come out to replace the > injector on the passenger side. Is this true? Is there something he's > missing, does the floor board come out so the valve covers can be > removed, this seems to be the problem. Joe in Sebastian > |
